2022 RAM 1500 Lease Deals and Prices
1568101130
  • MichaellMichaell Moderator Posts: 259,126
    Good evening, could I have the numbers for Ram 1500 Big Horn 4x2 crew cab 5’7 bed. 33401
    .00006 and 54%
    $750 incentives
  • HotshotHotshot Member Posts: 69
    TRX 4x4 24/10 residual and mf for 11219. Also if you can specify if any other term has any sort of incentives, thank you.
    Standard MF and 65% residual
    No incentives
  • warz00warz00 Member Posts: 34
    Thx in advance for MF, Resid
    2022 Ram Rebel 4x4, crew cab, 5.7L, zip 10543 36/12
    .00049 and 56%
    $1000 incentives
  • GreedIsGoodGreedIsGood Member Posts: 9
    Good morning,
    Can I have the numbers for Ram 1500 Laramie 4x2 crew cab 5’7 bed. 33401
    Good morning,
    .00014 MF and 55% RV
  • Hellp50014Hellp50014 Member Posts: 77
    Is there a separate forum for 2500 2022 trucks
    I’m looking for Tradesman 2500 crew cab 6 4 bed with power wagon package 4x4 Gas Engine
  • kyfdxkyfdx Moderator Posts: 261,245
    Sorry, we don't have any info on HD trucks.
  • Omahaeagle22Omahaeagle22 Member Posts: 5
    Can you please provide MF and Residual for 2022 Ram 1500 Laramie 4WD Crew Cab, 36/12k, zip 68164? Thanks!
    .00013 MF and 56% residual
    $2000 incentives
  • carguy1985carguy1985 Member Posts: 73
    2022 Ram TRX
    MF and Residual
    90211
    2022 Ram TRX
    MF and Residual
    90211
    Standard MF
    57% residual
  • KravinKravin Member Posts: 5
    edited February 2022
    Hi could I get the MF, residual and incentive for a 36 months lease on a Ram 1500 Limited 4wd crew cab with Hemi 5.7 e Torque. I"m in the zip code 84105? Thank you so much in advance.
    .00035 MF and 48% RV
    $1000 incentives
  • mavamava Member Posts: 33
    Hi could I get the MF, residual, and any incentives for a 2022 Crew Cab 4x4? Would like to compare pricing across the Limited, Laramie, and Laramie Longhorn editions, please. Zip is 93308. 36/10 or 24/10 terms. Thank you!
    LAR
    24/10 - .00017 and 66%
    36/10 - .00013 and 57%
    LTD
    .00044 and 59%
    .00035 and 51%
    LONG
    .00012 and 58%
    .00009 and 50%
    No incentives
  • taylor8xeno8taylor8xeno8 Member Posts: 3
    Hi can you give me Lease numbers on a 2022 Laramie Crew cab 4x2 24/10 75078
    .00020 MF and 65% residual
    Thank you!, is there somewhere the MF is published i can see please? Dealer is giving me run around on the MF
    Not that we know of.
    Then where the heck do you pull this info from lol
    The information is from Chrysler Capital, but it is proprietary. They don't publish it for the public.
  • SkiDoggSkiDogg Member Posts: 30
    Can I have the RV and MF for 2022 Ram 1500 Limited crew cab 5x7 box 4x4; 36 months at 10k. Zip code is 27587. Thanks.
    .00035 and 51%
  • dv8tor1dv8tor1 Member Posts: 24
    What's the standard MF for 2022 TRX? 36/10 - .002710?
    TIA
    TIA
    .00242 for 36 months
  • bigliljenbigliljen Member Posts: 28
    Hi there,
    Could I please get MF, RV, incentives for 2022 Ram 1500 Big Horn-Quad Cab-4x4-6'4 box? Zip 44055
    36/10k
    thanks!
    bigliljen said:
    Hi there,
    36/10k
    thanks!
    .00009 and 57%
    $3050 incentives
  • Burnee_doggBurnee_dogg Member Posts: 2
    Good morning! Can you please provide MF, RV, and incentives for a 2022 Laramie Crew Cab 4x4, 36/15k, zip 54956? Thank you!
    .00013 MF and 54% RV
  • mmendoza2mmendoza2 Member Posts: 193
    Hello, could i please have the lease numbers for a 2022 Ram 1500 crew cab bighorn with V6 etorque (4x2) in south florida 33027
    Any lease incentives?
    .00006 and 55%
    $750 incentives
  • ggreen006ggreen006 Member Posts: 26
    Can you please provide MF and Residual for 2022 Ram 1500 Laramie 4WD Crew Cab, 36/10k and 36/15k, zip 55125? Thanks!
    .00013 MF and 54% Residual
    $2000 incentives
  • jontheaegonjontheaegon Member Posts: 34
    Hi! Can I please get MF and residual for 2022 Ram 1500 Big Horn Quad Cab 4x2, 36/20 zip 95695. Thanks! any incentives? If standard MF, is it 0.00006?
    I meant 36/10, sorry!
    .00002 and 55%
    $1500 incentives
  • Chucktown99Chucktown99 Member Posts: 1
    Thanks in advance for MF, RV!!
    2022 Ram 1500 Bighorn 4x2, quad cab, buyer zip 29445 dealer 28134 36/10
    .00002 MF and 55% residual
    $1500 incentive
  • unikacunikac Member Posts: 17
    Can you please provide RV/MF/incentives for:
    Big Horn Crew Cab 4x4
    Rebel Crew Cab 4x4
    Limited Crew Cab 4x4
    24/36 months, 10k miles, zip 06880?
    Rebel Crew Cab 4x4
    Give us your top three combinations, please.
  • badgerpacbadgerpac Member Posts: 7
    Can you please provide MF, Residual, and incentives for 2022 Ram 1500 Laramie 4WD Crew Cab, 36/12k, and 36/15k zip 54812? Thanks, I appreciate it!
    $2000 incentives
  • PwheelsPwheels Member Posts: 19
    Will someone assist me with the MF, Residual, and incentives for both 36/10k and 42/10k (if they are still doing 42's that is) on the following in 45237:
    -22 Laramie 4WD Crew 5'7"
    -22 Big Horn 4WD Crew 5'7"
    Pwheels said:
    Will someone assist me with the MF, Residual, and incentives for both 36/10k and 42/10k (if they are still doing 42's that is) on the following:
    What is your location?
    W
    Sorry coffee hadn't kicked in yet. 45237
    Pwheels said:
    W
    .00013 MF and 57% residual. $1200 incentive
    .00012 MF and 57% residual. $2150 incentive
    42 mo not supported
  • mozonemozone Member Posts: 3
    Would appreciate any help in determining how good/bad this deal would be:
    2022 Laramie Crew Cab 4x4 5'7" bed
    MSRP $72,210
    12k miles per year, 36 months
    $0 down
    $859 per month + tax
    Zip code 50266
    MSRP $72,210
    $0 down
    Zip code 50266
    What is the adjusted cap cost for this quote?
    .00013 MF and 56% RV
