2022 RAM 1500 Lease Deals and Prices
1121315171830
  • zbell335zbell335 Member Posts: 17
    Hello looking for MF and RV for Ram 1500 Laramie 4x4 Crew Cab, zip 33131, 36/10 & 42/10. Thank you
  • kyfdxkyfdx Moderator Posts: 272,037
    .00017 MF and 54% residual
    $1300 incentive
    42 month term has no support
  • gstapp71gstapp71 Member Posts: 44
    Ram appears to have a ton of incentives for price as well. Do you know if you can use the price discounts to get the cap cost down with the $1950 in incentives? Thanks
    No, extra incentives are for finance and purchase. They won't be compatible with the lease program.
    There could be other loyalty or conquest incentives, if you qualify.
  • TheUSPSTheUSPS Member Posts: 29
    Hello, can you provide the MF and RV for a Ram 1500 Laramie Crew Cab 4x4, 36k/10, 61107. Thank you!
  • MichaellMichaell Moderator Posts: 268,279
    .00017 MF and 54% RV
    $1950 incentives
  • 9_lease9_lease Member Posts: 56
    Hello can I have the res, mf, and incentives for a 2022 Ram Laramie/Big Horn 2WD Crew Cab Short Bed
    24/36 10
    24/36 10
    What is your location?
  • LoGiKLoGiK Member Posts: 98
    Can I please have RV, MF, and Incentives for the following:
    36/10k
    Zip: 33016
    Big Horn Crew Cab 4x4 - 5'7" Box
    Big Horn Quad Cab 4x4 - 5'7" Box
    36/10k
    Zip: 33016
    .00002 and 53%; $2550 incentives
    .00001 and 53%; $3250 incentives
  • ggreen006ggreen006 Member Posts: 26
    Looking for lease details for 1500 4x4 Laramie Crew w V6. Considering 3yr/36k or 3yr/30k for zip 55125.
    TIA!
    TIA!
    .00017 and 53%
    $2800 incentives
  • xTGoodxTGood Member Posts: 3
    .00017 MF and 53% residual
    $1300 incentive
  • Mmey1581Mmey1581 Member Posts: 1
    Zip 55033
    Looking for residual and MF for:
    2022 Ram 1500 Classic WARLOCK QUAD CAB 4X4 6'4 BOX
    36/10k
    36/12k
    Mmey1581 said:
    Zip 55033
    36/10k
    36/12k
    .00001 MF and 52% residual
    $4050 incentives
  • ryanjuba11ryanjuba11 Member Posts: 23
    edited June 2022
    Hello Can I get the incentives and residual if I used a standard money factor on a Laramie crew cab 4x4 in 95670? What is Rams standard money factor? Also can I get the incentives if I used the reduced money factor of .00017? Interested to see what I qualify by taking the increased interest rate(money factor) since I may be trading in the truck in a few months it might be better to take more of the price to have more equity then the lower interest rate.
    These both would be for a 36 month 12k mile lease.
    Do dealers not usually allow you top take the higher incentives with higher interest rate? I know the monthly payment would jump but the incentives would help with the equity in the event I traded it in fairly quick.
    $1300 incentive
    Standard MF and 53% residual
    $4050 incentive
    Standard MF = .00347 MF
    Doubtful that would work out, taking the higher incentives
  • gsrodeo47gsrodeo47 Member Posts: 1
    edited June 2022
    2022 Ram 1500 Quad Cab, 4x4, 6'4 Box
    2022 Ram 1500 Crew Cab Laramie, 4x4, 5'7 Box
    36m/12k, 32765
    thanks!
    36m/12k, 32765
    thanks!
    What trim for the Quad Cab?
  • Mike098Mike098 Member Posts: 8
    Hi can I get residual and money factor for
    zip- 08234
    36m/10k
    39m/10k
    Thanks!!!
    zip- 08234
    36m/10k
    39m/10k
    Thanks!!!
    $3450 incentives
    39 month term not supported.
  • MnellyMnelly Member Posts: 31
    Can you please provide me with the MF/Res on the following?
    2022 Ram 1500 Big Horn Crew Cab 4x4 Short bed - Backcountry Package
    Plus any incentives
    Current lessee
    Zip code 06492
    Plus any incentives
    Current lessee
    Zip code 06492
    .00002 MF and 50% residual
    $2900 incentives
  • samm14samm14 Member Posts: 176
    2022 Ram 1500 Rebel Short bed 4x4
    mf/ rv zip 10383
    incentives
    36/10k
    Zip: 33016
    Can I please also have RV, MF, Incentives for:
    Laramie - Crew Cab - 4x4 - 5'7" Box
    Zip: 33016
    Terms: 36/10k
    mf/ rv zip 10383
    incentives
    Crew or Quad cab?
    LoGiK said:
    36/10k
    Zip: 33016
    Zip: 33016
    Terms: 36/10k
    .00017 and 54%
    $1300 incentives
    crew
    24/36 10
    92835
    mf/ rv zip 10383
    incentives
    samm14 said:
    crew
    Can you check the ZIP?
    9_lease said:
    24/36 10
    92835
    BH
    .00018 MF and 59% residual
    .00022 MF and 52% residual
    $2800 incentive
    LAR
    .00028 MF and 61% residual
    .00008 MF and 52% residual
    $1300 incentive
    11714
    mf/ rv zip 10383
    incentives
    samm14 said:
    crew
    samm14 said:
    11714
    Crew or Quad cab?
    crew cab
    mf/ rv zip 10383
    incentives
    samm14 said:
    11714
    samm14 said:
    crew cab
    .00092 MF and 56% RV
    $1800 incentives
  • 4114541145 Member Posts: 3
    Can I get the MF and RV for 36/12 and 48/12 on 2022 RAM Rebel 4x2 Short bed for 77450? Also are there any incentives and finance options available?
  • KDinger4321KDinger4321 Member Posts: 19
    Hello looking for MF and RV for 2022 Ram 1500 Limited Longhorn 4x4 Crew Cab, zip 16602, 36/12 Thank you
    crew or quad cab?
    .00047 MF and 48% RV
    $1950 incentives
  • julzbjulzb Member Posts: 25
    edited June 2022
    Could I get numbers on '22 Ram 1500 Laramie 4x4 Crew Cab and Big Horn 4x4 Crew Cab? Both 36/10K. Zip 22172. Thanks!
    crew or quad cab?
    crew cab
    BH - .00002 and 53%; $4900 incentives
    LAR - .00017 and 54%; $3450 incentives
    41145 said:
    crew or quad cab?
    crew cab
    Standard MF
    54% / 47% RV
    $1300 incentives
    Finance
    1.9% up to 60 months
    2.9% for 61-72 months
    $1000 incentives
    -or-
    $2000 incentives with standard rate financing
    zip- 08234
    36m/10k
    39m/10k
    Thanks!!!
    $3450 incentives
    Is there a difference in residual with 5.7 hemi vs diesel?
    zip- 08234
    36m/10k
    39m/10k
    Thanks!!!
    $3450 incentives
    No, all terms are the same
  • MikleinadMikleinad Member Posts: 7
    Can I get the following:
    2022 Ram 1500 big horn crew cab 4x4
    24/10
    mf
    rv
    zip 11360
    incentives
    24/10
    mf
    rv
    zip 11360
    incentives
    .00020 MF and 62% RV
    .00002 MF and 53% RV
    $2900 incentives
  • Interstellar76Interstellar76 Member Posts: 2
    Howdy! I'm showing what looks like to be pretty good incentives for Texas at the moment. ($4k+)
    2022 Ram 1500 Laramie Crew Cab
    36/10 Just curious on incentives and possible tax credits on lease.
    RV looks like 54 w/ incentivized MF @ .00017. Please correct if incorrect. Thank y'all!!
    2WD or 4WD?
    We don't have info on Texas tax credits
