2022 Chevrolet Bolt EUV Lease Deals
2
  • MichaellMichaell Moderator Posts: 265,335
    Kafhfeu said:
    Can I please have RV/MF and any incentives on an EUV premier in zip 17013 for 36/10.
    .00047 MF and 64% RV
  • aasuncionaasuncion Member Posts: 126
    May I please get the May, MF, RV, and incentives for the 2022 Bolt EUV Premier, 36/10, 39/10, zipcode: 08610. Thanks in advance.
  • kyfdxkyfdx Moderator Posts: 268,141
    .00050 MF
    62%/59% residual
  • budman21budman21 Member Posts: 50
    Could I get the May 36/10 MF and RV for a 2022 Bolt EUV LT and Premier with 19352 Zip? Thanks! fyi I'm seeing the $3750 Lease Loyalty for Bolt owners extended through May.
    LT - .00061 and 62%
    Prem - .00050 and 62%
    No info on loyalty
  • Oppressed77Oppressed77 Member Posts: 13
    May I please also get the MF, RV, and incentives on a EUV LT 36/10 - zip 95831 for May.
    Thank you in advance, I really appreciate it!
    .00061 MF and 62% RV
    $750 customer incentive
  • joec34_5joec34_5 Member Posts: 22
    May I please get for zip 20109 and 19734 the MF, RV, and incentives on a EUV LT 36/12 & 36/15
    .00061 MF and 59% RV
    Either location
    Thank you. could you please advise what the residual is for EUV LT 36/12 ? May I also please receive for zip 20109 and 19734 the MF, RV, and incentives on a EUV Premier for 36/12 & 36/15
    Add 2% for 12K
    Premier
    .00050 MF and 59% RV
  • adam045adam045 Member Posts: 6
    May I please also get the MF, RV, and incentives on a EUV LT 36/10, 36/12 - zip 11784 for May. Thanks!
    .00061 MF and 61% residual
  • TheNorthTheNorth Member Posts: 57
    Please may I get the MF and RV for 36mth and 12k miles per year for 2022 Chevrolet Bolt EUV LT FWD, zip is 93420
    Any incentives also please
    Thanks in advance
    Thanks in advance
  • Maverick2022Maverick2022 Member Posts: 2
    Can I please have EUV LT and Premier 36/10 MF/residual/incentives for zip 92620. Thank you!
    LT - .00061 MF and 62% residual
    Prem - .00050 MF and 62% residual
  • EVFinanceBroEVFinanceBro Member Posts: 6
    36/10 80129 Bolt EUV Premier Lease
    24/10 80129 Bolt EUV Premier Lease
    Looking for MF, RV, and incentives
    No 24 month lease term for the Bolt
    .00050 MF and 62% RV
  • JBenGuinnJBenGuinn Member Posts: 102
    Greetings! Can I please have EUV LT and Premier MF, residual, and incentives for 36/10 in 37209. Thanks!
    LT - .00061 and 62%
  • Kipster1203Kipster1203 Member Posts: 22
    Hey there, could I please have the MF, residual and any incentives on the EUV Premier?
    This is for 36/12 at zip 15241. Thanks for your time!!
    .00050 and 61%
  • bloomingbenbloomingben Member Posts: 4
    What are the incentives/mf/residual on a 2022 Chevrolet Bolt EUV Premier @ 12k/36 and 15k/36 in zip code 92124?
    Also, can you tell me the same for the LT Trim?
    LT - .00061 MF and 59% residual
    Prem - .00050 MF and 59% residual
  • rtwhitehurstrtwhitehurst Member Posts: 47
    Hello. Have the July numbers been released? 36/12k Premier in 29579. Thanks!
    July programs will be released tomorrow.
    Hello, could I also get the numbers for a 36/12k lease on an EUV LT at 15241?
    Thank you so much!
  • shihaamsshihaams Member Posts: 12
    Hi, may I please get July 22 numbers for a Bolt EUV LT & Premier?
    36/12k
    Zip 94542
    Any incentives? Thx!
    edited July 2022
    Thank you so much!
    .00069 MF and 61% RV
    36/12k
    Zip 94542
    LT - .00069 and 61%
    Prem - .00057 and 61%
    $750 lease cash
    Can I get the updated numbers, 36/12k Premier in 29579. Thanks!
    .00057 MF and 61% residual
  • joydivisionjoydivision Member Posts: 33
    Hi Can I get the numbers for Bolt EUV 2022 Premier
    36/12k
    36/15k
    Zip 43551
    36/12k
    36/15k
    Zip 43551
    .00057 MF and 59% RV
  • Dealseeker9999Dealseeker9999 Member Posts: 5
    edited July 2022
    Can I get a MF/RV/ incentives on a Bolt EUV premiere 36m/15k?
    Does the $6300 incentive apply?
    08619 zip
    Thanks a bunch in advance!
    08619 zip
    The $6300 is for purchase only
  • mitsleymitsley Member Posts: 37
    Hi there,
    Can you share RV, MF and incentives on an EUV Premier in 94549 for 36/10 and 36/12?
    Does Chevrolet allow MSDs?
    mitsley said:
    Hi there,
    .00057 and 61%
    No MSDs, to our knowledge
  • SFCarGuySFCarGuy Member Posts: 3
    Can you share current July 2022 RV and MF for 90041 on euv premier launch edition, 36/12?
  • ApplephanApplephan Member Posts: 52
    Hello, please forward, MF, RV and lease incentives for Bolt EUV premier in zip code 07960. 36/15. Thank you.
    .00057 MF and 59% residual
    Hi there,
    Do you already have the *August* Residual, MF and incentives for a *2022* Bolt EUV Premier in 94549, 36/10 and 36/12?
    Many thanks!
    mitsley said:
    Hi there,
    Many thanks!
    Not until next week.
    edited August 2022
    Hello, please forward, MF, RV and lease incentives for August for a Bolt EUV premier in zip code 07960. 36/15. Are the numbers the same for a Launch Edition? If not, please include those as well. Thank you.
    Applephan said:
    May I please get the May, MF, RV, and incentives for the 2022 Bolt EUV Premier for August, 36/10, 39/10, zipcode: 08610. Are the numbers different for a Launch Edition? If so, please include those as well. Thanks in advance.
    .00057 MF
    62% 36/10
    59% 39/10
    Hello, sorry, but somehow my request was modified. Please forward, MF, RV and lease incentives for August for a Bolt EUV premier in zip code 07960. 36/15. Are the numbers the same for a Launch Edition? If not, please include those as well. Thank you.
    Subtract 3% from residual on previous reply for 15K/yr
    Launch Edition has no effect on numbers
  • double_rdouble_r Member Posts: 56
    Please provide MF, residual and any incentives for a '22 Bolt EUV LT, zip code: 07006; thanks in advance!
