2022 GMC Sierra Lease Deals and Prices
1457910
  • Osmany21Osmany21 Member Posts: 3
    edited June 2022
    Hello can I get the Residual and MF for 2022 Sierra Elevation crew / short 5.3L 10/36 and 12/36.
    Located in 33176. Thanks
  • kyfdxkyfdx Moderator Posts: 261,194
    LTD or new style?
    2WD or 4WD?
    If 4WD, 3SB or 3VL?
  • Hellp50014Hellp50014 Member Posts: 77
    2022 GMC Sierra 1500 Elevation 4x4
    Crew Cab diesel
    36/10 39/10
    24/10
    60192
    It’s for the new body style not the old LTD trim
    Crew Cab diesel
    36/10 39/10
    24/10
    60192
    Different numbers for the 3SB or 3VL option.
  • jfergenjfergen Member Posts: 69
    2022 GMC Sierra AT4X Crew Cab 6.2 4x4
    zip 50588
    Odd question, i can pick this up this week, or I can pick it up next week which will start July. Do you believe the residual will stay the same or change for the better or worse if I wait?
    zip 50588
    .00213 MF and 65% residual
    No guesses on what happens next month
    edited June 2022
    zip 50588
    I had a typo, sorry. I need 36/12
    jfergen said:
    zip 50588
    64% residual
  • ROLO_ExoticsROLO_Exotics Member Posts: 43
    What is the MF and RV for 2022 Sierra Denali ultimate diesel For 36m/12k and 39mo/12kmiles in 93060
    Thankyou
  • MichaellMichaell Moderator Posts: 259,078
    Thankyou
    Current GM programs from June run through July 5th
  • mb9182mb9182 Member Posts: 38
    2022 sierra 1500. Elevation, crew cab 4x4 07733.
    36/15k. RV/MF Incentives.
    Thanks in advance
    Thanks in advance
    Old or new bodystyle?
    3SV or 3VL?
  • bmwsrmylifebmwsrmylife Member Posts: 26
    Hello can I have the MF/RV for the new body 2022 Sierra Denali 4x4 crew cab short bed. Zip 15227. Thanks!
    .00208 MF
    66%
    63% RV
  • justinluv949justinluv949 Member Posts: 18
    Hello what are the RV/Mf 36 months 10k top tier credit.
    2022 new interior xt4 diesel crew cab,
    92647
    92647
    I don't see an XT4 trim level for the Sierra.
  • odelaydodelayd Member Posts: 19
    edited July 2022
    Hi, can I get the 36/12 residual and MF for the Sierra 1500 5.3 Gas Elevation 4x4 (new style) in 91350?Thanks!
    Double or Crew cab?
    Double or Crew cab?
    Crew cab please.
    odelayd said:
    Double or Crew cab?
    Crew cab please.
    Ugh, one last question - 3SB or 3VL engine?
    odelayd said:
    Double or Crew cab?
    Crew cab please.
    3SB, with the bucket seats :)
    odelayd said:
    odelayd said:
    Double or Crew cab?
    Crew cab please.
    .00227 MF and 65% residual
    Hello > @Michaell said:
    .00208 MF
    66%
    63% RV
    Thanks! Is the Ultimate trim the same?
    .00208 MF
    66%
    63% RV
    Yes
  • aelwynaelwyn Member Posts: 6
    Hi there. Can I get the residual and MF for:
    2022 Sierra 1500 AT4X (with the V8, not the diesel, if it matters)
    36/12k
    zip code 80249
  • ryanjuba11ryanjuba11 Member Posts: 23
    I’m looking for a lease mf res and incentives for Sierra 1500 elevation crew cab 4wd in 95670.
    36 month 12k a year.
    3 sb with the duramax
    Can I also get the same numbers for the limited elevation? Crew cab 4x4
    36/12k
    zip code 80249
    .00220 MF and 64% residual
    .00122 and 59%
    .00227 and 65%
  • seanmwelshseanmwelsh Member Posts: 37
    edited July 2022
    Are there any lease numbers available for a 2022 GMC Sierra 3500 HD SLT? CrewCab with the 6.6L gas V8??
    Zip code 61111
    36/10 or 39/10
    OR a 2022 GMC 2500 HD Denali trim, CrewCab with the gas engine. Both 4WD.
    Zip code 61111
    36/10 or 39/10
    Sorry, we don't have the GMC HD lease programs.
  • TrentgwTrentgw Member Posts: 59
    Hi - Can I please get the numbers for the following:
    GMC Sierra - new body style
    Elevation w/ Leather
    Crew Cab - short box
    4x4
    36mo
    12k & 15k miles/year
    4x4
    36mo
    What is your location?
  • NightsSunnyNightsSunny Member Posts: 8
    Can i get the numbers for a GMC AT4X 2022 based in NJ (08859). The MSRP $80,935. What discounts should i try to get of MSRP?
    .00220 MF and 62% residual
    See the Price Checker link, below
  • namtarunamtaru Member Posts: 3
    edited July 2022
    Hi, can I get the 36/10 and 36/12 residual and MF for the Sierra 1500 5.3 Gas Elevation 3SB 4x4 Crew Cab Short Box in 48843.
    edit: wow you are fast! Thanks again.
    namtaru said:
    Hi, can I get the 36/10 residual and MF for the Sierra 1500 5.3 Gas Elevation 3SB 4x4 Crew Cab in 48843.
    .00227 MF and 66% residual
  • CCripsyCCripsy Member Posts: 20
    Hi, can I get the 39/12 residual and MF for August for the 2022 Refresh Sierra 1500 AT4 in 33610?
  • RoxGRoxG Member Posts: 8
    edited August 2022
    Hi - looking for residual and MF for 22 refresh sierra at4 duramax 36/10 crew cab. 14063
    .00220 MF and 65% residual
  • Fellows941Fellows941 Member Posts: 9
    Can I please have the residual and mf for a 2022 Sierra new body style Elevation crew cab with the 2.7 4 cylinder 2wd 36/10, and 48/10 in 33629
    .00282 MF and 75% residual
    .00224 MF and 66% residual
  • Tim5150Tim5150 Member Posts: 98
    Can I please have MF/RV for Sierra 1500 LTD Short Bed Crew Cab in AT4 trim? Zip Code 32547
    .00101 and 58%
    .00176 and 52%
  • boomtown1boomtown1 Member Posts: 19
    good morning,
    Can I have the RV and MF for a Sierra 1500 Denali short bed in 32903? 4x2 and 4x4 models, and 36/12 and 39/12.
    boomtown1 said:
    good morning,
    .00208 MF
    65%/62% residual for 36/39 mo
    Either drive
  • Brade96Brade96 Member Posts: 48
    Hello...can you please share the MF and residual for the 2022 Sierra 1500 Elevation 2WD for a 36/12 in 33312. Thanks.
    Double or Crew Cab?
    LTD or New body style?
