2022 Toyota Tundra Lease Deals and Prices
1567911
  • MichaellMichaell Moderator Posts: 270,947
    Hello, have the numbers changed for August?
    SR5 crewcab, 5.5ft box, 4x4, in 55912
    36/10 and 36/12
    August programs released tomorrow.
    Hi, may I please have the MF/RV and any incentives for -
    2022 Tundra SR 4x4 CrewMax 5.5ft
    2022 Tundra SR5 4x4 CrewMax 5.5ft
    2022 Tundra Limited 4x4 CrewMax 5.5ft
    24/12 and 36/12 in zip 11427
    .00235 MF
    82% / 76%
    80% / 74%
    78% / 72%
  • ejc770ejc770 Member Posts: 8
    ejc770 said:
    ejc770 said:
    ejc770 said:
    Could I get lease numbers for Tundra SR5 4X4 5.5 36/12 24/12 for 28117. Thanks.
    Crewmax or Double Cab?
    Crewmax
    .00191 MF and 75% residual
    SETF doesn't offer 24 month term.
    Would it also be possible to get Limited numbers?
    72% residual
    Hi, have the money factors and residuals changed for August for SETF (28117)?
  • kyfdxkyfdx Moderator Posts: 276,051
    ejc770 said:
    ejc770 said:
    Crewmax
    72% residual
    Same as last month
  • HotshotHotshot Member Posts: 69
    Did you get numbers for trd pro this month? 24/7.5 and 36/7.5 any incentives for 11218. Thanks
    Sorry, we didn't
  • statsloverstatslover Member Posts: 15
    Hi Michael,
    Could you please provide the numbers for
    36/10 and 36/12
    Hi Michael,
    36/10 and 36/12
    .00235 MF and 74% residual
  • TrdsjhTrdsjh Member Posts: 4
    Zip 01532
    Zip 01532
    .00235 MF and 70% residual
  • The_SheepdogThe_Sheepdog Member Posts: 98
    Could someone share the Money Factor (MF), Residual Value (RV) & any incentives that would be involved with the following car:
    2022 Toyota Tundra 4WD Capstone Hybrid
    Lease Length: 36 Months
    Mileage: 15K
    Zip Code: 21401
    Thank you in advance!
  • F3_La_Z_BoyF3_La_Z_Boy Member Posts: 14
    It looks like SETF has better Money Factor rates... Is that accurate? Are all states that are included in the SEFT southeast region (AL, FL, GA, NC, & SC) the same, in terms of MF, or do they still vary by zip?
    Mileage: 15K
    Zip Code: 21401
    .00235 MF and 62% residual
    Yes, SETF numbers are the same in all 5 states.
    You can't really depend on the residuals, though. SETF tends to have MRMs, which restrict the residual amount to a maximum number, regardless of how high the MSRP might be. On a low-optioned model, the numbers might be better, but they tend to get much worse, as the MSRP goes up.
    Gotcha. In that case, can you provide the SETF MF and Res for a Limited and SR5, crew max, 4x4, 36/12?
    .00191 MF
    75% SR5
    72% LTD
  • jeffreyb23jeffreyb23 Member Posts: 21
    Could you please provide the MF/RV for the following?:
    Limited and Platinum, 4x4, Crew max, short bed| 36/12 | 14580
    Also, what does the MF drop to for single pay lease?
    Thank you, in advance!
    .00235 MF
    72%/70% residual for LTD/Plat
    No info on the single pay discount
  • Drumbum00Drumbum00 Member Posts: 1
    can i get mf and res on a 22 tundra sr5 4x4 crewmax 5.5ft bed
    36/12 zip:32824
    36/12 zip:32824
    MN resident, buying in IA. Is dealer marking up MF from .00235?
    2022 SR5 Crewmax 5.5'
    .00265 (was told this is with Tier 1+ credit and using my 810+ score)
    It's possible that the base MF is .00265, but we don't have any documentation to prove it.
    Shop other dealers and see if you get the same answer.
  • laelorenlaeloren Member Posts: 40
    Hi Michael,
    SR5 crewcab, 5.5ft box, 4x4, in 43606
    36/10 and 36/12
    laeloren said:
    Hi Michael,
    36/10 and 36/12
    .00235 and 74%
    @CPATT_014 -
    We do not allow solicitation on our forums. You are free to post questions that will help our members, but I have deleted your post.
  • CPATT_014CPATT_014 Member Posts: 1
    BUT YOU CAN GIVE OUT LEASE INFORMATION?
    Correct. We aren't dealers or salespeople.
  • randyjstarkrandyjstark Member Posts: 99
    Looking for #s for zip 28516\
    2022 Tundra SR Crewmax 5.5ft bed - 4x2 and 4x4
    2022 Tundra SR DoubleCab 5.5ft bed - 4x2 and 4x4
    24, 30 and 36 mo term
    12k/yr
    MR and residual please, TIA!
    12k/yr
    Only 36 month term supported for SETF.
    .00191 MF
    Crew - 85% / 81% for 4x4 / 4x2
    Dbl - 80% / 77%
    Thank you Michael! What about the SR5 version, are the residuals and MF the same? It's hard finding available SR's on the dealer lots right now...
    Crew 75%/74% residual
    Double 73%/71% residual
    .00191 MF
    Wow big difference, thank you! Hoping to find a SR to keep my payment low...
  • zunairsharifzunairsharif Member Posts: 144
    Hi can i get TRD Pro Tundra RV MF, thanks.
    24mo/10k and 36mo/10k, zip 11001, TFS.
  • MauriceDominickMauriceDominick Member Posts: 2
    2022 Tundra SR5 Crewmax 5.5ft bed - 4x2 and 4x4
    36/12k/yr
    MF/RV
    Zip: 78754
    Thank you kindly.
    36/12k/yr
    MF/RV
    Zip: 78754
    Thank you kindly.
    .00235 MF
    73% 4x2
    74% 4x4
    That's the Hybrid, right?
    .00235 MF
    24/12: 78% residual
    36/10: 73% residual
  • NappytimeNappytime Member Posts: 6
    Hi. Looking for the RV/MF and any current or upcoming lease deals on a 2022 Tundra Limited CrewMax 4x2. 36 months. 12k miles. Houston, TX 77080. Thanks!
    .00235 MF and 70% rv
  • NatostarrNatostarr Member Posts: 17
    Can I get the RV/MF for a 2022 Tundra SR5 Crewmax 4x4. 36 and 24 months. 10k miles. 92008. Thank you!
    .00235 MF
    24/12: 80% residual
    36/10: 75% residual
  • latitude18latitude18 Member Posts: 29
    Hello
    Can I get the RV/MF for a 2022 Tundra hybrid capstone 4x4. 36 and 24 months. 10k miles. 16059. Thank you!
    Hello
    .00235 MF
    70% 24/12
    65% 36/10
    Good morning Michael,
    I found a vehicle, but my DL is not yet updated to the South so it looks like the dealer needs to put the vehicle in my PA address... Looking for #s for zip 18618
    36mo 12k/yr
    thanks in advance!
    36mo 12k/yr
    thanks in advance!
    .00235 MF and 75% residual
    ejc770 said:
    ejc770 said:
    Crewmax
    72% residual
    Same as last month
    Hi, have the numbers changed for September?
    ejc770 said:
    ejc770 said:
    ejc770 said:
    Crewmax
    72% residual
    Same as last month
    New Toyota programs will be released tomorrow.
    Ask again, then.
  • jaxondaneljaxondanel Member Posts: 13
    When they’re available - can I please get the MF/RV for a Tundra TRD Pro in 91325. Thank you!
    ejc770 said:
    ejc770 said:
    ejc770 said:
    Crewmax
    72% residual
    Same as last month
    Ask again, then.
    Hi, can I get numbers for 36/12 for Tundra SR5 4x4 crewmax in 28117. Thanks.
  • ct1127ct1127 Member Posts: 15
    Can I get September numbers (when available) for 85743 for 36/12, 30/12 on:
    Tundra TRD Pro 4x4 crew
    Tundra Platinum 4x4 crew
    Thanks in advance.
    ejc770 said:
    ejc770 said:
    ejc770 said:
    ejc770 said:
    Crewmax
    72% residual
    Same as last month
    Ask again, then.
    .00252 MF and 76% residual
