2022 Chevrolet Equinox Lease Deals and Prices
124
    NC95 said:
    Hello can you please provide MF/Residual/Incentives for zip code 10308.
    2022 Chevy Equinox LT AWD 36/10k
    2022 Chevy Equinox RS AWD 36/10k
    Does adding packages change the rates? such as CONFIDENCE & CONVENIENCE PACKAGE and ADVANCED SAFETY PACKAGE and INFOTAINMENT PACKAGE?
    .00077 MF and 60% residual
    .00028 MF and 56% residual
    Option/packages have no effect
  • MJOPMJOP Member Posts: 42
    Can I please get the MF, residual and any incentives for 2022 CHEVROLET Equinox FWD LT for 24 mo / 10k miles in 30306.
    I do have an existing competitive lease as well - looks like that is $1000 incentive.
    .00048 and 69%
    Confirm $1000 conquest
  • RustyshacklefordRustyshackleford Member Posts: 10
    Can I get numbers for a premier 24/10 and 36/10? Zip is 33914.
    Also do the number vary for the LT trims (2LT, 3LT) or is it the same for any LT trim?
    I don't see a 2LT or 3LT for the Equinox; just 1LT and 2FL.
    Premier
    .00059 and 65%
    .00060 and 56%
  • lamber12lamber12 Member Posts: 37
    edited August 2022
    Could you tell me the numbers for 36/15k and 39/15k for LT and Premier in FWD in zip 77077?
    Thanks for all your help!
    LT - .00108 and 57% / 53%
    Prem - .00060 and 53% / 51%
    Thanks, the MF for the LT seems much higher than the other/prior numbers. Could you please tell me the MF and Res for 36/12 instead for LT FWD?
    Same numbers for either drive.
    Add 2% to residual for 12K allowance
  • gregw5gregw5 Member Posts: 112
    edited August 2022
    If you would be so kind to post Equinox RS AWD lease numbers in 48331.
    24/10k
    36/10k
    Thank you in advance.
    24/10k
    36/10k
    .00059 and 65%
    .00060 and 56%
  • frank1210frank1210 Member Posts: 4
    May I please get the numbers for a
    2022 Equinox LT FWD & RS FWD for
    24/10k & 36/10k.
    Zip code is 48312. Thanks
    24/10k & 36/10k.
    LT
    .00048 MF and 69% RV
    .00108 MF and 60% RV
    RS
    .00059 MF and 65% RV
    .00060 MF and 56% RV
  • es5653es5653 Member Posts: 40
    Could you please provide the numbers for LS FWD & AWD, LT FWD & AWD, for 24/10 in 51534? Thanks!
    .00048 MF and 69% residual
    For all
  • DayoOduDayoOdu Member Posts: 1
    Money factor, residual and any incentives for ‘22 Equinox Premier 36 months, 15k Miles at 11003 zip please. Thank you!
    .00083 MF and 53% residual
  • f8lmindzf8lmindz Member Posts: 7
    Hi, can anyone please provide RV, MF and incentives for
    2022 chevy equinox lt awd
    3y / 12k
    Zip 11746
    Ty!!
    3y / 12k
    Zip 11746
    Ty!!
    .00131 MF and 59% RV
  • hfuchs19hfuchs19 Member Posts: 12
    Can you please provide RV, MF, and incentives for
    2022 Chevy Premier FWD
    36 / 10
    Zip 33401
    36 / 10
    Zip 33401
    .00083 MF and 56% residual
  • EagleoneEagleone Member Posts: 10
    2022 Chevy Premier AWD
    36 / 10
    Zip 10314
    36 / 10
    Zip 10314
    .00083 MF and 56% RV
  • TheNorthTheNorth Member Posts: 57
    Could I please get the MF and RV with any incentives for a 2022 CHEVROLET EQUINOX PremierFWD in 93420 for:
    24/15
    24/15
    .00081 and 63%
    .00083 and 53%
  • constantinopleconstantinople Member Posts: 10
    2022 Equinox AWD LT
    MF and incentives for…
    65201
    2022 Equinox AWD LT
    65201
    .00131 MF and 59% residual
  • Finfan72Finfan72 Member Posts: 3
    May I please have the residual, MF and incentives for 2022 Chevy Equinox RS AWD 36/12 for 08759. Thank you in advance.
    .00083 MF and 55% residual
  • OutbackjtOutbackjt Member Posts: 16
    Hi, can I please have the RV, MF, incentives, for a 2022 Equinox AWF RS 36/12k 45011
    .00083 MF and 55% RV
  • stevegrazianostevegraziano Member Posts: 64
    Can you provide mf and residual for Chevy Equinox LS in 02038 for 12k/36?
    Thank you! Could you also provide the same for the 2022 Equinox LT AWD in 02038? 36/12 and 36/10?
    Same as LS above
  • TeaBoneTeaBone Member Posts: 1
    MF + RESDIDUAL for 2022 CHEVROLET EQUINOX
    FWD LT. 91040 zip code 36/10
    .00131 MF and 60% residual
  • FrancisFKKFrancisFKK Member Posts: 10
    edited September 2022
    Would sincerely appreciate the MF, Residual and Incentives for a 2022 Equinox 2WD Premier AT, zip 48092
    .00131 MF and 57% residual
  • Crad4Crad4 Member Posts: 42
    May I please have the MF and residual value for a 2022 Equinox LT AWD 36 months 12k miles?
    07065
    07065
    .00131 and 59%
  • JenlouJenlou Member Posts: 1
    Can I please have the MF and residual value for a 2022 Equinox LT FWD 24/10 and 36/10 zip 23434.
    .00070 MF and 69% residual
    May I please have the residual and MF for a 2022 Equinox LT with 24 months 10k miles?
    AWD and FWD?
    07066
    AWD and FWD?
    07066
    Either drive
  • Mercadocapital1Mercadocapital1 Member Posts: 24
    Hello, can you please provide RV and MF for 2023 Equinox, RS, 3 Years, 10k miles per year, 48823
    2023 Equinox discussion is now open!
  • DbiancoDbianco Member Posts: 2
    Can I please have the MF, residual and any incentives for 2022 CHEVROLET Equinox FWD LT for 24 mo / 10k miles in 07302?
  • mariaji2013mariaji2013 Member Posts: 4
    Can I please have the MF, residual and any incentives (inc. for current lease cust.) for 2022 CHEVROLET Equinox FWD LT for 24 mo / 10k miles in 14120? thanx
