...at 6-7pm Pacific/9-10 pm Eastern. Hope to see you there!
http://www.edmunds.com/chat/subaruchat.html
And 40 STi's is just insane :P
At least they will be testing one publicly using the Forester as the test vehicle.
Bob
http://www.ita.doc.gov/td/auto/cafenhtsa.html
"49 U.S.C. 32912(b) imposes a civil penalty of $5.50 for each tenth of a mpg by which a manufacturer's CAFE level falls short of the standard, multiplied by the total number of passenger automobiles or light trucks produced by the manufacturer in that model year. Credits earned for exceeding the standard in any of the three model years immediately prior to or subsequent to the model years in question can be used to offset the penalty"
Thanks for the info.
I don't know about the rest of the folks on this board, but I doubt I would purchase an STi, even if I could afford it. The WRX and/or a hot Legacy... now that's different story.
Bob
-mike
Bob
Provided the hot Legacy isn't more than $30k (around $25k?), I'll be first in SE Wisconsin to get one.
-Brian
-mike
Jim
Jim
Bob
$27-28k tops. It'll sell fine right about there.
-Brian
Surely you realize that Japanese market only B4 is a 260HP twin turbo 2.0L that (unsurprisingly) makes more low-end torque than the WRX's single turbo but slightly less peak power.
Carrying over the same power and trim level can't be done for $27k-- no way, no how. Low to mid 30s at best.
-Colin
Jim
After thinking about it a bit more, it probably will be in the $29-30k range. I'm basing this on the fact that the Impreza RS is MSRP at about $20k and the WRX is MSRP at $25k-ish. If we do that math on a Legacy GT Limited at $24.5k, then the 'hot' Legacy would be about $29-30k. $31k tops. I just can't see Subaru asking more than that for it. They'd be crazy to do so. Pricing them at $29-30k would have them selling lot hot cakes.
You really think people would be lined up to by a mid-size performance sedan at $40K? From Subaru?!?!?
-Brian
Volswagen did it very successfully by upping their pricing! They have a small car (Jetta) at a premium price. Why not Subaru? I do agree that Subaru is not quite up to the quality of the various German assembled marques, however, if Subaru can do something about their styling, they should be able to get the premium pricing.
Is it not any manufacturer's goal to get the most money for the least investment?
Daniel
Now all I need to know is how many HP is 207Kw???
Rolls/Bentley apparently has a pretty bad problem with the CAFE standards, but not with the Gas-Guzzler tax. Apparently, there's a weight maximum for the G-G tax, so things like furniture trucks and school busses aren't taxed. Since the Rolls (and I assume Bentley) weigh more than 6,000 pounds, they are exempt from the G-G tax.
Think about that. MORE THAN SIX THOUSAND POUNDS! Three tons. Talk about a smooth ride!
This may be old info, but I got it from a P.J. O'Rourke article on driving some of the most expensive cars.
They are definitely paranoid and biased towards the Volvo set, but if you read between the lines, they are one of the better sources for real information on the cars we drive.
Also, as I understand it, a taller gear may not necessarily improve your mileage. You engine's torque peak is where it runs most efficiently, at any throttle setting. To produce the most energy for the least gas, gear your motor so that your average speed in top gear is right around the torque peak. Smaller displacement cars (read: VTEC) have pretty strange torque curves, and may respond poorly to a taller gear.
Of course, if the posts are any guideline, we all drive faster than the speed limit, and may actually benefit from taller gearing....
then I think 207Kw = 297hp
If the math is right... WOW!
-mike
The efficiency you're talking about is true, but its not enough to offset the higher RPMs. In other words, at 5000 RPMs vs. 2500, you may not be using twice the gas, but you are using maybe 1.7 times as much. The efficiency has gone up, but its still sucking more fuel than at the lower RPMs.
Bob
• The middle rear headrest is smaller, not unlike that of the new Impreza.
• The radio antenna is now in the rear quarter glass (rear window on sedans), like the Forester.
• There is indeed a lit ignition key this year.
• Both front cup holders are now in the console, next to the handbrake. The heated seat switches have been moved slightly, and the console has been redesigned to accommodate these changes. There is no longer a pop-out cupholder on the dash.
• All white Outbacks have the pearl white. I think(?) white is no linger available on the Legacy models. They are now offered a silver instead.
• Regatta Red on the Outbacks is georgous! With the gold cladding it just looks fantastic. It's my favorite color combo.
Bob
The NZ website says the AT has some sort of fingertip selection, is that some sort of Sube Tiptronic??
Bob
Bob
Damned spell checker....
-mike
Too bad they can't team up with Acura and make a TL AWD. A TL type B4 anyone?
-Brian
Drew
-mike
I'll take my B4 in dark blue or dark green, beige interior, thankyouverymuch :-)
Cheers,
-wdb
(Whose '00 Legacy GT will be fully paid off by the time the B4 arrives heeheehee!)
They should also offer their customers "Reverse Option".
i.e. Standard Equipment: Leather, Upgrade Stereo, Moon Roof, etc... Give the customer the option of saying "I'll take it without Leather, Moon Roof, etc..."
Patti - How's that for really tuning in to the customers?
-mike
Agree with you on the "so all-inclusive"; however, the way the Subaru is equipped and priced, especially the VDC, I think the "Reverse Option" approach could help with Sales (more attainable) thereby offseting cost, if any, without creating another tier of model line (more badging - can't imagine "Outback H6 VDC Limited").
The only reason I wouldn't be buying the H6 Outbacks is because it doesn't come without sun/moon roofs - One sale lost there (I'm sure I'm not the only one).
If we the consumer have the option to elect not to have certain high priced standard offered can help improve Sales.
i.e. minus Sun/Moon Roof = Lower Purchase Price, hence more Wallet Friendly.
I think it is easier for a consumer to remove things they don't need and watch the purchase price go down versus adding options and watch the price go up.
I think the idea can fly, if "manipulated" right.
The price will depend on the packaging. I say get the base GT and add the turbos and better seats, that's it. The GT costs less than the Outback Limited, so the B4 should cost less than the LL Bean (never mind the VDC).
Wow, we're close on CAFE. Keep in mind it's not just $11 for the car you buy, it's $11 for ALL cars Subaru sells. So missing it by 0.2mpg would mean the fine would be roughly 1.9 MILLION DOLLARS! Ouch. Bye bye profits. Told ya CAFE was serious business.
VW has gone after Mercedes. They were peeved that Mercedes launched the A class to attack the Golf, so they are counter-punching. The fact that they are german helps in the US, but not in Brazil, where they are still a "cheap" brand. For Subaru it's the opposite. Too bad the US market is so much bigger.
Bob: sounds like you had a close look. I liked the trick cup holder, but it sounds like an improvement anyway. The lit keyhole should appear on all models.
-juice
-mike
Legacy platform: big block V8, V12 option
Forester platform: big block V8, low range
All with 5 speed automatics with manual shift control. Sound about right? ;-)
-juice
a bare-bones GT-B4 would do for me. Anything less than $30k keeps me hopeful that we could swing for one!
-Brian
Followd my uncle over the weekend listened to the dual exhaust note from the SVX, it's so sweet!
-mike
