2023 Toyota Corolla Cross Lease Deals and Purchase Prices
MichaellMichaell Moderator Posts: 270,923
edited December 2022 in Toyota
Ask your 2023 Corolla Cross lease and purchase questions here! Get information on money factors, residuals, incentives, deals, payments and prices. Post information on prices paid and discounts for purchases.
When making a request for lease information, please include the following information for the quickest response - body style, cab style (for trucks), trim level, RWD/FWD/AWD/4x2/4x4 (as appropriate), lease term, mileage allowance and your location.
«1
  • phillysunshinephillysunshine Member Posts: 59
    Can I have the MF, RV, Incentives for:
    2023 Toyota Cross LE, FWD/AWD
    36/12K
    Zipcode 19153
  • kyfdxkyfdx Moderator Posts: 276,036
    36/12K
    Zipcode 19153
    .00275 MF and 62% residual
    For all
  • kalcius17kalcius17 Member Posts: 5
    2023 Toyota Cross LE, AWD
    36/10K
    Zipcode 13760
    36/10K
    Zipcode 13760
    .00315 MF and 63% residual
  • dasgmgmdasgmgm Member Posts: 5
    Can I pls have RV, MF, Incentives for 2023 Corolla Cross LE and XLE, 36/12 and 24/12 for zipcode 32792
  • MichaellMichaell Moderator Posts: 270,923
    No 24 month term for your region
    .00228 MF
    68% RV
    Either trim
  • ticocarguy23ticocarguy23 Member Posts: 2
    Hi! Can I have the numbers for a 2023 Corolla Cross LE, 36/12 for zipcode 93065
    .00245 MF and 62% residual
    Either 36/12 or 39/12
  • xaropexarope Member Posts: 1
    Hello!
    Can I have the numbers for LE, 12k and 10k, 36mo for zip code 32819?
    The offer I have is for $269/mo with 3.6k down
    Also, would anyone know anything about the upcoming corolla cross hybrid?
    xarope said:
    Hello!
    .00236 MF and 67% residual
    No info on the hybrid version, this month.
  • AmirmohammadAmirmohammad Member Posts: 7
    Hi, could you please provide MF/RV info on 2023 Toyota Corolla Cross LE for 36/12K?
    Zipe code: 77074
    Zipe code: 77074
    .00225 MF and 61% RV
  • AFFB57AFFB57 Member Posts: 3
    Can I please have RV, MF, & Incentives for 2023 Corolla Cross LE and XLE, 36/12 and 24/12 for zipcode 33178?
    Thanks in advance.
    Thanks in advance.
    Only 36/12 term supported
    FWD or AWD?
    both please. Thanks
    edited May 2023
    Thanks in advance.
    AFFB57 said:
    both please. Thanks
    .00236 MF
    67% LE FWD
    66% LE AWD
    66% XLE FWD
    67% XLE AWD
  • arslanqadeerarslanqadeer Member Posts: 2
    Hi There,
    Can I please have MF, RV, and selling price for the month of May with the following:
    - 2023 Corolla Cross Base Trim with FWD
    - 36 months and 10K miles annually
    - Zip code 11214 (but I'm open to going for other nearby dealers if a good deal is available)
    Thanks for your help in advance!
    Hi There,
  • gregw5gregw5 Member Posts: 113
    Requesting Money-factor and residual value for 2023 Corolla Cross XLE AWD in 48390: 24/10k miles per year. If 24mos isnt available then 36mos / 10k.
    .00225 MF
    24/12: 66% residual
    36/10: 61% residual
  • MiteyJoeMiteyJoe Member Posts: 28
    Can I have the MF, RV, and Incentives for:
    2023 Toyota Corolla Cross Hybrid SE AWD
    36/10K
    Zipcode 19342
    36/10K
    Zipcode 19342
    .00225 and 63%
  • ajapmaxajapmax Member Posts: 6
    Hi There,
    Can I please have RV, MF, & Any Incentives for 2023 Corolla Cross Hybrid XSE, 36/12 for zipcode 90041
    Thanks in advance.
    ajapmax said:
    Hi There,
    Thanks in advance.
    .00225 MF and 62% RV
  • MaayanMaayan Member Posts: 1
    Requesting MF and RV and any incentives for Toyota Corolla cross 2023
    AWD all trims if possible
    36/12k and 36/15k
    Zip code 07205
    Thanks in advance
    36/12k and 36/15k
    Zip code 07205
    Thanks in advance
    .00225 MF and 58% RV
    All trims
  • ryfriryfri Member Posts: 32
    Can I please have the RV, MF, and any incentives for the 2023 Corolla Cross LE and XLE trims (fwd in both) for zipcode 33209? Thank you!
    36/12,000, thanks
    ryfri said:
    36/12,000, thanks
    .00236 MF
    67% and 66% residual, respectively
  • Craw316Craw316 Member Posts: 19
    May I please get the 36/12 numbers (money factor and residual) in Zip 13021 for the Corolla Cross XLE
    .00245 MF and 59% residual
  • jposeyjposey Member Posts: 5
    2023 Toyota Corolla Cross Hybrid SE, AWD
    36/12K
    Zipcode 53711
    36/12K
    Zipcode 53711
    .00245 MF and 61% RV
  • Ms7979Ms7979 Member Posts: 4
    Can you please provide the MF and RV of the 2023 Corolla Cross LE and XLE AWD? 12k/36mo
    Zipcode: 07070
    Zipcode: 07070
    .00245 MF and 59% RV
    Either trim
  • kidnopartskidnoparts Member Posts: 5
    Hi there, could I have mf/rv for 2023 corolla cross L:
    both awd and fwd
    both 12k/36 and 12k/24 - zip 06226.
    Thank you in advance.
    both awd and fwd
    .00245 MF
    65% / 59% RV for 24/36 and 12K
    Either drive
  • Rich2713Rich2713 Member Posts: 5
    edited July 2023
    Hello, would you be so kind to provide me with the MF/RV:
    2023 Corolla Cross XSE & XLE
    AWD Only
    24/36
    10K/12K
    83815
    AWD Only
    24/36
    10K/12K
    83815
    .00245 MF
    65% 24/12
    59% 36/12
    All trims
    (though, I don't see an XSE trim for the gas model)
    AWD Only
    24/36
    10K/12K
    83815
    .00245 MF
    65% 24/12
    59% 36/12
    All trims
    Sorry, the XSE is the Hybrid model top trim, was curious if the Hybrids have better rates than the gas models. I assume same MF/RV as the other trims you provided? Thanks!
    AWD Only
    24/36
    10K/12K
    83815
    .00245 MF
    65% 24/12
    59% 36/12
    All trims
    Hybrid
    Same MF
    67% 24/12
    61% 36/12
    All trims
  • tfgfxtfgfx Member Posts: 7
    edited July 2023
    Can I have the MF and RV of a 2023 Corolla Cross L FWD? zip code: 33004 (24/12 & 36/12) Much Appreciated!
    36 month only
    .00236 MF and 66% residual
    Why is it only a 36 month lease? If its the trim then can I get the MF and RV for an LE (24/12)?
    The 24 month term is not supported for any Toyota in the SouthEast region.
  • PHILJPHILJ Member Posts: 6
    edited August 2023
    Hello. If you've got a few seconds, could I get the MF and RV for Corolla Cross Hybrid XSE 36/10000-12000 in 44255. Thank you very much!
    .00245 MF and 61% residual
  • Jlozan834Jlozan834 Member Posts: 6
    Hello, can I please get mf/tv on Corolla cross 2023 xle and 12k/36 zip code 98802
