2023 Toyota Prius Lease Deals and Prices
kyfdxkyfdx Moderator Posts: 275,734
edited March 2023 in Toyota
Ask your 2023 Prius lease questions here! Get info about prices, money factor, deals, incentives, and payments.
«13
  • sanegreddysanegreddy Member Posts: 16
    Hello! Can I please get the numbers for LE and XLE 36/12? Thanks!
  • kyfdxkyfdx Moderator Posts: 275,734
    What is your location?
    I'm on a roll today...lol 33619
    .00315 MF
    66%/62% residual for LE/XLE
    Could I get the numbers for an LE at 33619 but for 36/10? Thanks!
  • MichaellMichaell Moderator Posts: 270,853
    SouthEast Toyota Finance does not offer a 10K allowance for leases.
  • ASTWASTW Member Posts: 14
    Hello!
    Can I please get the residual value and the money factor (excellent credit) for LE, AWD for term 36/10K? Also any incentive/rebate? Thanks!
    Zip code: 97035
    ASTW said:
    Hello!
    Zip code: 97035
    .00225 MF and 63% residual
  • Wild2023Wild2023 Member Posts: 8
    MF/RV/incentives
    07027
    LE/XLE/Limited
    36k/10
    Wild2023 said:
    MF/RV/incentives
    07027
    LE/XLE/Limited
    36k/10
    .00225 MF
    63%/61%/58%
  • MichaelG_4MichaelG_4 Member Posts: 3
    Hi could you please provide money factor and residual value for 2023 LE in zip 92835?
    Thanks very much
    Thanks very much
    .00225 MF and 60% RV
    Hi, sorry, for MF and RV for 2023 LE in 92835; is this any different for 36/10?
    63%
  • ryanw126ryanw126 Member Posts: 18
    Hey! Can I get MF/RV/Incentives for 2023 Toyota Prius Limited (FWD), 36/10 in 63119? Thank you in advance!
    .00225 MF and 58% residual
    Thanks @kyfdx! Just out of curiosity, why is the RV so low for my area?
    It's the same for almost every region in the country
    @kyfdx ah, so it's the Trim that affects the RV more than anything? I see higher RV's reported above for the lower trims. Sorry, just trying to learn.
    Yes, that's correct. Higher trim usually have a lower RV
  • Fire_Astronaut719Fire_Astronaut719 Member Posts: 5
    Interested in MF/Residual/Incentives for:
    2023 Prius AWD
    36 mo / 10k miles
    Zip code: 07026
    2023 Prius AWD
    36 mo / 10k miles
    Zip code: 07026
    What trim level?
  • ColinEnsleyColinEnsley Member Posts: 31
    I'm looking for MF and RV on a 2023 Prius Prime - XSE Premium. 36 months / 12K for zip 94523. Also, any incentives currently? Thank you!
    I do not see numbers for the Prius Prime for May.
    Are they available at the dealer yet?
    I'm going to look at one tomorrow - at the dealer. Will let you know what they quote me.
    If I were to guess, MF is .00315.
    Unfortunately, it was sold by the time I got there.
  • Haroldth3heraldHaroldth3herald Member Posts: 5
    RV and MF for Prius LE XLE
    Zip 90002
    Credit score 688
    Zip 90002
    Credit score 688
    .00225 MF
    63% LE
    61% XLE
    MF is for Tier 1+
    Add .00010 for Tier 1
    Add .00055 for Tier 2
    Add .00145 for Tier 3
    Zip 90002
    Credit score 688
    .00225 MF
    63% LE
    61% XLE
    MF is for Tier 1+
  • Huckster123Huckster123 Member Posts: 2
    Rv and mf for prius xle awd
    zip 82718
    please
    zip 82718
    please
    .00225 MF and 59% residual
  • Agricola123Agricola123 Member Posts: 5
    Can you please provide RV and MF for 90026, 10k miles:
    XLE (not AWD)
    Limited (not AWD)
    XLE (not AWD)
    Limited (not AWD)
    .00225 MF
    62%
    59% residual
  • HorizonUpHorizonUp Member Posts: 1
    Can you please provide RV and MF for 95407, 36mo/12k miles for
    Prius Prime SE
    Prius Prime SE
    .00315 MF and 65% residual
    But, check with a dealer, they may have special programs that we don't know about.
  • maisbassmaisbass Member Posts: 3
    edited June 2023
    Hello! Can I please get the RV and MF for Toyota Prius Prime LE and XLE 36/10?
    Zip code- 10312
    Credit score 800
    Zip code- 10312
    Credit score 800
    Those aren't Prime trims
    Ooops. I meant SE and XSE
    Zip code- 10312
    Credit score 800
    .00064 MF
    66%/64% residual for SE/XSE
    .00064 MF
  • ec1ec1 Member Posts: 80
    Can I get MF,residual, lease cash for a Prius Prime XSE and XSE Premium - 36/12 - zip 37027? Thanks,
  • doug63026doug63026 Member Posts: 31
    Hello! Can I please get the numbers for LE and XLE 36/12? ZIP 63026 Thanks!
  • exbauerexbauer Member Posts: 58
    Hello. Numbers for a Prius Prime XSE 36/12 12534 36/12 please. Thanks!
    .00245 MF
    62%/60% residual for LE/XLE
    .00315 MF and 62% residual
    .00315 MF
    62%/59% residual for XSE/XSEP
  • Npny1214Npny1214 Member Posts: 24
    Can I get MF, residual & incentives for a Prius Prime SE and XSE please? 36/10 zip 11787? Thanks
    .00315 MF
    65% and 63% residual
  • nochnoch Member Posts: 5
    hi
    can you please post MF and RV 2023 Prius LE. 36/12. zip is 94030. Thank you
