Rearview mirror ripped chunk out of windshield - how do I fix without replacing windshield
Josebaum7Josebaum7 Member Posts: 3
edited May 2023 in Mitsubishi
Last week while adjusting my rearview mirror it fell off the windshield with a chunk of the windshield attached. I am dumbfounded. I did not even pull that hard on it! Nonetheless, I have tried reattaching the rearview mirror plate with the chunk of glass still attached with glass glue twice, but the mirror falls off after a day or two. Looking for some cost-effective ideas. I would rather not have to replace my entire windshield.
  • kyfdxkyfdx Moderator Posts: 270,805
    First, check your state insurance regulations. Assuming you have comprehensive, some states require the replacement of glass with no deductible.
  • thecardoc3thecardoc3 Member Posts: 5,858
    The factory "dot matrix" tinting and especially the blotch with the cut-out of it for the mirror placement is a problem. Usually when this would happen on a regular windshield, we can just move the mirror anchor and bond it beside the damaged section of the glass. That tinting however is like the Teflon coating on a frying pan and resists adhesives sticking to it. There aren't any good or advisable ways to try to remove some of that tinting to make a place to remount the mirror. Your best approach unfortunately this time is to replace the windshield.
