2023 Jeep Wagoneer Lease Deals and Prices
245
  • gaflyer2gaflyer2 Member Posts: 46
    gaflyer2 said:
    Can I get the info for...
    2023 Wagoneer L Carbide - 32801 zip
    Whatever length has the lowest MF with 15k miles
    Also, can you prepurchase miles if you think you're gonna go over? How much per mile?
    4x2 or 4x4?
    4x2
  • MichaellMichaell Moderator Posts: 269,035
    ajsonnick said:
    ajsonnick said:
    ajsonnick said:
    Can I have MF and Residual on Grand Wagoneer Obsidian for
    ZIP 11747.
    10K/year
    Please provide whatever is available for the below:
    36 mo
    39 mo
    42 mo
    48 mo
    Series II or Series III?
    Obsidian is it's own class. No? Is it a Series II?
    My data shows an Obsidian trim for both Series II and III, with different lease numbers for each
    Series 2 please :)
    36/10 - .00225 and 51%
    39/10 - .00231 and 49%
    42/10 - .00232 and 48%
    That's going to be insanely expensive to lease ... you could get an Audi, BMW, or MB instead.
  • ajsonnickajsonnick Member Posts: 36
    ajsonnick said:
    ajsonnick said:
    ZIP 11747.
    10K/year
    36 mo
    39 mo
    42 mo
    48 mo
    Series 2 please :)
    Thank you! I know I agree. I have a grand wagoneer lease coming due soon and I really like the vehicle, but it's too expensive, so I thought a Wag might be better
    ajsonnick said:
    ajsonnick said:
    ajsonnick said:
    ZIP 11747.
    10K/year
    36 mo
    39 mo
    42 mo
    48 mo
    Series 2 please :)
    Hold up ... your initial request was for a Grand Wagoneer Obsidian.
    You wanted the Plebian Wagoneer?
  • sonn426sonn426 Member Posts: 1
    Hi there! Could I have a lease MF and Residual on a Wagoneer L Series II Carbide for Zip 18403.
    42 mo / 10k
    36 mo / 10k
    42 mo / 10k
    36 mo / 10k
    4x2 or 4x4?
    4x2 or 4x4?
    4x2
    Can I please get an answer to this one?
  • kyfdxkyfdx Moderator Posts: 272,648
    4x2 or 4x4?
    4x2
    .00329 MF and 58% residual
    Yes, you can pre-purchase miles, but we don't know the cost per mile.
  • limepopsiclelimepopsicle Member Posts: 10
    Hello, looking for the MF and residual on 2023 Wagoneer Base and Series II 4x4 for 36/12k. Zip is 33544, thank you
    Base = Series I?
    If so, .00290 and 65%
    For Series II, only the 42 month term is supported - .00356 and 57%
  • jlo1979jlo1979 Member Posts: 4
    Hi, can I get the MF and residual for a Wagoneer Series 3 4WD in 46074. 10k miles and 36 and 42 months? Thanks
    .00310 MF and 58% residual
    .00318 MF and 54% residual
  • oc181oc181 Member Posts: 1
    Can I have MF and Res for Grand Wagoneer series II obsidian 4x4
    42 mo/10k - Zip would be 19044. thank you so much!
    .00272 MF and 50% RV
  • eoneal007eoneal007 Member Posts: 25
    Hi. Can I get the MF and Residual for a 2023 Wagoneer 4x4 in zip 18902 for 36mo/12kmi?
    That is all the Sticker says vertabim: "2023 Wagoneer 4x4". No Series or anything. This is with the new I6 engine in transit to the dealer. Sticker is 69,992, so my guess is base or Series I
    Series 1 4X4
    .00290 MF and 65% residual
  • HomeStarRunHomeStarRun Member Posts: 6
    Hi - Can I get MF and Res for 2023 Grand Wagoneer 4x4 Series 3 02895
    .00190 MF and 49% residual
  • EncierroEncierro Member Posts: 7
    Wondering if there are any updates for the 2023 Wagoneer Series II 4x4 for 24 and 36 months/ 15k in zip 77008 (MF, Residual, and incentives ). Dealer said residual would be .75 & .67,
    July programs will be released on 7/6.
    Ask again, then.
    Ask again, then.
    Thank you, headed to pick up the car today. So just wondering if that sounded correct as previously the residual has been a lot lower. So wondering what is currently.
    Ask again, then.
    The only term that is supported for the Wagoneer this month is 42 months.
    42/15 = .00356 and 55%
    It's possible your dealer is using a different bank.
    Ask again, then.
    We only have Chrysler Capital programs. With those residuals, the dealer would have to be using an alternative bank
    Ask again, then.
    Correct, they were, in the end didn't lease, as it added quite a bit (like 20%) if we decide to keep it. Thank Michaell for the help.
  • jamesy7jamesy7 Member Posts: 9
    Hi! Can I please have the mf, residual, and incentives for a Wagoneer 4x4 series II and III for 24/36 15k in 80906?
    Thanks in advance
    Thanks in advance
    No 24 month term supported on the Wagoneer.
    II
    27/15 - .00360 MF and 64% residual
    36/15 - .00343 MF and 58% residual
    III
    .00303 and 60%
    .00297 and 54%
  • erooseeroose Member Posts: 15
    edited July 2023
    Looking for MF RV etc for 2023 Series II Wagoneer 4x4 zip 19087. 36/15 or 42/15
    .00352 MF and 54% residual
  • bneta86bneta86 Member Posts: 1
    Went to get a 23 Wagoneer Carbide L 4x4 but they didnt have any, and couldnt order a 23. They offered to order a 24, but I couldnt get any lease information because he estimated 12 weeks to build.
    Is the build timeframe realistic? I suspect expensive to lease on 24s but I dont have any indication. They wanted me to reserve it and order it, but I hadnt seen any context on new packages, options, etc on the 24s.
    And there likely won't be any programs, until the units start to arrive at the dealer.
    You sure there isn't something comparable that you could lease instead?
  • PSK4PSK4 Member Posts: 11
    Can I have MF and Residual on Grand Wagoneer 4x4, Series 1 & Series 2 for
    ZIP 07631.
    10K/year
    36 mo
    39 mo
    42 mo
    Thanks so much
    ZIP 07631.
    10K/year
    36 mo
    39 mo
    42 mo
    Thanks so much
    Series I
    .00233 and 53%
    .00239 and 51%
    .00240 and 50%
    Series II
    .00250 and 52%
    .00256 and 50%
    .00257 and 49%
    4x2 or 4x4?
    4x2
    Can I get an update for August? Vehicle just shipped from the factory.
    Wagoneer L Series 2 Carbide 2WD (32801 zip) - Which term has the best support? Just trying to see if a lease followed by a purchase down the road makes more sense than a purchase right off the bat.
    4x2 or 4x4?
    4x2
    .00295 MF and 57% residual
    4x2 or 4x4?
    4x2
    This is for 36/15?
    4x2 or 4x4?
    4x2
    This is for 36/15?
    Yes
    Hi, what's the MF and residual for w Wagoneer Series II 4x4 in 46032
    36/10 or 7.5 if there is one.
    39/10
    39/10
    .00321 MF and 61% residual
    .00329 MF and 59% residual
    Chrysler Capital doesn't offer 7.5K/yr
  • cmillie93cmillie93 Member Posts: 13
    What is the residual & MF for a Wagoneer L Carbide and Wagoneer L Series II?
    Both 36/12K
    Both 36/12K
    What is your location?
  • sagostosagosto Member Posts: 8
    Lease details for Wagoneer Series 2 AWD (10K and 12K per year miles) for 07430. I can buy outright but Wagoneers are losing a ton of value. Thanks.
    .00321 MF and 60% residual
    Zip 68116. Also - would you happen to have a ballpark of factory invoice or how much below MSRP factory invoice might be?
    Both 36/12K
    4x2 or 4x4?
    4x2 or 4x4?
    4x4, thank you.
    Both 36/12K
    4x2 or 4x4?
    cmillie93 said:
    4x2 or 4x4?
    4x4, thank you.
    .00284 MF and 59% RV
    Either trim
    Hi!
    Series I 4x4 and Series II 4x4
    39mo/10k, 42mo/10k & 48mo/10k
    Zip: 07631
    MF, RV, any incentives?
    Thanks!!
    PSK4 said:
    Hi!
    Zip: 07631
    Thanks!!
    Series I
    39/10: .00233 MF and 61% residual
    42/10: .00232 MF and 59% residual
    Series II
    .00329 MF and 57% residual
  • Castroj88Castroj88 Member Posts: 4
    Hello!
    MF and RV on 23 Wagoneer Series II 4x2 and Series II Carbide 4x2. 32724. Any incentives?
    Castroj88 said:
    Hello!
