Visitor Agreement.
https://www.schultzford.net/new-inventory/index.htm?status=1-1&model=Maverick
I would bet that a lot of those are a fleet order. seems suspicious that most of them are white XL models.
Good deals though at sticker, if you don't need all the bells and whistles!
also got the Acura title in the mail yesterday. A NJ title, so trying to get ahold of someone at NY DMV to confirm I need to take that in to get exchanged.
How many of those are you working on?
Yikes, for a while there that dealer almost sounded like Henry Ford…you can have any color you want as long as it’s Oxford White.
Our resident Maverick guru (@stickguy) called that one.
Some definitely leave sold vehicles on there until there is an inquiry.
Also, sometimes the price changes once there is an once info is requested.
Has happened to me several times.
https://www.windowsticker.forddirect.com/windowsticker.pdf?token=iBh0uZl7h5IGqjZdAqy2qK1S6YMP2ABtkWr34Q3Pzx2/kVSpZYjOr6lTkEqpEm6J5qRuPf2DrC1U9rZzsTWLZeVNDCJufWE62bcqfqrXhXd6YjMK9tS/au9fyFd5WaBCElxheZi0C/2muwfGFtoUj/JyUPB0uC3gGasFOqkq9KU=&cguid=SH-0ef918e1-55b5-19b9-0002-456453843069
I initially bought a Raspberry Pi Zero W board and case along with a software defined radio receiver and installed the DietPi command line Linux distribution (which was super easy to set up). Things ground to a halt when I discovered that the Zero W I purchased had only a 32-bit processor, and the flight tracking setups appear to currently support only 64-bit hardware. The Pi Zero 2 W has a 64-bit chip, but is not readily available at its $15 retail price, nor are the newer full-fledged Raspberry Pi single board computers.
I ordered a Libre Le Potato, which has the same form factor as several of the Raspberry Pi boards, and a slightly different feature set, which arrived today. The first hurdle I encountered was that it won't run the official Raspbian OS, you have to download a compatible fork from Libre's website. Then I wondered why it wasn't connecting to my wifi, despite including my wifi settings in a configuration file, as instructed. Surprise fact which I had noticed a while back and promptly forgot: the Le Potato does not have onboard wifi. Luckily, I had a compatible "nano" USB wifi dongle in the parts bin which was compatible. Also, the case I ordered was for a Raspberry Pi 4 and doesn't properly fit the Le Potato, which has the form factor of the older full size RPi boards, so I've ordered the correct case and am returning the wrong one to Amazon.
However, the ADS-B feeders installed without much drama, and I'm extremely impressed with the range of reception--close to 100 miles in some cases, and that's with a mediocre antenna sitting next to a TV, computer, and monitor in the upstairs of my house, so there is also a roof, insulation, and walls attenuating the signal. I'm excited to try repositioning the antenna. Here are some screenshots of the built-in web server, which shows only the aircraft from which my box is receiving a signal:
Huh? Almost as clear as mud to me. What do you do for fun?
You might be able to find a bargain pickup at this type of auction.
I didn’t even understand that much. :'(
You're welcome.
And this one... what I don't understand is how he didn't know about the transport issue before reaching out in the first place. What would have happened had I accepted the first offer?
Will be interested to see how this Hyundai store turns out after the construction is over. The piece of land they're on isn't huge by any means and they also have a Genesis and Subaru store on the same property but in their own buildings. But, it is close for us, a big reason we buy there. So, we'll just see in a year or two when the new Kona is out for awhile. Hoping for 0% financing at that time as it would make my decision that much easier to make. Put a few grand on my credit card and pay the rest off at 0% and I'm good.
In the pictures, saw a nice dark grayish blue that looked really good on the vehicle. As much as I like a white pearl paint, their dark blue color captivated me and if can be had in a pearl finish, so much the better. A black interior is a no go for me, either make it gray or two tone like the Toyota I was in on Tuesday.
I would have been tempted to answer his first question with…”can you do 2000 tomorrow”?
My kind of fix!
Holy cow; that's a lot of air traffic in such a small area!
Great trouble-shooting to get it rolling, though.... and you were able to further justify the old parts bin's continued existence!
The oil leaks under the A3 have stopped since the last oil change it seems. Strange, but no longer finding any oil drops on the garage floor every few days. Not complaining by any means here, very happy to be honest. We're just doing our normal driving and things are going fine. Might bump up the oil change/rotation for the Golf by a month or two since I'm really not driving it much at all...more like more severe driving as I'm usually at my destination within 5 to 10 minutes whenever I use it. So bumping up the time frame a bit won't hurt it. Found a good coupon at a local place I've heard good things about which has been around for a long time so figure, hey, why not.
I took it for a short test drive for 20 minutes and it's solid - no rattles or anything. Goal for today is to get my son's seat into it and let him ride around for a bit - see how he does with it.
Exactly. I don’t get the change from the regular T5. I’m sure it gets around just fine as the T5 S60 I test drove at one point was more than adequate.
Good luck with your new ride. It’s alway satisfying when you buy a used car and its what you were hoping it would be.
I never knew a child’s car seat was meant for the drivers seat. I guess it doesn’t hurt to start them early. Let us know how he did.
My bad. I thought you bought the car. I never heard of test driving a used car for 24 hours before deciding if you want it. Especially a car that was shipped from out of state. If you decide you don’t want it and it has to be shipped back, who pays for the shipping?
Nah. But it was a couple hundred bucks. Nothing catastrophic if I say no.
I’m still very much on the fence about doing this, and what is to CarMax is to CarMax, I haven’t felt any pressure.
Pics or it isn’t happening…
Getting it ready for the afternoon pickup.
That car seat is cozy back there!
Gorgeous interior! Fingers crossed it works out for you.
