2023 Chevrolet Suburban Lease Deals and Prices
2»
  • Here_to_learnHere_to_learn Member Posts: 8
    Just following up, is there a different MF and Residual Value for a 2023 Suburban LT RWD w/ luxury package for a 36/12K lease?
    And what is the MF and Residual Value 2023 Suburban RST RWD for a 36/12K lease?
  • MichaellMichaell Moderator Posts: 259,840
    RWD and AWD have the same programs.
    RST - .00247 MF and 59% residual
  • PP2030PP2030 Member Posts: 3
    If you can kindly help me with the following:
    Residual, MF, and incentives on 2023 Suburban Z71 4x4 w/lux pkg; zip: 93722
    10k/yr 24 Mo
    10k/yr 36 Mo
    P
  • kyfdxkyfdx Moderator Posts: 262,003
    10k/yr 24 Mo
    10k/yr 36 Mo
    P
    .00370 MF and 72% residual
    .00247 MF and 60% residual
  • limepopsiclelimepopsicle Member Posts: 10
    Hello, can I get the MF and residual for a 2023 Suburban LT 4WD and Z71 4WD 36/12k in zip 33544. Thank you!
    LT - .00258 MF and 60% residual
    Z71 - .00247 MF and 59% residual
  • penn2penn2 Member Posts: 128
    Hi - evaluating a 36/10k lease in 19355(residence zip...but dealership is in 08401 if that matters?) for a Premier 4WD 5.3L. Seeking RV/MF. Looking at previous posts, seems the MF hasn't changed much past few months. Can your provide? and while it's anyone's guess , any sense if July would improve? Lastly, when will you have July #s avail? Thank you!
    .00247 MF and 60% RV
    Current GM programs run through the end of July.
  • cdeed50cdeed50 Member Posts: 47
    Looking for RV and Money Factor on the following
    -2023 Suburban 4WD LS 36/10k in 21754. Any incentives?
    -2023 Suburban 4WD RST 36/10k in 21754. Any incentives?
    Thanks!!
    Thanks!!
    .00227 and 64%
    .00247 and 60%
  • ZaidZaid Member Posts: 29
    Hi, can I plz get the MF and Residual for a 2023 RST AWD 36/12
    What is your location?
    94538 zip code
    Zaid said:
    94538 zip code
  • ahenri1ahenri1 Member Posts: 8
    Hi, can I get MF and RV for 2023 Suburban Z71 and Suburban High Country? 36 months/12k miles in zip 70124.
    Z71: .00247 MF and 59% residual
    HC: .00198 MF and 55% residual
  • aperture79aperture79 Member Posts: 2
    edited July 2023
    Hi! Can I have the MF and RV for a 2023 Suburban 4WD LT 36/12k in 44124. Any lease incentives? Thanks!
  • kdog1244kdog1244 Member Posts: 44
    edited September 2023
    2023 suburban LT and premier 36/10 and 36/12 4WD for 57108. Any incentives? Thank you!
    LT - .00258 and 60%
    Prem - .00247 and 59%
  • tatiyanatatiyana Member Posts: 15
    Hi can I get the MF and RV for 2023 Suburban RST 4WD
    10k & 12k for 36mo (or 39mo)
    Zip code: 08742
    Zip code: 08742
    .00247 MF
    59% / 57% for 36/39 and 12K
  • synthxoundsynthxound Member Posts: 1
    Hello looking for MF and RV for a 2023 Suburban LT 4WD w/ luxury package and w/out for 24/10 and 36/10K in 11725 area code? Any incentives? Thanks!
    .00384 MF and 74% RV
    .00258 MF and 61% RV
  • wkhokarwkhokar Member Posts: 42
    Hello - Can I get the MF, RV, for 2023 Premium Suburban for 36/15k, zip 22033?
    .00247 and 57%
  • blakecablakeca Member Posts: 11
    Good day. Can I please get the MF, RV and any incentives available for a '23 Suburban RST and Premier for a 36/12 36/15 lease for 58078?
    .00255 MF and 56% residual
    Either trim
  • 123ablack123ablack Member Posts: 77
    Hi, RV/MF for 2023 Suburban Premier 4WD
    • 36/10
    • 39/10
    • 48/10
      Zip 11219
      Any incentives?
    • 36/10
    • 39/10
    • 48/10
      Zip 11219
      Any incentives?
    .00255 and 59%
    .00255 and 57%
    .00269 and 49%
    .00255 and 59%
    .00255 and 57%
    .00269 and 49%
    Thank you so much @Michaell
    Do we have 2024 suburban numbers yet?
    Yep! Post here
  • kledeezykledeezy Member Posts: 37
    23 z71 suburban luxury package, MF and res 36/10 39/10 zip 92223
    .00255 MF
    59%/57% residual
  • rh04merh04me Member Posts: 50
    Hi can I please get the MF and residual for a 2023 suburban LS 4wd for whatever are the best terms…I’m guessing that is 39/10k in 46077.
    .00241 MF and 55% residual
    Could I also please get the MF and residual for a suburban LT 4wd for 39/10k in 46077
    .00264 MF and 54% residual
  • RribbRribb Member Posts: 3
    Looking for money factor/residual on 23 lt/premiere 2wd 39/10 in 33458
    LT: .00264 MF and 54% residual
    PRM: .00252 MF and 55% residual
    -2023 Suburban 4WD LT 36/10k in 21754. Thanks
    .00264 MF and 56% residual
