2023 Chevrolet Silverado Lease Deals and Prices
1679111214
  • kyfdxkyfdx Moderator Posts: 272,623
    Hi, could I get MF, RV, and incentives for a Silverado 1500 LT 2FL crew cab 4WD at 24/10, 36/10, and 39/10? Zip 48035. Thanks!
    .00247 MF and 77% residual
    .00194 MF and 70% residual
    .00194 MF and 68% residual
    $1500 customer incentive
  • Whitehulk552Whitehulk552 Member Posts: 28
    Hi, can I get the MF, RV and current incentives for a Silverado 1500 RST 4WD crew for both the 6.2 and the 5.3? Zip is 48329. 36/12. Thanks!
  • MichaellMichaell Moderator Posts: 268,879
    .00142 MF and 62% RV
    Either engine
  • Austinm13Austinm13 Member Posts: 12
    Hi, can I get the MF, RV and current incentives for a Silverado 1500 RST, LTZ and LT Trail Boss all with the 3.0 4WD crew? Zip is 76132. 36/12.
    RST - .00142 and 62%
    LTZ - .00169 and 63%
    LT TB - .00211 and 64%
  • theratkingtheratking Member Posts: 1
    Hello!
    Can I get the MF, RV, and current incentives for a Silverado 1500 Custom Double Cab 2.7L 2wd
    zip code 32536
    term 24mo 10k mileage
    Hello!
    zip code 32536
    .00259 MF and 73% RV
    $1000 incentive
  • sonora02sonora02 Member Posts: 209
    May I have MF, RV, and incentives for Silverado 1500 Crew Cab 4X2 zip 92123, 36/12
    Diesel/Gas
    RST
    LTZ
    Thanks in advance
    Diesel/Gas
    RST
    LTZ
    Thanks in advance
    .00142 MF and 62% residual
    .00169 MF and 63% residual
  • Timatc2324Timatc2324 Member Posts: 2
    Hi, can I get the MF, RV and current incentives for a Silverado 1500 RST, LTZ, and ZR2 all with the 6.2 4WD crew? Zip is 14086. 36/15 & 48/15
    Thanks!!!
    Thanks!!!
    LTZ/ZR2
    36/15 - .00169 MF and 61% RV
    48/15 - .00211 MF and 54% RV
    RST
    .00142 MF and 60% RV
    .00199 MF and 53% RV
  • bryanwilson1bryanwilson1 Member Posts: 42
    Mf,rV and any incentive for august please
    2023 lt crew 5.3 4x4
    Thanks again.
    Thanks again.
    What is your location?
    Sorry 44870
    Thanks again.
    Sorry 44870
    1LT or 2FL?
  • GeezInTheCarGeezInTheCar Member Posts: 4
    Hi, can you provide the current rates for 2023 1500 RST - 4x4 - 3.0L Diesel - Zip code 33028
    Thanks so much! You rock!
    36/12 - .00142 MF and 62% RV
    48/12 - .00199 MF and 56% RV
  • Deere7810Deere7810 Member Posts: 1
    Could I get the current rates for 2023 1500 LTZ 4x4 3.0 Dsl Zip 49316
    Thank-you,
    Thank-you,
    .00211 MF and 57% residual
  • Ybar03Ybar03 Member Posts: 3
    Can i please have the MF and RV for 2023 Silverado 1500 High Country 4x4 Diesel. Zip is 92057.
    36/10 - .00128 MF and 63% RV
    48/10 - .00176 MF and 57% RV
  • jzwangjzwang Member Posts: 15
    Hi, can I get the MF, RV and current incentives for a Silverado 1500 High Country and LTZ with the 3.0 diesel 4x4 crew cab?
    Zip code is 94587, 36/12k
    HC - .00128 and 62%
    1LT or 2FL?
    1LT
    Thanks again.
    Sorry 44870
    1LT or 2FL?
    1LT or 2FL?
    1LT
    24/10 - .00193 and 72%
    36/10 - .00142 and 63%
    $1750 incentive for 2.7T engine
    $750 incentive for all other engines
  • Jeffk79Jeffk79 Member Posts: 13
    edited August 2023
    Hi, can I please have the MF, RV and any available incentives for a 2023 Silverado 1500 Short Box 4WD RST 5.3 V8 in zip code 60453? Looking into 36/10K but was also wondering if there is a "sweet spot" for these trucks? I typically drive under 10K miles/year and am open to term limit. Thanks in advance.
    .00142 MF and 63% RV
    $750 incentive
  • maz41276maz41276 Member Posts: 3
    edited August 2023
    Hello, I'm also looking for MF, RV and any available incentives for a 2023 Silverado 1500 Short Box 4WD RST 5.3 V8 in zip code 01440. 36/12. Is there any difference in the numbers between a 5.3 or a 3.0 duramax? Also, are these rates based on GM financial? thanks!
    $750 incentive
    No difference with engine choice
    Yes, GM Financial
    Hi, can you provide the current rates for 2023 Silverado 1500 Crew Cab 4x4 Zip 92127
    2FL & LT 2.7L
    Thanks in advance
    2FL & LT 2.7L
    Thanks in advance
    .00194 and 69%
    $1750 incentive
  • Rtorres12Rtorres12 Member Posts: 2
    2023 Silverado RST Z71
    Money factor and residual
    10k miles for 36 months
    78261
    78261
    Which cab style?
    Which cab style?
    Crew, sorry
    78261
    Rtorres12 said:
    Which cab style?
    Crew, sorry
    $750 incentive
  • dfriesdfries Member Posts: 1
    Hi, can you please provide the current MF RV rates for a 2023 Silverado 1500 Custom Crew Cab 4x4 Zip 55068
    2.7L
    2.7L
    .00223 MF and 66% residual
    $1000 customer incentive
    Hi, can you provide the current rates and incentives for 2023 Silverado 1500 Crew Cab 4x4 Zip 92127
    RST 2.7L
    Thanks in advance
    and 4X2
    RST 2.7L
    Thanks in advance
    sonora02 said:
    and 4X2
    When are you going to pull the trigger? You've been asking for truck numbers since April....
    Plus a lot of other requests. How many people are you shopping for?
  • JbrunellJbrunell Member Posts: 1
    MF and residual for Silverado 1500 RST Duramax crew cab in 48059
    36/mo 15k miles
    36/mo 15k miles
    .00142 MF and 60% residual
    $2250 incentive
  • VdubzzVdubzz Member Posts: 7
    Requesting MF and residual for Silverado 1500 LT 2FL Crew Cab 48025
    36/mo 12k miles
    Thank you,
    36/mo 12k miles
    Thank you,
    .00194 MF and 69% residual
    $2250 customer incentive
    Hi, can I please have the MF, residual and any available incentives for 36/10 and 24/10 on the 2023 Silverado 1500 Crew Cab LTZ 4WD 5.3L in 60453? Thanks in advance.
    .00215 and 72%
    .00169 and 64%
  • BeardogchildBeardogchild Member Posts: 6
    May I please have the MF and Residual and Inventives for a 2023 Silverado LT 2FL Crew Cab 4x4 for the 24mo/10k and 36mo/10k lease. Located in 14217.
    $1750 incentives
  • navoyorknavoyork Member Posts: 18
    Hi, can I get the MF, RV and current incentives for a Silverado 1500 LT Crew TrailBoss 4WD Zip is 91977
    2.7L Engine
    Thanks!!!
    2.7L Engine
    Thanks!!!
    .00211 MF and 64% RV
    $1000 incentives
