When oh when will we get Forester Turbo? I wouldn't mind any tires on that beast!
But could you imagine RWL on a Porsche?
Soon, maybe, with the Cayenne on the way! Sad!
-juice
Bob
RWL on the Forester looks less out of place. That and the "AWD" stickers aren't my favorites, but I'm guessing Subaru will keep them on their most SUV-like vehicle.
-juice
I'd put money that a good portion of the SIA plant is for producing the Axiom which is due out this spring from Isuzu. SIA will now be producing Rodeos, Rodeo Sports, Legacies, Outbacks, and Axioms.
I believe Honda is cutting corners, living on their past glories of the 70s and 80s.
I'd just like to let you know, my XT6 has a tilt, telescopic and tilting guages
Long live the SVX and XT6!
-mike
It'll be a busy plant!
-juice
Leo
Note most of the stuff on this site pertains to the WRX, but there is a listing of other Impreza Info too.
http://www.new-impreza.com/
Also, go to SOA's web site and follow the links to News and press releases. There's a lot of info there too.
http://www.subaru.com
Bob
The structure is also stiffer, and interior materials seem at least one step up the quality ladder. The passenger seat has a height adjustment, too.
I suggest you visit a local auto show, since they're making their rounds now. They were present at the Detroit, Philadelphia, and Chicago auto shows.
We saw a WRX wagon, but the OBS should get similar improvements.
-juice
toyota and honda are not cometition for this allegedly muddled impreza line. Just look at the price of the Corolla S wagon and the civic 5 door......
Also, the Corolla wagon has been MIA for half decade or so. At least they'll offer the Matrix.
-juice
Wagons are making a come back, like it or not (I do).
-juice
Leo
If someone has data I would love to hear it
Frank
My Toyota has 153,000 miles and still going strong. Due to me putting in the wrong antifreeze in, I had to replace the radiator. A clutch replace at 100,000 miles, which I probably could have milked out longer. Other than that, it's been routine maintenence.
This was my fist Toyota--also my first foreign car. I've been pleased with its reliability. Will I buy another Toyota?? Possibly, but I'm open minded to other reliable vehicles. Thus my question regarding Subarus. I'm also looking at Mazdas and Hondas. I think Hyundai has made remarkable improvements in their vehicles in the last few years and warrant I look also.
Leo
It's like when you get a new car, especially if that model has already been out a while. After you get your car you often suddenly notice how many there are or aren't on the streets.
-Colin
Frank
Consumers reports Recomends ALL current subaru models and rates all of them with above average to exellent reliability.
Used models are rated equaly high.
And on a side note, a bunch of artiles about the new WRX were from a Subaru held "rally" that they did for hundreds of Media persons a couple months ago. They drove like 2 or 3 cars around for 2 days for over 15 hours straight each day on Rally courses with jumps, gravel, dirt, etc. (Stock cars, nothing done to them) and over that whole weekend, all that was ever replaced were Tires. (If you go find and read some of the articles from Car+Driver, Road+Track, Automobile Magazine, Grassroots.com, here at Edmunds, and more, alot of them mention this and are astounded by that fact).
Suburu's are Generally VERY reliable and VERY rugged, not to mention very safe in accidents and in hard conditions.
ash
Frank
-mike
In the summer, the car rides fine. But it's in the winter that it squeeks like I am driving some old Ford truck!
-mike
-- ash
I heard that turbo chargers can be rough on engine wear, is that true? That they can cause head gasket leaks, is that true? Last, I heard that the turbo chargers themselves often break, is that true?
As you may be aware, I'm new to Suburas and considering buying one. So any enlightment you can provide would greatly be appreciate.
Leo
I don't know of head gasket failure per se, that shouldn't be an issue.
1) Let the motor idle for 30 seconds to a minute before shutting it off. This gives the turbo a chance to cool and gives the oil circulating through it a chance to carry that heat away.
2) Change the oil often! Turbos stress engine oil due to their high operating temperatures.
Cheers,
-wdb
Leo
-Colin
200k is a bit optimistic, even for Hondas and Toyotas. By then it's very likely that several parts would have failed, so it's a matter of what was fixed/replaced/serviced. It is worth spending $700 to fix the AC condenser on an Accord with 178k miles?
Fleets are a good example. My friend is VP of a construction company, and they have dozens of fleet pickups. They are mostly Fords, which aren't rated highly in reliability. But the key here is DURABILITY, not reliability. In other words, they service them all the time, in-house, and keep them running forever.
They routinely get 250k miles out of each truck. Yes, that includes an engine rebuild or two, and several other repairs, of course.
Bottom line: take care of your Soob and it will last. Remembering to do the 30k, 60k, 90k, etc servicing is probably most important.
ramon: sure you don't need that front strut tower brace to quell the rattles?
-juice
Thanks for the tip on using synthetic oil in turbo charge engines. I did not know that.
juice, I hope that your wrong regarding Toyotas and Hondas--at least for Toyotas as I currently own one. Everyone I talked to who owned a Toyota brag about how Toyotas are just getting broken in at 100,000 miles. Many attest to near 200,000 miles or greater. All said without major repairs. Don't know if that means I should read between the lines or that they a very loyal Toyota fans. Brand bias has a tendency to blind one to a vechicle shortcomings.
Just like before I bought my Toyota, I heard good things about Subaru and their reliability. Sure there are going to be bad Suburas that have trouble just as there are going to be bad Hondas and Toyotas. Overall, I think Subaru are good reliabe cars.
Personally, I can't wait to see the 2002 subura models coming out.
Leo
Frank
-mike
Also, how long a circa 1982 car of any brand does not necessarily tell you how long a 2001 model will. So much has changed since then they really have not a single part in common.
However, an automaker with a historically good reputation for reliability certainly improves your chances.
-juice
For example, I put 25,000 miles/year on my car. Probably 90% highway, 10% city. Got my '94 Toyota in November. I'm estimating that I should have around 175,000 miles on my car by Nov 2001.
I think the national average is more like 12,000 miles/year. Some argue 15,000 miles/year. So if one keeps a car 10 year, the car will probably have about 120,000 miles. That's not too bad for a Toyota. I'd bet one would get tired/bored of the car after owning/driving it for 10 years more than for it giving mechanical trouble as a reason to get rid of it.
But that's interest thought. Would a Toytota, or any car for that matter, give more trouble w/ less mileage/year but getting to an older age vs a high mileage/year vehicle but newer? I honestly don't know.
I guess I got lucky with my Toyota. Because I'm going to try and keep it until 2002 thus making it both old (at 8 years) plus high mileage at close 200,000 miles. Since I'm not going to get anything for trade in on this car, I'm debating on keeping and see how long the car can last without major repair.
Any comments on my previous questions regarding Subarus?
Leo
What's worse, age or mileage? Well, in a used car I'd want a balance of the two, but I'd tend to say mileage is worse because it represents actual use.
The catch is lots of people with high miles will claim they are highway miles, which cause less wear in the long run.
-juice
Well, even though this isn't the SC-Maint&Repair topic I'll weigh in with my thoughts. We're all friends here and it will relate to Subaru (eventually!).
I won't dispute the common thought that mileage accrued on the highway is less fatiguing than mileage earned in stop&go city gridlock. Surely this proves true if you owned and maintained a high-miler at the extreme of each environment...
Anyway, the problem with this theory is that book value doesn't give a rat's posterior about city vs. hwy mileage. There is no discrimination, it all lowers value. If you are selling it yourself and convince a purchaser that the highway miles raise the value somehow then good for you. Would you likewise sell it for less if they were evil city miles (assuming in both cases the car was mechanically sound)?
From what I've seen of Subaru so far I think they possess the typical Japanese tolerances-- much better than domestics for sure. Subaru does not use especially robust parts though, unlike a Toyota 4AG or any vtec Honda. No oversize beefy rods, no forged cranks, etc. Reasonably reliable stuff, but of course aluminum blocks don't like overheating at all so any Subaru owner should watch that water temp like a hawk.
-Colin
It's a Forester L. and it's an Auto. I was pleasantly surprised at how efficient the auto is. It shifted seamlessly. And it's quite peppy too. Not like them Accords auto I drove on before. Aiyah!
The higher seating position was a change. Now I sorta understand why ppl buy SUVs. It's nice to look down on other drivers. hahahaha.... but on corners, I was kinda scared. Anyways can't wait to drive it again. Might as well.... since it's free for the day.
I like the seat height, too. It's like a boost, without being a high chair - so you don't get nausea.
It's so, so funny that you think it's so different. A lot of people criticize it for having seats that are too low!
-juice
Cheers!
Paul
My dad's does, though. But again, it's only for the first few seconds each morning. Must be surface rust, I guess.
-juice
- hutch
