2023 Toyota Corolla Lease Deals and Purchase Prices
124»
  • kyfdxkyfdx Moderator Posts: 273,555
    moodyhank said:
    May I please get the XSE Hatchback (automatic transmission) numbers for 36/10 and 24/10 in Colorado?
    .00185 MF
    24/12: 58% residual
    36/10: 53% residual
  • Samiam937Samiam937 Member Posts: 4
    May i please have the MF and residual for 2023 corolla sedan both LE and SE for zip 45420 and incentives?
  • MichaellMichaell Moderator Posts: 269,573
    What lease term and how many miles per year.
    36
    both 10k &12k please
    36
    .00185 MF
    54% residual
    Either trim
  • AldoPaulRamirezAldoPaulRamirez Member Posts: 1
    Hi!
    Looking for the Money Factor and Residual Value for a 2023 Toyota Corolla LE Sedan FWD! 36 Months with 12,000 Miles Annually. For Zipcode 77433! Thank you!
    Hi!
    .00185 MF
    54% residual
  • Fireblade950Fireblade950 Member Posts: 75
    Hi, what is the MF, residual, lease, and incentives for 2023 GR Corolla Core and Circuit trim both trims please, 10k miles for 36 months, zip code 10314? Thanks!
    .00315 MF
    68%/66% residual for Core/Circuit
  • 22tango22tango Member Posts: 49
    Hello, could you please share details for the Money Factor, Residual Value, and incentives for a 2023 Toyota Corolla LE? 36 Months with 12,000 miles, Zip code 80124! Thank you!
    Hello, could you please share details on Money Factor, Residual Value, and incentives for a 2023 Toyota Corolla Hatchback SE? 36 Months with 12,000 miles, Zip code 80124! Thank you!
    .00195 MF and 53% residual
  • FatchocoFatchoco Member Posts: 7
    Hello, could you please share details for the Money Factor, Residual Value, and incentives for a 2024 Toyota Corolla LE? 36 Months with 10,000 and 12,000 miles, Zip code 20036 or nearby! Thank you!
    .00195 MF and 54% residual
  • 96eclipse96eclipse Member Posts: 23
    Can I get MF and residual on a Corolla le or se
    36/10 zip code 07095
    either trim
    Could I get MF and residual for 2023 Corolla le
    Zip code 07095
    Sorry, the first numbers were for a 2024 correct?
    either trim
    Is this for 2023 or 2024?
    either trim
    2023, as this is the 2023 model discussion
  • GCBMWGCBMW Member Posts: 26
    Can you please share
    And
    MF
    Residual
    Incentives
    For 2023 Corolla LE?
    Zip 80134
    And
    MF
    Residual
    Incentives
    Zip 80134
    .00195 and 53%
  • mootsmoose23mootsmoose23 Member Posts: 23
    Can I have the MF/RV on Corolla GR Core 24/12 36/12. Zip 97086. Thanks.
    .00325 MF
    74% / 67% RV
  • OgM13OgM13 Member Posts: 5
    Could I get MF and residual for a 2024 Corolla Base model
    Zip code 07205
    Zip code 07205
    Please re-post in the 2024 model discussion
