Visitor Agreement.
-mike
For autocross all you need is Snell 90 or newer. Motorcycle or SA rated, it doesn't matter. You have to have 10 years from the current spec, and right now the current spec is 2000. If you bought a Snell 90 helmet you would have to replace it in 5 years, Snell 95 gives you 10. Beyond that... phew! replace that old stinking helmet!
-Colin
-mike
-Colin
(O He of Too Many Helmets, another one is on the way)
seamus
Hard to believe that such a small change in the shifter geometry makes shifting feel so much more solid, considering that only the angle between the linkage & the shifter fulcrum is changing by a few degrees. And the throw distance is about half of stock!
I really recommend this mod! Cheap & easy. I only wish I had done it sooner.
HIDs alone
All lights
Sorry, no night shots. Digicam is little brother, and can't wait around till after 9:00 pm (Summer Nights).
Have also installed a home brewed ignition illumination light complete with time delay, got an electronics friend to build the time delay I believe it consists of a slow discharge capacitor and a couple of resisters whole lot cost me about twenty bucks.
Cheers Pat.
Very nice pics. Did you do the actual wiring yourself? How difficult was it?
Ken
Brought it to the guys that installed my alarms.
$56.00 and one & half hour later... lights!.
From observing the installation, it didn't look too difficult. First they pondered (about 20 min.) the best place to put the ballast which ended up mounted on a bracket they installed in front of the radiator just below the bumper. next, find a sturdy spot to sit the lamps. The wirings itself, that's where I am no good at, don't know how it is done...and I was watching.
If you're thinking of HID auxilary for your Forester, go with the Micro Xenon, the Forester would look good with then. They are vertical mounted and rest on top of the bumper. If you check the light tunnel in Hella's web, you'll notice the Micro Xenon cast farther and brighter than the DE Xenons. I opted for the DEs cause the Micro would look silly with the OB's profile.
-mike
Mike
They definitely decrease the restriction in the incoming air supply. Throttle response is better and as paisan said, more upper RPM power. Just don't expect huge gains, but small gains add up and as you said, it is simple. I can't say it has done anything for fuel mileage.
The part number for the '01 Forester is 33-2154.
Frank
http://www.tornadofuelsaver.com/
http://www.summitracing.com
They had the best delivered price for the 2 I bought... put one in my wife's Forester also.
Frank
Ed
I can't say specifically about the underdrive pulley but my feeling is it just allows you to spool up a little quicker...after that ?????.
As far as the claimed HP gains ...I'm sure they could be backed up with dyno results... the real issue is the fact that the gains are almost always measured at the top end. Now this is not bad ..but unless you are spending a lot of time ut 5000+ rpms...the results are not really meaningful.
If you want your machine to be up a little from joe averages...the mod package is worth it! Moreover, I know of no performance oriented NA machines that do not include CAI/exhaust mods.
OK..a little longwinded and just my input...stand by for other comments..
-mike
In either case, don't expect huge gains. You'll need to combine that with a modified intake for any measurable performance gains.
Mike: I'd highly suggest going aftermarket for your bike rack needs. Subaru's racks are just re-badged Yakima racks. Chances are you're paying more money for less choice. There's a lot more choice in bike racks from companies like Yakima or Thule.
Ken
I never used K&Ns on my bikes. They always necessitated jetting changes and sometimes the velocity problems couldn't be worked out. Plus I rebuilt the engines frequently enough on dirtbikes, no need to speed it along by letting more particles through.
No car I've ever owned saw or ever will see dirt on that scale though, obviously. K&N is fine but I prefer AMSOil.
-Colin
Issue is probably as long as both can be reused equally as well eg: clean and replace...then your outlay has value. I'm a K&N guy and can say they "work good..last a long time"
Bottom line ..your $$$...make a choice! I doubt that you will be burned either way.DO IT!
I was wondering if you have tried both on the same car? I would be interested in an airflow comparison. The data I remember seeing suggests that K&N drastically outflows AmSoil. I always look for independant analysis and thought you might be it.
The only numbers I ever saw on dirt was that AmSoil stopped 99% and K&N stopped 98%. I don't consider 1% significant. I always thought that if Walker Evans used K&N to run Baja, how bad can the dirt thing be?
Frank
K&N does outflow AMSOil, but I wouldn't say drastically. Either are higher than stock paper filters.
-Colin
Matt
-mike
Matt
I've tried a kartboy in a friend's RS and loved it. He also had the urethane bushings, so it felt like the Honda S2000's shifter, i.e. snick-snick, zero play, short throw.
David: nice HIDs. Look how bright they are compared to the stock halogens!
Pat: get any pix?
I have the OE hitch mounted bike rack. If you already have a hitch, you may feel it's worth it. It's made for 2 bikes, but I've carried 3 just fine, and the bikes never touch the vehicle, plus you can tilt it and open the hatch. Lastly, it leaves the roof free for my cargo carrier.
-juice
On the '98 OB I noticed under the bumper, there's this thingie (fastener or something) one on each side, like it is used to hold up the bumper.
Anybody knows what is its use? And if it is removeable? Thinking of shifting those lights more towards center. Ya, I'm attempting to DIY.
-mike
here's where I hope to tap on your experiences.
In its current position, the light spread to the left and right respectively are cut off by the vertical column where the fogs are, and I thought maybe shifting the lights towards center would clear the light pattern of those columns.
Whats your thought on this?
-mike
http://www.toad.net/~rrubel/lights.jpg
Or
some Subie Gal style rally lights. :-)
http://www.subiegal.com/legacygt.htm
Dennis
Jim
-mike
Jim
Dennis- Yep, you're right. I don't need anymore lights. Grin
Jim- I'll fall on it as plan 'B'... Not that it isn't a good thought/idea too.
So, has anyone removed that fastener thingie and mounted their aux lights there?
-mike
It's a wash on the cargo baskets. A Yak SpaceCase will set you back about $479, while the approximate equivalent (different Mfg) from SubaruParts is $340.
HTH,
Theo
-Colin
-mike
Seriously, though, I saw a nice set of HIDs on a Legacy one night and it was like day time. They lit up the whole parking lot, though it did take a while to warm up.
-juice
-mike
-mike
Frank
Rgds,
jack
