Visitor Agreement.
WDB: some times I wish more people thought that way. There are way too many distraction inside cars nowadays.
-juice
Ross
BTW. wear a dust mask when you pull the drums off they will be full of brake dust,clean everything up before you put the drum back on.
Cheers Pat.
-juice
Cheers Pat.
does anybody here have any experience with the various lightweight battery replacements out there?
my 1998 Impreza is getting a new battery.
Right now I'm leaning towards the
Westco Miata battery replacement(25lbs, $85),
or the Dyna-Batt (13.5lbs, $147ish).
any first hand experience out there?
thanks,
Ryan
(has links to the above sites, but I seem to recall that stuff like that isn't good juju on this board)
-juice
I've never read that anywhere, here's a pretty good, non commercial write-up:
http://www.miata.net/garage/battery.html
the Westco is my frontrunner right now.
Ryan
Ryan, what's the CCA of the stock battery? 470 isn't bad for something so small, and my wife's Miata had no problems last winter although I would personally tend towards putting a 700-800 CCA DieHard in my Impreza once my stock battery has given up the ghost.
-Colin
I'm sure a tiny in-line four is a lot easier to crank than a 2.5l boxer.
What about the American Eagle battery in that article? My Panasonic was replaced, and IIRC I have a WestCo in my Miata now.
-juice
The only catch with the AGM batteries (i.e. the Westco) seems to be the required slow trickle recharge rate. Of course they'll be happy to sell me their low amp charger.
The car isn't a daily driver though, so If I have to jump it on occasion, it's not a huge deal.
I wonder if anybody make a charger that will let me swap between the 20A and 1A charge rates, so I could use it on my normal batteried cars as well........
Ryan
-perhaps expecting too much.
more info (clipped) from the miata page:
In 1985, when the Miata was taking shape in Irvine, a new battery technology was being used in military aircraft. The paramount considerations of power, weight, safety, and reliability were the selling points of this new type of battery. The new technology was AGM or Absorption Glass Mat. This technology was an evolution of previous battery technologies, including gel cells.
One of the differences with the AGM battery compared to the wet-cell battery is the recharge rate. That is, how fast you can put energy back into the battery. With a wet-cell battery you can "quick charge" it at about 20 amps or more. Usually this is when you would boil the electrolyte right out of the battery. The AGM batteries require a lower charge rate, for a longer time period. If your battery will not crank the engine, you should charge the battery at a rate of 1 amp or less for 18-24 hours. If you try and charge it like a wet-cell battery, you will destroy the battery.
WestCo has a small battery charger for the Miata for those who drive their car infrequently. The EZ-12R is a ½ amp charger that will automatically maintain the charge in the battery. The advantage of this charger is you can leave it plugged in and it will not overcharge the Miata battery.
How fast does a running car charge it's battery with the Alternator? Is it the equivalent of a trickle-charge?
-juice
BTW. I understand that if you are charging any battery with a battery charger it is preferable to trickle charge apparently fast or high charging shortens the life of the batteru considerably.
Cheers Pat.
If you live in Ottawa Canada weight of the battery is not a consideration, getting the sucker started at 35 below celsius is a far greater consideration therefore the biggest battery that will fit is the one you use.
The only time I could think it would be less of a problem would be in a summer driven car.
Cheers Pat.
ryan: I bought a craftsman charger some years ago that supports 4 charging modes: 50a (starting only) 30a, 20a, and 3a trickle.
-Colin
But the reason I asked the question about the trickle charge is this - if Ryan hooks up a WestCo, won't his Subaru try to charge it rapidly, and damage the battery?
-juice
perhaps I'll even trunk mount it. Alternator charging shouldn't be a problem. The Miata system (which also charges the US replacement wet cell battery) should work just like the Subaru and vice versa.
I should have it Friday or Monday. report to follow, and of course some Michigan winter durability testing. although our 60 degree weather now hardly qualifies as winter in my mind.
Ryan
-juice
Oh boy! It was fun fun fun! The day was fantastic. It was partly organized by the Honda Prelude club of Toronto. The invitation was extended to us. A few of us went. We all met up together before caravaning to the track. Was well organized. There were some who went for the car control school. Actually most of the prelude boys went to the school. So that left us to do lapping. Lots of cars showed up later. 2 Vipers, a new M3, a kit car, supercharged miata, mr2...the likes. But we totally tore up the track. Yup. The track was quite technical with 16 elevation changes. It was awesome! Of course I remounted my S-03s. They were fantastic. Pulled on Type-Rs, Vipers, Mustang GTs, MR2s all day. The type R guy who did this a few times more than me came later to ask me if I did this before. He was shocked when I told him it was my first time. Guess my Solo II experience also helped. The best was when I pulled on one of the GTS Viper. He was fast on the straights but the techincality of the track slowed him down, that's when the AWD of my lil RS really bite it's lil Viper tail. After a few laps hanging by his rear, the driver gave up and pulled to the pits to let me pass. Hahaha...
All in all it was a good time. My poor tires are prolly half worn now. Alot of guys there were totall impressed with the Scoobies. They came and asked us how come we were so much faster, and we told him that with the off camber turns coupled with some undulations in some corners gave our cars the advantage in which we can put the power down much faster than those 2WDs.
Anyone have any information on the following:
Front Strut Brace. Any gains on handling? Is there one
out there for MY 02? Costs?
Rear Anti-Sway Bar. Stock bar looks quite "thin".
What size should I go with? Any gains in handling?
I do not want to get too wild! Is there one out there
for MY 02? Costs?
Thank you in advance.
I guess a lot of us are at the end of the RE92 service life....
Here's my experience. I bought a set of barely used S-03 205/55/16s (thank you Jon Bogert) and mounted them on my GT's stock rims. Then I realized I'll need winter tires, and picked up a set of '00 RS rims (thank you boebe999) with 215/50/16 G-Force KDWs already on them. my unscientific analysis:
KDW- loud as hell. Sounds like I have a vacuum cleaner in the car. Grip is good, but they get a little squirrelly at the limit. At the threshold of performance, they are a bit unpredictable and don't talk to me as well as the S-03, and therefore aren't as confidence inspriring. Luckily, the car itself does a pretty good job and I've had enough track seat time to know if the $heet is getting ready to hit the fan. Still and all, it is a good handler that I would be happy with (although it is noisy), if I hadn't ever spent time with.....
S-03. My car's best friend. Even with the slightly taller sidewall, these are the most inspiring tires I have ever driven. Gobs and gobs of grip all the time, and very collected in the rain. Breakaway is smooth and progressive, with plenty of warning for the driver who knows how to listen (with your fingertips). I didn't pay retail, thank God, but I will gladly shell out the retail price for these next go 'round. The single most dramatic improvement I could possibly have made. Now, what to do for the cold weather.......
BTW, this was a modest upgrade from 18 to 20, so the car is still a loooong way from exhibiting dangerous "snap" oversteer traits.
Having said that, we both love the car with the 20mm bar, and it has been a hoot at the track too(!!). We have a BG Outback and a BG GT; your BH Outback is prolly a good 300lbs heavier, so the stock bar may be more than the 18mm bar that came with ours.
No doubt they're an awesome tire though!
-Colin
The tread ain't as kewl as the S-02s tho. Oh well...
ramon- it's all true! tread does look wimpy, but I prefer performance to looks anyway. Plus it fools auto-x newbies/ :-)
Damn, now I miss them. I've fot the G-force KDWs on right now, since they are almost worn and the S-03s are almost new. I figure I'll get through the winter on them, switch to L-81s for any massive snow days, and get into my S-03s next season.
-Frank P.
I will let y'all know how it goes once it is in.
BTW its not very expensive a mod either...the maine console cover plus the tow cup holder parts are mayb $40 total.
-r
You have to swap out the whole console as the new top panel with the two cupholders does not fit the model years 2000 and 2001.
I have just done this swap on my 2001 GT wagon so I know of which I speak.
Subaru had to modify the whole console in order to incorparate the two cupholders, sorry to rain on your parade but it is not a cheap swap.
Cheers Pat.
Nice driving.
We're supposed to get a cold winter. We'll see if we get precipitation, though.
Pat: I went to a dealer on Saturday and saw the new console. Nice - you can hold two mugs, even. The lit ignition ring is really nice - all Subies should get it.
Still can't talk the wife into a wagon, though. They had a Forester S Premium and an Outback Limited side-by-side, and she still preferred the Forester because "it's not a wagon".
-juice
Bob
-juice
She likes it quite a lot, other than being utterly gutless (3.4L, auto, 4wd). Cannot convince her that a WRX wagon is cool, but I bet she'd spring for a Forester... maybe "Brat", our dogs are small so plenty of room for them.
-Colin
I guess you know you made a good choice when you shop for you next vehicle and you end up at the same exact thing even years later.
-juice
The dealer tells me you have to buy the whole ignition switch to get the lighted ring, I cannot see it as the old black collar is separate from the switch I think the new lighted ring is the same way.
They just cannot see this on the parts list, so there is no convincing them it is separate.
Cheers Pat.
-juice
Might be worth a try they can only say no.
Cheers Pat.
Good to hear about the sportsmanship, ramon.
-juice
I do want to go through with the mod since it just makes a lot more sense than the 2001 version.
Thanks for any info!
-r
Cheers Pat.
My daughter bought mine as a christmas gift as I wanted it but did not want spend that amount of money.
She got it from a dealer in the Nashville area and she would not tell me what she paid since it was a gift I don,t think it will be cheap in the states either.
You need console box assembly part #92111AE14AML.
console cover part# 92132AEO7AML.
switch case console part# 9217AE12AML.
cupholder cap part# 66155AE03AML.
cupholder support Part# 66155AE02A.
There may be some little parts I missed as I had to swap over bits of my console.
Cheers Pat.
Cheers Pat.
Ross
-Colin
Ross
-juice
RP
-save your integra jokes please...
I dunno, they still look odd to me. If you wanted a rally replica I guess they work.
-juice
