Have you recently purchased a new car or are you trying to and struggling to find affordable options? A reporter would like to speak with you; please reach out to [email protected] by 5/26 for more details.
-juice
http://forums.i-club.com/forums/showthread.php?s=&threadid=227158
Not many trade offs, the lights don't draw any more amps from the alternators than any other accessory. depending on the size and mounting location of the lights there might be a reduction of airflow to the radiator, but definitely not enough to cause problems.
I have PIAA 520's mounted on top of the front bumper on my 98 Forester, man, those are bright!! I use them sparingly. As for manufactures, I would go with a quality one, such as PIAA, PILOT, HELLA, etc. But don't buy driving lights from a regular auto parts store (pepboys, autozone, etc) they generatly low end models that will not deliver the performance that you would expect. Go to an aftermaket specialist, you will paymore, but then you get what you pay for.
I do know for certain that in terms of ease of installation, PIAA can't be beat, very simple, took me no more than half an hour to do it. I have installed Hellas and they are a pain to do, wires everywhere (some of them not long enough). The only tricky part is splicing into the headlight/parkinglight wires for power, if you choose to go this route, not much room or factory wire length to work with.
I would recommend that you choose a light with a "driving" beam pattern as opposed to a "pencil" beam pattern. The former illuminates at a wider angle. The latter will illuminate further, but with a much narrower spread, as the name suggest, like a pencil, straight and narrow.
If you are doing the install yourself, please take the pain staking time to aim the lights properly, it will give you better performance from the lights and keep on comming traffic from high beaming you (just a thought).
Much luck.
Mike
Joe
If Subaru offers the Electrochromatic Mirror with Compass as a optional accessory for the '02 Impreza, then it is likely prewired, as the '01-'02 Forester supposedly was. (My guess is that the harness is tucked into the headliner, just behind the mirror.)
Even if it is not prewired, if you are semi-handy and it actually comes with instructions, you should be able to put it in yourself in 30-60 minutes or so.
I should know - I bought the identical aftermarket mirror from Donnely Electronics that has the compass AND an outside temperature display for my old '99 Forester. This is the mirror that was advertised in Motor Trend just about every month. Subaru uses Donnely as the OEM and had them design one without the thermometer.
The main wire I was able to easily tuck into the headliner without removing it (thank goodness!). I then removed the A-piller cover (it just pulls off with a strong tug on the Forester) and fed the wire down behind the dashboard (near the left footrest).
I then used the pinout diagram in my owners manual to tap into the 12V igition-on power line for the security system, but the Subaru OEM one you're buying likely has specific instruction where to attach the wire.
The bulk of the work was running the thermocouple through the firewall to the front of the car, but since the Subaru OEM doesn't have that, you don't even have to deal with it.
I LOVE this mirror. It is definitely worth the money.
Elliot
-mike
you have a couple of hurdles:
1) the Phase I DOHC EJ25 has a Mass Air Flow sensor. More accurate and therefore a better performance choice, it is still more fragile than later MAP equipped systems. Isolation from vibration and good filtering are critical to this part's long-term survival.
2) Phase I engines also need that torque chamber (the big plastic box on the intake plenum). this is a reservoir of pre-filtered air that avoids starvarion problems under wide open throttle inputs. I think Colin will back me up on this..... And most cone filter type CAI systems ditch this part.
3) cold air from where exactly? Us GT guys don't have the Impreza RS boy-racer hood vents that can be made functional to help the traditional cone filters get to cold air. And the scoop is too far aft.
I've just taken out the snorkus from the right fender well and let the airbox draw from the fender-well. You could also go with a drop in filter like K&N or AMsoil, but I remain skeptical about their usefulness. Others here are true believers and may come up with the data to convince you otherwise. but with that MAF in there, I dunno.
hope that helps, from a BD GT owner that loved the sound of his CAI but didn't like getting hung out to dry every time he stomped on it.... :')
a big airbox will help any engine during throttle transitions. it's actually the removal of the reversion tubes that hurt the MAF-equipped models, rebounding air and pressure causes a sensor misread. air that's already been metered moves over the sensor again...
-Colin
it's very large and noticable on a '99 SOHC.
-Colin
If you yank the snorkus be ready for a bit more intake noise, though I like it.
-juice
Check out this page:
http://www.importstudio.bigstep.com/item.html?PRID=717680
-juice
-mike
Ken
-juice
steve-v
http://www.thepearsonhome.com/subaru_modifications.htm
Jim
The sound gets better once the speakers and unit aquaints each other.
I had reported my mild dissatisfaction of the sound after my swap (loss of mid-range tuning), but after awhile the sound quality was noticeable better than the original OEM unit.
I must say, a swap very worthy of ones $$$ and time spent.
-Dave
Maybe use a piece of wood, painted flat black, to cover that hole? For now you could just put some black electrical taper over it.
-juice
4 springs on a WRX from stock to Eibach Pro-springs no lift, just jacks, and not working like mad, 1:12min start to finish. 2 weeks ago took us 45 min to do 2 WRXs start to finish with 8 people in the dark and Rain.
Anyone else have any interesting install times?
-mike
-Dave
Jim
-juice
http://www.gatech.edu/oit/oe/design/rob/suby/106-0614_IMG.JPG
Also,
http://www.gatech.edu/oit/oe/design/rob/suby/106-0613_IMG.JPG
The reasoning behind this is simple....there is no chrome on this car except for the grille...so why not get rid of it.
I can put it back stock (or I may get the new 2003 grille which I like much better!).
-r
How did you do it? Or it that just a great PhotoChop job?
-juice
Is the mounting method secure? I take my car through a 'touchless' car wash from time to time. The exit blower is strong enough to flex the hood deflector quite a bit. Think the side visors could hold up to this?
How about wind noise? Any noticeable difference after adding these on?
Thanks for any info. I've got a Bernese Mountain Dog that thinks my car is her second home. I'd like to be able to crack the windows for her in the rain and not end up with wet seats (or wet dog).
Alan
I get into a lot of deep snow in winter, and would like to have this virtual center diff lock effect for those conditions. I have retrofit a diff lock switch on an SUV before so it could be used with the diff locked in high range as well and it was fairly simple. But..??
Thanks in advance.
IdahoDoug
-mike
Thanks for the thumbs up.
If I was smart, I'd a used photoshop. But instead, I removed the grille, masked off the black surrounding the chrome, masked off the Subaru emblum (sp?) and sprayed away with Krylon Semi-Flat black paint. I need to touch it up, though, I did it at night and did not get a good look at it till the next day....plus just this morning on the way in to work, something nailed me in the grille...I don't know what it was, but I am guessing it was a rock spit up by the car in front of me.
BTW...it is not that I hate chrome...its just that there is no other chrome on the entire vehicle. If the vehicle was of a design that lent itself to having chrome (say a '67 190 SL) then I wouldn't have a problem with it.
-r
Did you sand the chrome before you painted? I'm surprised the paint stuck on so well.
-juice
-mike
I also thought about painting that chrome area to match the color of the car...but that would be a whole lot more involved.
-r
I've read over at i-club about some people discussing the possibility of putting 4EAT into a "locked" 50:50 mode. Since there is a fuse to disable AWD completely, there should be a way to keep it permanently enabled.
I believe the challenge is that the clutch pack on the 4EAT (not the VTD) is not meant for heavy duty use (ie. constantly engaged). I've read somewhere that the 4EAT clutch pack constantly cycles on and off and is never fully engaged (maybe with the exception of 1st gear).
Ken
-juice
Either of you recall where those threads were? If there is a forced torque spread in '1' then all my work is done! That's really all I'd need.
Also, the FWD fuse thing is something I've thought of as well. I've used it for a couple hundred miles and I think it's easy on the clutch since there's full slippage going on and no distribution rearward. What I wonder is if there's a full locked up mode with 0 slippage that would also be healthy for extended use. After all, if there's enough line pressure to get 0 slippage available, then the clutch itself should be fine, eh?
So, if I can find any information on the logic or controller of the clutch, it would likely be a matter of discerning the signal required to keep line pressure maxed until further notice.
IdahoDoug
Hope this helps..........
Here's a thread posted by the above Mr.lakepop:
http://forums.i-club.com/forums/showthread.php?threadid=84430&referrerid=767
That thread has good comments from "SubyTechMaster", a.k.a. Ed from ISR Performance.
-Dennis
-juice
-Dennis
-juice
On a whim I ordered the tweeter kit for '97 OB, only $35 thru a dealer. I have fished the wires up from the door panel and am waiting for the kit to arrive UPS this week. Question: Do these tweeters have some sort of crossover or high pass filter (aka "bass blocker" or the like) built in, or is something like that built into the factory speaker/wiring, or nothing like that at all?
If not, has anyone tried to modify this on their car so the speakers get the frequencies they are supposed to get (ie highs go to the tweeters)? Any suggestions or feedback (d'oh! - bad choice of words!) would be appreciated. Thanks.
btw - I already tried to ask the dealer and Subaru these questions, but understandably they don't know a lot about speakers, just cars.
-juice
Frankly, I'd be surprised if there is any filtering on the tweeter wires as this is not a very high end setup. Mine sounds fine, though with the upgrades there's a pretty big hole in the low end that's got me thinking about subs. It never stops, eh? Glad I pulled the subwoofer amp output wire out where I could get it easily if just this upgrade came along....
IdahoDoug
