Visitor Agreement.
-utahsteve
I have had boots that fit so tightly that they trapped air while installing, forcing the boot to pop loose of the plug. I had to "burp" the boots with a small hook while I pushed the boot all the way on to get them to stop popping off.
I have only found this to happen with what I consider to be high quality performance wires.
Frank
I did sent the wires back to them and waiting to see what they say
I've been considering a full size tire, too, but haven't gone there yet...maybe when I hit the lotto...
Brian
bit
-Dennis
I would never again own a space saver spare if my vehicle had room for a full sized spare, BUT... the roof is the last place I would want to put it. Up there it is subject to the elements (lots of UV) and it raises the center of gravity of the vehicle.
The worst of it is that it would look silly. Why not mount it on the hood like an old Land Rover?
-james
:-D
-Colin
Sam: if you are interested, e-mail me (just add @ifc.org to the end of my handle). My wife would love to see me clean out the shed.
-juice
-juice
those old carbureted EA82 1.8L OHV engines had the spare sitting right there...
first time I saw one I was like 12... had already been wrenching on motorcycles and cars for a while, helping my dad... and a friend of his had an GL Wagon. popped the hood for some reason and another guy spots the spare and says "wow! there's your problem, if you replace that restrictive air cleaner you're sure to get more power and better gas mileage!"
I couldn't stop laughing. I still think about that whenever I see an old Subaru on the street...
-Colin
I guess a small engine leaves enough room up there, why not? The spare was filthy, though.
-juice
-james
Cheers Pat.
Bob
Cheers Pat.
Cheers!
Paul
-Frank P.
-juice
• A full-size tire can be fitted.
• It can be protected from the heat and grime. Perhaps putting it in an insulated plastic box?
It will raise the center of gravity ever so slightly, as well as adversely affect the front-to-rear weight distribution, again, only slightly; but the space gain in the trunk area are well worth it IMO.
Bob
Modern engine bays are crammed so I doubt we'll see it often.
Look at how spares can get in the way - like in the Hummer H2. And rear mounted spares create blind spots.
-juice
Cheers Pat.
-juice
Again, I want to see a full-size spare, and to have it sealed and protected from engine heat and engine/road grime.
Another possibility is to stack it vertically between the engine and radiator, or in front of the radiator. The problem with this solution is that you are adding extra front overhang, which is not desired, as Subies already have a lot of front overhang.
Bob
-juice
2) It might be able to be engineered so that it becomes part of the front-end crash resistance. If the tire were laid flat (or on an angle to reduce front overhang), under the radiator, but behind the front bumper, it could be done. Again, it may add some extra front overhang, and accessing a tire that's under the radiator might be tricky.
Of course the radiator could be relocated or you could have two small radiators off to each side, which would eliminate accessing the spare. I think it could be done, but it would require re-engineering the whole front end.
Bob
For the Miata to get to 50/50, they put the spare and even the battery in the trunk!
-juice
If that were done, the spare could be mounted vertically, and take up the space that the radiator now occupies.
Bob
The spare in the Forester is perfect. It's clean and easy to access. Sure, you have to remove the cargo, but so what, you have to remove cargo to reach the tools anyway.
I'm not sure they'd want a big steel or alloy wheel in the engine bay for safety reasons. They already design motor mounts to break so that the engine dives under the passenger compartment, now they'd have another thing to worry about.
-juice
-Frank P.
Too unique? "Unique" is what makes a Subaru—a "Subaru." I wouldn't want to think that GM will kill that uniqueness. Maybe it will happen. I know paisan thinks GM will smother Subaru's creative impulses eventually. I hope he's wrong.
Bob
Bob
More likely is the demise of the spare entirely. Tires are FAR more dependable than they were in the "good old days". When was the last time that you had a flat... a "blow-out" not just a slow leaker that you can air-up and limp to the tire store on.
Cars don't carry spare engines or transmissions. Why carry a spare tire. The Vette Z-06 has no spare.
By the way... I'm only half serious here.
-james
-Dave
and we don't go around running over nails or screws with our engines or transmissions, plus they take more than 10 minutes to swap. *that's* why we don't have spares for those. ;-)
-Colin
Bob (running for cover!)
-Frank P.
Bob
Run flats are heavey and usually have very stiff sidewalls. I think the PAX system is a possibility, though. That plus a can of Fix-a-flat, like Pat has.
But in a big SUW, bigger than the Outback, with very likely bigger tires, it won't happen.
-juice
Alpine 6-disk changer, plays MP3's WOO HOO!(_8(|)
Alpine 4 channel amp
Alpine speakers all around
Hope to get a woofer with an amp soon, let the neighbors know I'm home.
Oh and tint, 35% upfront and 20% in back.
And finally, large barnicles of snow behind all 4 tires
Mike
http://www.yakima.com/products/dynamic/8007076_6.html
I'd like to get the MegaWarrior for the Outback if it will fit... If I end up getting it, I'll post pictures!
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item- =2404927243&category=10368
the SVX's rear differential is the same as the WRX's-- Hitachi R180.
-Colin
I bet it would fit a new RS, Outback Sport, TS, or Forester L or X.
-juice
If the Mega is longer by a foot or so, than it should fit with no problem...if it's much wider, it might look funny, but should mount with no problem to the factory rack same as the Load Warrior does.
I know you can buy an extender for the standard Load to make it longer, so I'm guessing the Mega is wider, too, than the Load.
Given the unloaded weight of my Load Warrior, I don't think I'd want anything heavier. The rack alone weighs about 50 pounds with 3 bike mounts attached to the Load Warrior...that's a lot of weight up there before you even start adding fun stuff like bikes and gear...just something to consider.
B
