Either way, not sure what program you are referring to. Do you have a link?
MOJ - 54% / 48%
RUB - 53% / 47%
36 months = .00412
48 months = .00373
What's the mf and res for 36 12 and 48/12 on gladiator sport S in 92064
55% / 49% RV
1. 2023 and 2024 Jeep Gladiator Sport S, 36/12, 33322.
Standard MF and 54% residual
Can I please get MF and RV for 2023 Mojave and High Altitude for zip 34772?
36/10k miles and 48/10k miles
54%/48% residual for 36/48 mo
Either trim
Thanks! How can I determine what standard MF is?
48: .00373 MF
Can I please get current numbers and incentives for 36/12 and 48/12 for zip 98404 for a Mojave? Does the 15% off MSRP apply to leases?
( fyi, new to leasing, so if I should be asking for something else that would be a better idea for someone who is likely to purchase at the end it would be appreciated )
53%/47% residual for 36/48 mo
Sorry, no info on the 15% off, or if it applies
I found a 'far out edition' that I'm sure CFC doesn't supplement:
RUB - 53% / 47%
36 months = .00412
48 months = .00373
Also, same numbers for Far Out
Usually don't start seeing programs until they are on the lot
Standard MF
OVL: 54% residual
Sport: 56% residual
Hi
May I have the mf and rv of 2023 Jeep Gladiator WILLYS 4WD 3.6L V6 Automatic zipcode 48329.
Thanks for your help.
Standard MF and 51% residual
It's 36/12 the same?
Thank you again
Thank you again
53% residual for 36/12
Can someone please provide the MF + residual for a 2023 gladiator Willys sport. 36months /10k miles. Zip code 60191
Sorry if this was covered and I missed it. What is the standard MF rate? Thanks!
.00411
52240
24 and 36mo 12K
55% and 50% residual
36 Mo 12k miles
