2024 Toyota Tundra Lease Deals, Incentives, Rebates, and Prices
13468918
  • kyfdxkyfdx Moderator Posts: 262,003
    johnciv6 said:
    .00173 MF
    72% and 68% residual
    Just a general question. Do the hybrids have lower or higher residual on the upper models?
    Just like the gas models, the higher trims have lower residuals
  • johnciv6johnciv6 Member Posts: 87
    edited February 2024
    2024 tundra SR5 4x4 5.5ft
    98550
    (For my dad, sorry for all the requests)
  • MichaellMichaell Moderator Posts: 259,840
    98550
    Which cab style?
    Which cab style?
    Crew
    98550
    johnciv6 said:
    Which cab style?
    Crew
    .00265 MF and 70% RV
  • RichRoyal2RichRoyal2 Member Posts: 3
    What Tundra model and configuration leases the best? 40299
    SR Crew Cab
  • iambevsiambevs Member Posts: 19
    Could I please have the MF & RV for the 2024 Tundra Limited Crewmax 5.5 AWD 12k/yr 36 mos 29910
    Is that gas or Hybrid? I don't know the engine sizes
  • TonyP0717TonyP0717 Member Posts: 21
    Could I please have the RV & MF for a Toyota Tundra platinum 4x4, crewmax 6.5, 15K, 36 months zip 33065.
    Gas
    .00245 MF and 65% residual
    .00245 MF and 70% residual
    SR Crew Cab
    Thanks. What’s the MF and RV?
    Also, of the limited, 1794, and platinum which is the best lease in 40299 and what is the MF and RV for that one?
    Thanks for your help!
    SR Crew Cab
    36mth, 12k per yr
    SR Crew Cab
    .00265 MF
    71%, 67%, 65%, 65% residual
  • ysiysi Member Posts: 2
    Could I please have the RV & MF for a Toyota Tundra platinum 4x4, crewmax 5.5, and limited 4x4, crew max 5.5, 10K, 36 months zip 80212.
    Gas or hybrid?
    Gas or hybrid?
    Hybrid
    ysi said:
    Gas or hybrid?
    Hybrid
    .00265 MF
    68%/65% residual for LTD/Plat
  • ajwindows8ajwindows8 Member Posts: 35
    For 46062, MF & RV - for both Gas and Hybrid models - 2024 Tundra 1794, 4x4, 5.5, CrewMax. 36/15K mi, and 48/12K mi. (or the two best lease-length terms offered at 12,000 mi or 15,000 mi). Thanks!
    .00265 MF
    62%/63% residual for Hybrid/Gas
    We don't have the 48 month terms
  • cciampa123cciampa123 Member Posts: 57
    Can I get MF, RV, incentives for the 2 below? Zip 01845
    Both non hybrid
    24 Tundra SR5 Crew Max 5.5 4x4
    36//15
    24 Tundra Limited Crew Max 5.5 4x4
    Both non hybrid
    39/15
    39//15
    No 39 month term supported for the Tundra
    .00265 MF
    65% LTD
    67% SR5
  • thatnew26thatnew26 Member Posts: 1
    Can I get the incentives, residual & MF for a 2024 Tundra SR5, CrewMax, 5.5' BED TDR OFF ROAD premium package, Premium audio package, 4WD? I'm looking at 36/12 in 95603
    .00165 MF and 69% residual
  • dauto32dauto32 Member Posts: 9
    Please share the lease numbers for
    Zip:
    08034
    2024 Tundra trd pro
    36m/10k miles
    Dealer said their MF is .00335 ?
    Also residue is 65%
    I don’t think that’s right.
  • lexusdriverx2lexusdriverx2 Member Posts: 25
    Could I get the residual value & money factor in zip 75009 for 36/10 on Platinum, Limited, Pro & 1794? All hybrid, 4x4, crew max. Thanks!
    I don't see a Pro trim.
    .00225 MF
    65% 1794
    68% LTD
    65% Plat
    Zip:
    08034
    2024 Tundra trd pro
    36m/10k miles
    Also residue is 65%
    .00335 MF and 69% residual
    PRO
  • pdurant1980pdurant1980 Member Posts: 27
    Hey - any chance you have numbers for zip code 36526 on a
    2024 Tundra SR5 Crew Cab 4x4 Gas for 36/12 or 48/12? Thanks!
    39/12
    .00245 and 73%
  • TireKicker12TireKicker12 Member Posts: 16
    Looking for MF and RV on Crew Cab 5.5" 4WD SR5 and Limited 36/15 24501...any incentives?
    .00265 MF
    67% and 65% residual
  • Hawks3212Hawks3212 Member Posts: 17
    Could I get the residual value & money factor in zip 52722 for 36/12 on Platinum, Limited, & Pro? All hybrid, 4x4, crew max. Thanks in advance!
    .00265 MF and 67% (LTD) and 64% (Plat)
    .00335 MF and 68% (Pro)
  • micarhunter11micarhunter11 Member Posts: 57
    Tundra sr5 crew 4x2/4x4 33067 , any lease term with low mileage option if available. Thank you
    39/12
    .00245 MF
    2WD: 70% residual
    4WD: 73% residual
    .00245 MF
    2WD: 70% residual
    4WD: 73% residual
    Thanks. Do you have SR numbers too?
    .00245 MF
    2WD: 70% residual
    4WD: 73% residual
    .00245 MF
    74%
    79% residual
  • hemgs1hemgs1 Member Posts: 41
    Can I get residual and MF for 36 (or 39 months) for 12k per year for 28409
    2024 Toyota Tundra Platinum Hybrid - 4x4
    and
    2024 Toyota Tundra Platinum - 4x4
    and
    2024 Toyota Tundra Limited - 4x4
    Please and thank you.
    and
    and
    39/12
    We don't have the Hybrid numbers for your region
    .00245 MF and 67% residual
    and
    and
    39/12
    Thank you - I assume hybrids would typically have higher residuals?
    Also can I do single pay lease and does that eliminate interest?
    and
    and
    39/12
    With SETF, I wouldn't assume anything.
    A one-pay lease is calculated with a lower money factor. We don't know how big that discount is with SETF, but considering the starting money factor, you can count on quite a bit of finance charges, still.
  • shellersheller Member Posts: 4
    good afternoon,
    Looking to lease a 2024 Tundra SR5 4WD crew cab in Colorado
    Do you know the MF and Residual 36m/12k miles?
    thank you
  • Samir_1998Samir_1998 Member Posts: 11
    RV and MF for 24 Tundra SR5 crew cab 4x2 and 4x4
    Any available rebates or tax credits?
  • BZ2710BZ2710 Member Posts: 2
    Can I get 36/12 MF RV for a 2024 Toyota Tundra 1794 4x4 Crewmax 5.5ft bed for zip code 10950?
    sheller said:
    good afternoon,
    thank you
    .00173 MF and 69% residual
