2024 Chrysler Pacifica Lease Deals, Incentives, Rebates, and Prices
kyfdxkyfdx Moderator Posts: 276,018
edited February 2024 in Chrysler
Ask your 2024 Pacifica lease questions here! Get info about prices, money factor, deals, incentives, and payments.
«13
  • Lomax1992Lomax1992 Member Posts: 4
    Can I get the MF and RV for limited and pinnacle Plug-in Hybrid 36/12 and 39/12. 92126
  • kyfdxkyfdx Moderator Posts: 276,018
    Standard MF
    PIN: 48%/46% residual
    $750 bonus cash
    I don't see a PHEV Limited trim for 2024
  • MSKing601MSKing601 Member Posts: 3
    Good evening. May I please have the MF and RV for a 2024 Chrysler Pacifica Pinnacle Hybrid Plug and just a regular limited in for the longest term available with 10k miles a year please? Zip code is 39466. Thank you!
  • MichaellMichaell Moderator Posts: 270,923
    LTD - FWD or AWD?
    LTD - FWD or AWD?
    If you can provide both, that’ll be great. Just in case they have an option for both.
    MSKing601 said:
    LTD - FWD or AWD?
    PIN - Standard MF and 50% RV; $7500 incentive
    LTD FWD - .00277 MF and 51% RV
    LTD AWD - .00264 MF and 51% RV
  • FishyFishyFishyFishy Member Posts: 12
    May I please have the incentives, MF, and residual in 20175 for the following:
    36/10k, Pacifica Hybrid Select
    36/10k, Pacifica Touring L (non-hybrid)
    Thank you in advance!
    FWD or AWD on the Touring L?
    FWD for both of these.
    Standard MF and 48% residual; $7500 incentives
    .00194 MF and 49% residual; no lease incentives
  • sr71photosr71photo Member Posts: 16
    Touring L FWD and Limited FWD
    75080 36/10
    Please and thank you.
    75080 36/10
    LTD: .00277 MF and 48% residual
    TourL: .00202 MF and 50% residual
  • audikupaudikup Member Posts: 153
    Hello. Could you send mf and rv for 2024 Pacifica touring L fwd 36/39 month 10k? Zip 80206
    Any current incentives? Thanks
    Standard MF
    50%/47% RV
  • ZacBrownZacBrown Member Posts: 2
    Hi could I please get the MF and RV on the Pacifica Limited AWD and Pinnacle AWD (both non hybrid versions) . Zip code 53213. 36/10 and 36/12K. Thanks
    Standard MF and 50% residual
    Thanks. What is the standard MF for this month?
    .00404 MF
  • jfeins02jfeins02 Member Posts: 210
    Can I pls get the numbers on a hybrid pinnacle 36/10 90036
    Standard MF and 49% residual
    $4500 incentive
    $4500 incentive
    plus the $7500 federal?
    $4500 incentive
    No. $4500 is the full incentive from Chrysler Capital
  • brian02brian02 Member Posts: 1
    May I have the MF and RV of a Hybrid Select S? 36mo / 10K, 60540 - if MF is standard, what is it?
    Standard MF and 47% RV
    $4500 incentives
    36 months = .00452 MF
  • CoCatManCoCatMan Member Posts: 2
    edited June 2024
    Greetings, may I have MF and RV for gasoline 2024 Pacifica Limited FWD 36/39 months 10k? Zip 85251.
    Any current incentives? Thank you very much!
    Standard MF and 50%/47% RV
    $3750 incentives
  • LadyMixLadyMix Member Posts: 13
    May I please have the MF/RV/incentives for 24/10 or 36/10 the 2024 Chrysler Pacifica Hybrid Select FWD in 30307?
    Thank you so much for the amazing help!
    There is no Chrysler Capital lease support for the Pacifica, in your region.
    Check with your dealer - they may have other banks to use. But, we don't have those programs.
  • drew_the_bravedrew_the_brave Member Posts: 3
    Could you share MF and RV for 2024 Pacifica Touring L FWD 36/39 month 12k?
    Zip 92833
    Zip 92833
    .00123 MF and 46% residual
    .00081 MF and 43% residual
  • apache137apache137 Member Posts: 29
    Can I get 24/36/39 month options for 12k
    Limited fwd and awd
    Pinnacle fwd and awd
    Pinnacle phev
    Thank you. You have helped me lease a dozen vehicles in the last few years.
    Limited fwd and awd
    Pinnacle phev
    3 terms, 3 trims = 9 sets of numbers.
    Thanks, but we'll pass.
    Can I get 24/36 month options for 12k
    Limited fwd and awd
    Limited fwd and awd
    What is your location?
    Ga 30345
    Limited fwd and awd
    Hmm, that's still 8 combinations.
    Can we pare this down a bit?
    Yes for sure. I apologize.
    Can we do touring L and limited both FWD.
    24/36 12k
    That’s 4 combos I believe
    24/36 12k
    LTD
    27/12 - .00243 MF and 52% RV
    36/12 - .00187 MF and 48% RV
    $500 incentive
    Tour-L
    .00162 MF and 49% RV
    .00123 MF and 46% RV
  • GatornoleGatornole Member Posts: 37
    Hello! Could you please share MF and RV for 2024 Pacifica Touring L FWD 36/12k and 36/15k in ZIP 32311? Any current incentives? Thanks!
    .00123 MF and 44% RV
  • hawkgrl79hawkgrl79 Member Posts: 23
    Hello, can you please share the MF and RV for a 2024 Pacifica Touring L and Limited AWD 12k/36 or 12k/39 months if that's better in zip 50266?
    Standard MF
    48%/47% residual for LTD/Touring L
    $500 incentive on LTD only
    Thanks. What is the standard MF though?
    36 months = .00415 MF
    Can you please share mf and rv for 2024 touring L awd. 36 or 39 10k per year, zip 80206. Any lease incentives? Thanks
    36: .00159 MF and 51% residual
    36: .00412 MF and 49% residual
    42: .00161 MF and 47% residual
    Hello, can you please share the MF and RV for a 2024 Pacifica Touring L and Limited AWD 12k/36 months in zip 50266?
    LTD: .00227 MF and 51% residual. $500 incentive
    Touring L: .00159 MF and 50% residual. No incentive
  • Dan_WDan_W Member Posts: 40
    Hi…
    Looking for MF and residual for a ‘24 Pacifica Hybrid Premium S Appearance please.
    36 or 39 months
    7,500 miles/year (if available….if not, then 10k)
    Zip is 48154
    Dan_W said:
    Hi…
    36 or 39 months
    Zip is 48154
    .00255 MF and 48% residual
    .00247 MF and 47% residual
    $7250 incentive
