2024 Hyundai Sonata Lease Deals, Incentives, Rebates, and Prices
24567
  • MichaellMichaell Moderator Posts: 268,646
    ciachr035 said:
    .00219 MF and 66% RV
    Are the numbers above the for zip code 11581? Thank you
    Same
  • bales75bales75 Member Posts: 3
    edited February 2024
    Hello, can I please get the MF, RV, and any incentives for the N-Line for 46237? For 36/10
    .00251 MF and 69% residual
  • NeuroBossNeuroBoss Member Posts: 3
    Hello. Can I have RV, MF, and cash rebates for 2024 Sonata SEL, 36/10, for zip 92618. Thanks.
    FWD or AWD?
    FWD. Also, do you think these parameters have changed since yesterday because of new month? One of the local dealers was insisting all these would go up because of "new" month. Not sure how true it is. I took it as salesman pressure tactic.
  • RK6308RK6308 Member Posts: 2
    Good morning from MN. Looking for RV, MF, incentives for AWD 36/12 36/15 for zip 55810.
    Question, would some of these values be different if I request zip codes from Mpls/St Paul metro instead of Duluth?
    Also, new lease would be in late June when current SUV lease is up. I'd imagine now vs then could make some difference in all of the variables? Thank you for advice.
    .00242 MF and 67% residual
    Looks like better than last month, by a little
    edited March 2024
    .00256 MF and 65% residual
    Same as Mpls
    1) Little better is due to Residual (66% vs 67%)?
    2) Can these change in the middle of the month?
    Yes..
    Anything is possible, but 99% it stays the same
  • ciachr035ciachr035 Member Posts: 15
    Sorry for the noob question, but could someone explain what we should do with the numbers provided?
    Use this link to start your lease research
  • prm24prm24 Member Posts: 4
    Hello. Can I get the MF,RV, and any incentives for a 2024 Sonata N Line please? 08846 Jersey
    .00251 MF and 66% RV
  • usedsubmarineusedsubmarine Member Posts: 14
    Hi there. May I have RV, MF, and cash rebates for 2024 SEL AWD, 36/12, for zip 46815. Thanks
    I'm not that picky about my vehicle. I'm more picky about how much I spend.
    .00256 MF and 67% residual
    edited March 2024
    Thanks. Is there any major difference for these in the zip code 46060? The RV, MF, and cash rebates for 2024 SEL AWD, 36/12
    No
    Can I please have the RV, MF, and any rebates for Limited Hybrid in 11717?
    36/12k
    36/10k
    36/12k
    36/10k
    .00256 MF and 61% residual
  • Dave MillerDave Miller Member Posts: 114
    Can I get info on the N-Line 36/12, M/F zip 85374
    .00251 MF and 68% residual
  • Rickgrimes2020Rickgrimes2020 Member Posts: 79
    Hi May I please have the numbers for Sel FWD 36/12 or 24 if offered
    15001
    15001
    24/12: .00248 MF and 73% residual
    36/12: .00242 MF and 66% residual
    @Rickgrimes2020 said:
    Hi May I please have the numbers for Sel and LIMITED 36/12 or 24 if offered
    15001
    I and starting to see 2024 HYBRIDS locally. Any numbers yet for those?
    15001
    Which trim?
    Both trims please
    15001
    Either trim
  • MoreIntoAirplanesMoreIntoAirplanes Member Posts: 1
    Hi May I please have the numbers for SEL Cov FWD 36/12. 30080 (Smryna/Atlanta, GA)
  • LcfylesLcfyles Member Posts: 6
    What is your location?
    Zip code 91001. Sorry. And thank you.
    24/12: .00248 MF and 74% residual
    36/10: .00251 MF and 69% residual
  • SuperDuperSuperDuper Member Posts: 21
    Can I please get the MF, Residual Value, & any incentives for 2024 Hyundai Sonata SEL Hybrid and the regular SEL trim for zip 08824 based on 36k lease 10k miles a year? Thank you in advance!
    Gas SEL - FWD or AWD?
    Sorry, FWD, please. Thanks
    Gas: .00242 MF and 67% residual
    HYB: .00256 MF and 61% residual
  • rosboss1rosboss1 Member Posts: 30
    Can I please get the MF, Residual Value, & any incentives for 2024 Hyundai Sonata Hybrid, both SEL and Limited Trims, for zip 85050 based on 36k lease 12k miles a year? Thank you in advance!
    Either trim
  • insearchinsearch Member Posts: 49
    Hi Can I please have RV, MF, and cash rebates for 2024 Sonata SEL 12/36 for zip 68130. Both FWD and AWD if I could please.
    AWD - .00256 and 67%
    FWD - .00242 and 66%
  • 5280guy5280guy Member Posts: 14
    Hi. Can I please have RV, MF, and incentives for 2024 Sonata SEL 12/36 for zip 80020. Both FWD and AWD please. Thank you!
    AWD: .00256 MF and 67% residual
    FWD: .00242 MF and 66% residual
  • 4eddie4eddie Member Posts: 26
    Hi. Can I please have RV, MF, and incentives for 2024 Sonata Hybrid Ltd 10 k/36mo for zip 07407. Thank you!
    .00250 MF and 62% residual
  • Wil101Wil101 Member Posts: 21
    Hi! May I please have the mf and rv for Sel AWD 36/10 or 36/7500
    May I please have the mf and rv for Sonata N-Line 36/12 for zip 11717?
