2024 Jeep Grand Cherokee Lease Deals, Incentives, Rebates, and Prices
1131416181936
  • MichaellMichaell Moderator Posts: 265,315
    Crash2500 said:
    Looking for mf and residual for 2024 GC 4xe overland 36/10, 36/15. Zip 55344
    Also if you don't mind 2024 GC limited 4x4 36/10, 36/15
    4xe OVR - .00251 MF and 51% RV; $9250 incentives
    Gas LTD - .00195 MF and 56% RV; $1000 incentives
  • Crash2500Crash2500 Member Posts: 14
    Sorry. One more.
    Gc 4xe base
  • HawkeyeCubHawkeyeCub Member Posts: 97
    Could I get the RV, MF, & incentives for 2024 Grand Cherokee Limited 4x4 gas for 36/10 for zip code 85255?
    Thank you!!
  • kyfdxkyfdx Moderator Posts: 268,104
    Sorry. One more.
    Gc 4xe base
    .00333 MF and 55% residual
    $9250 incentive
    Thank you!!
    .00195 MF and 59% residual
    $2000 incentive
  • B_ThaxB_Thax Member Posts: 7
    Could I get the RV, MF, & incentives for 2024 Grand Cherokee Limited 4x4 gas and Grand Cherokee Altitude X 4X4 gas for 36/10 for zip code 46236
    In the path of totality!
    ALTX: .00294 MF and 63% residual
    LTD: .00195 MF and 59% residual
    $2000 incentive
  • thehankthehank Member Posts: 99
    Can I get the MF/RV for a 2024 JEEP GRAND CHEROKEE Overland 4Xe and 2024 JEEP GRAND CHEROKEE Summit 4Xe? 36/12 - zip code is 63025.
    Also incentives if any are available! Thanks
    OVL: .00251 MF and 53% residual
    SUM: .00296 MF and 55% residual
    $6750 incentive
  • LibaxLibax Member Posts: 11
    edited April 2024
    2024 JEEP® GRAND CHEROKEE LAREDO A 4X2. MF and RV for 24/12 and 36/12 in zip 22032
    27/12: .00355 MF and 70% residual
    36/12: .00289 MF and 62% residual
    39/12: .00268 MF and 59% residual
  • SnakeOilKidSnakeOilKid Member Posts: 5
    edited April 2024
    Hi there looking for RV, MF, & incentives for 2024 Grand Cherokee 4xe
    Zip 02476
    Summit 24/10
    Summit Reserve 24/10
    30th Anniversary 24/10
    Overland 24/10
    Zip 02476
    Summit 24/10
    Overland 24/10
    There is no 24 month term supported for the 4xe
    27/10
    .00318 and 62%
    .00318 and 62%
    .00362 and 65%
    .00263 and 60%
    $7750 incentives
  • CamkornCamkorn Member Posts: 1
    edited April 2024
    Hi all, can anyone help me out with RV, MF, & incentives for 2024 Grand Cherokee 4xe following trims? Can you also give me some advice how I can use the numbers to negotiate with a broker I am working with?
    11772
    4xe base 27, 36, 39 months. 15k
    4xe anniversary 27, 36, 39 months. 15k
    edited April 2024
    11772
    Either trim
    .00362 MF and 63% RV
    .00333 MF and 55% RV
    .00312 MF and 53% RV
    $7750 incentives
    Now that you have the numbers, you really don't need the broker. Just another step in the process.
  • Jeffk79Jeffk79 Member Posts: 13
    Can I please have the current lease incentives, MF, and residuals for the 4x4 GC 4XE Overland and Anniversary editions? I am in zip code 60453. Looking for 36/39/42 months and 7500/10K miles if you could. Thanks in advance for all your help!
    ANN
    36/10 - .00333 and 58%
    39/10 - .00312 and 56%
    OVR
    .00251 and 54%
    .00229 and 52%
    $6750 incentives
  • carmeldlcarmeldl Member Posts: 31
    Hello. Could I please get the residual, MF and any incentives for 36/12k on the 2024 Jeep Grand Cherokee Altitude X 4x4 and 2024 Jeep Grand Cherokee Altitude 4x4 (if there is a difference between the two trims) in 46062? Thank you!
    62% residual
    $2000 incentive
    ALT: .00291 MF
    ALT-X: .00294 MF
  • Florida_AndrewFlorida_Andrew Member Posts: 8
    edited April 2024
    2024 Jeep Grand Cherokee: Limited
    Residual
    MF
    Incentives/Rebates
    33569
    edited April 2024
    Residual
    MF
    Incentives/Rebates
    33569
    2WD, 4WD or 4XE?
    2-row or 3-row?
    2WD, 2-Row, 39 mo, 10k miles
    Residual
    MF
    Incentives/Rebates
    33569
    2WD, 4WD or 4XE?
    2-row or 3-row?
    Residual
    MF
    Incentives/Rebates
    33569
    2WD, 4WD or 4XE?
    2-row or 3-row?
    .00176 MF and 56% residual
    $1750 incentive
  • ErlexxErlexx Member Posts: 50
    edited April 2024
    Hello, Could I please get the MF, Residual, and any incentives for a 2024 GRAND CHEROKEE LAREDO X 4X4 as well as the 2024 Grand Cherokee Altitude X if there is any difference in the Trim numbers.
    36/10k
    36/15k
    Also any other special lease duration/miles that may be available if any.
    Zip 40475
    Erlexx said:
    Hello, Could I please get the MF, Residual, and any incentives for a 2024 GRAND CHEROKEE LAREDO X 4X4.
    36/10k
    36/15k
    Zip 40475
    .00276 MF and 58% RV
    $2000 incentives
    36/10k
    36/15k
    Zip 40475
    $2000 incentives
    You beat my edit! Could I also get the same for 2024 Grand Cherokee Altitude X
    Erlexx said:
    36/10k
    36/15k
    Zip 40475
    $2000 incentives
    Same for that trim
  • zeke29zeke29 Member Posts: 1
    Looking for MF/ Residual / Incentives for 2024 Grand Cherokee 4xe Anniversary Edition
    39/12
    39/10
    Zip: 19460
    39/12
    39/10
    Zip: 19460
    36/12 - .00333 MF and 57% residual
    39/12 - .00312 MF and 55% residual
    $6750 incentives
  • PwheelsPwheels Member Posts: 19
    Hey there looking for MF/Residual/Incentives on Grand Cherokee LIMITED 4X4 at 36/10 in 45237
    Also looking the same on ALTITUDE X 4X4 at 36/10 in 45237
  • ZipsterfastZipsterfast Member Posts: 8
    Can I get a MF/Residual/Incentives for Summit and Summit Reserve in 21209. 36/10 & 36/12
    ALT/X: .00294 MF and 63% residual
    $2000 incentive
    .00206 MF and 56% residual
    Either trim
  • MiguelSTMiguelST Member Posts: 19
    Hi! Could i please get Residual Value, Money Factor and lease incentives on a Jeep Grand Cherokee 4XE, Summit and overland trim, 36 mos. 10k miles?
    Best,
    Miguel Titarelli
    Best,
    Miguel Titarelli
    Zip code is 80498
    Best,
    Miguel Titarelli
    OVL: .00251 MF and 54% residual
    SUM: .00296 MF and 56% residual
    $9250 incentive
    Can I get the MF RV and Incentives for 36/15 on 2024 GC 4XE Base and Trailhawk please?
    Zip 40475
    Zip 40475
    Base: .00331 MF and 55% residual
    TH: .00323 MF and 53% residual
    $6750 incentive
  • dieselco23dieselco23 Member Posts: 1
    AM looking at leasing a 2024 Jeep Grand Cherokee 4xe Anniversary Edition 39 month/10k yr
    Hoping to get MF, RV and Incentives as every dealer out here has given me totally different information!
    Zip code 80206
    Zip code 80206
    .00312 MF and 56% RV
    $9250 incentives
    Jeep dealers have several banks to choose from; we only have the numbers for Chrysler Capital (CCAP)
  • stevegrazianostevegraziano Member Posts: 62
    Hello, could I please have the mf and residual for the 2024 GRAND CHEROKEE LIMITED 4X4 and the 2024 GRAND CHEROKEE ALTITUDE 4X4. 36 and 39 months. 10k miles. 02066 Zip.
    Also, any incentives?
    ALT
    .00291 MF and 63% residual
    .00273 MF and 61% residual
    LTD
    .00176 MF and 57% residual
  • a421a421 Member Posts: 46
    Looking for MF, residual and incentives for
    Jeep Grand Cherokee 4xe trailhawk, overland and base
    36/12k
    Zip 89141
    36/12k
    Zip 89141
    Base: .00333 MF and 57% residual
    TH: .00321 MF and 55% residual
    $6750 incentive
    $6750 incentive
    What about for anniversary edition? 36/12k 89141
    $6750 incentive
    Same as base
  • mojomikemojomike Member Posts: 16
    Looking for MF / Residual value / incentives for 2024 Jeep Grand Cherokee 4xe Trailhawk 27/10 and 36/10. Zip 92037. Thanks
    .00357 MF and 62% residual
    .00321 MF and 56% residual
    $6750 incentive
    36/12k
    Zip 89141
    What about 24/12k for trims? Ty
