2024 Mercedes C-Class Lease Deals, Incentives, Rebates, and Prices
135678
  • MichaellMichaell Moderator Posts: 271,081
    So to confirm based on an earlier response, C300 Sedan RWD 36/7.5 and 36/10 in 92679 both have an RV of 61% and MF of .00201, no diff between the 2 mileage bands?
    Where in my response did you deduce that? You asked for the 7.5K mileage, and that's what I provided.
    Subtract 1% for 10K
  • mjw313mjw313 Member Posts: 10
    Hi, can I please have RV, MF and any incentives for a 2024 C300 Sedan RWD 36mo/7.5k miles in 92618? Thank you!
  • kyfdxkyfdx Moderator Posts: 276,206
    .00201 MF and 62% residual
  • bmwagainbmwagain Member Posts: 25
    Good afternoon, I apologize if this under the wrong heading but didn’t see any 2024 CLE topic. Can you please provide the MF, RV and incentives for the 2024 CLE300 AWD Sedan for 24/10K and 24/7.5K in 15301? Thank you
    Please repost into our new 2024 CLE discussion
  • nycdompnycdomp Member Posts: 30
    Hi Michaell,
    Could you provide me - 2024 C300 4Matic 36/10K - 11021 and if any loyalty / incentives.
    nycdomp said:
    Hi Michaell,
    Which body style?
  • BuckeyekingsBuckeyekings Member Posts: 6
    Hello. Please provide mf and rv for 2024 c300 4matic sedan 36/12 and c43 amg sedan 4 matic 36/12. Zip code 78259
    300: .00201 MF and 60% residual
    43: Standard MF and 61% residual
    nycdomp said:
    Hi Michaell,
    Which body style?
    Sedan, thanks!
    nycdomp said:
    nycdomp said:
    Hi Michaell,
    Which body style?
    Sedan, thanks!
    .00201 MF and 61% residual
    No info on loyalty
    nycdomp said:
    nycdomp said:
    Hi Michaell,
    Which body style?
    Sedan, thanks!
    No info on loyalty
    Thank you for this!
  • jliaojliao Member Posts: 6
    Hi, I'm looking for numbers for a 2024 c300 sedan 4matic white, in 21042, 36mo/10k. Thanks!
  • die4valordie4valor Member Posts: 35
    Hi - Can you please provide JUNE MF and RV for 2024 C300/4Matic sedan 36/10 for zip code 10128. Thank you!
    June programs start on Tuesday
    Thanks. Please let me know when you have an update!
    thank you!
  • mayan50mayan50 Member Posts: 24
    thank you!
    Did this residual go down a point from May?
    thank you!
    I don't know. Feel free to scroll back through the discussion. Rates are nationwide.
  • JD187JD187 Member Posts: 8
    Please provide the RV MF and any incentives for a C300 4matic sedan in PA for 12/36.
    .00201 MF and 59% RV
  • aserianniaserianni Member Posts: 10
    Can I get the MF, RV, and any incentives for 2024 C300 4matic and AMG C43, 36/10 and 36/12, for zip 11374. Thanks in advance.
    Which body style?
    I presume the AMG line body package is what you're referencing, then yes with that option.
    Sedan, coupe or convertible?
    Sedan, sorry I didn't know they made it in a coupe or convertible. I thought the CLE is the only coupe or convertible option anymore for the C class. Am I mistaken?
    I don't know.
    So, do you want sedan, coupe or convertible?
    Sedan, as it's the only option. There is no C class coupe or convertible for 2024.
    300 - .00201 MF and 59% RV
    C43 - Standard MF and 60% RV
  • SRPA305SRPA305 Member Posts: 11
    edited June 2024
    Could you provide me with lease terms for 2024 C300 4Matic 36/10K - 15106 and if any loyalty/incentives.
    $2000 loyalty
  • FrumpDingoFrumpDingo Member Posts: 3
    Can I please get RV and MF on a 2024 C43 and C300 sedan for 36/10k in 03060? Thanks!
    C300 - .00201 MF and 60% RV
    C43 - Standard MF and 61% RV
    Can you please explain what Standard MF is? Thanks!
    Tier A1 - .00295
    Tier T1 - .00325
  • evadivvaevadivva Member Posts: 3
    Can I please get RV, MF, & incentives on a 2024 C300 sedan for 36/12k in 19153? Thanks!
  • jmbgatorjmbgator Member Posts: 1
    Hi. Could you provide me with lease terms for 2024 C300 either 36/12K, or 42/12K in zip code 33134 and if any loyalty/incentives? Thanks!
    .00201 MF
    59% or 53% residual
    $2000 loyalty
  • BI4UUNBI4UUN Member Posts: 22
    Hi Michaell and kyfdx, happy July 4th! May I have the lease terms for 2024 C300 either 24/7.5K, or 36/7.5k in zip code 78753 and if any loyalty/incentives? Thanks!
    .00201 MF
    69% / 61% RV
    $2000 loyalty
    Are the current MF and RV on the C300 4Matic sedan going to be in place for the remainder of July?
    Through the 31st..
    edited July 2024
    Can you provide the lease terms for 2024 C300 4Matic 36/10K - 15106 and if any loyalty/incentives.
    $2000 loyalty
  • Mdel33029Mdel33029 Member Posts: 1
    Hi. Could you provide me with lease terms for 2024 C300 either 36/12K, 42/12K and 48/12Kin zip code 3302O and if any incentives? Thanks!
    .00201 MF
    59% / 53% / 48% RV
