A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Can I get from any auto part store?
Does It work?
How would I use it?
I would like to use it to cleaning my car engine.
Ray
Here's question.....don't laugh....
1. Will it hurt to switch to 5w30 after using 10w30 for 29000 miles.
2. Is 5w30 thinner...thereby possibly causing leaks? How thinner is it?
Thanks...
John
Probably you know the answer?
I understand, that the Amsoil 0w-30 is a bit more expensive than the 5w-30 or 10w-30, but with the Mobol-1 the price is the same: $4.49 a quart +tax at our local Pep Boys.
With two or more cars in family it would be less headache to use every time the same oil. Just buy it, bring to the station, and never think again.
For example, the Chevy Malibu manual recommends 5w-30, while the Buick Regal likes more 10w-30. To complicate things, Buick also recommends 5w-30 for colder times, when the temperature is below 60F, Chevy recommends 10w-30 for very hot weather, and the both cars recommends 0w-30 or synthetic 5w-30 for the really cold weather.
As a rule, the winters are not so cold in Connecticut. Very seldom the temperature falls below 0F: this is warm enough even for 10w-30, while only marginally. But things happens.
By the way, all stations I know in the neighborhood are using 10w-30 dyno, usually Kendall, not depending on car nor season. Bring your own oil (and filter), if need or want something less standard.
Today's engines are tight tolerance because of improved contruction techniques. Because everyone wants better gas mileage and want more power from existing engines or new engines. A decent 5w20 oil today is better than a 10w30 or 40 of ten years ago in its ability to keep an engine lubricated. Anyone who ignores the manufacturers recommendation is just asking for misery. Poor gas mileage, more engine wear and a 'we don't pay for failure to maintain the engine properly'. If the recommended oil is not available commercially, the manufacturer must, by law, give you a reasonable alternative.
Your schedule is truly unique, where did you learn of that frequent an oil change schedule?
I don't know why the Mobil 1 0W30 is not used more, perhaps fear of the lower #. The 5 and 10 have flow points down to minus 50 or so and it may not make much diff.
For that reason, I would skip the 2k change and do my next change at 3k (followed by 6k etc) if I were you. If you are concerned about metal particles in the oil, you might consider replacing just the filter at 2k and then change both filter and oil at 3k.
Incidentally, you may void your warranty if you go longer than the manufacturer's specified interval. For example, my new Ford specifies every 5K for normal duty, 3K for severe. If I use syn oil, and do every 7,500 miles, Ford could very well refuse to honor warranty if engine repairs are needed later. And, according to many sources I've seen, syn oils protect better but do not extend the allowable time between changes. Just as with dino, syn oils contain additives which break down over time. In other words, buyer beware. Don't always believe the hype you hear.
And, for my money, initially changing the oil more frequently and then sticking to the manufacturer's schedule is cheap insurance.
I would consult your owners manual on this. I thought more manufacturers are recommending this.
All motor oils have various additives to the base stock. These additives serve many purposes from dissipating dirt to viscosity extenders. Your base stock can only carry so many additives in suspension. If you have a higher quality base stock than you can lower the amounts of certain additives and increase the amounts of others. This is where synthetic gets its advantage. As an example, the base stock is so good that it needs less viscosity extenders added. This allows an increase in the additives that dissipate dirt. That is one of the reasons that synthetic can handle extended drain intervals. Whether you extend those intervals is obviously up to your comfort level.
As a nation, we use a lot of oil. Much goes into sewer systems and ground. Now, comsumption favors the oil companies, distributors and lube places as well as car dealers. This is steady income. But, if I had reliable information about the effects of extended drain intervals on driving similiar to mine w/wo synthetic oil then I would go with the least expensive, least hassle method of maintaining my cars. I have a 98 Camry V-6 and a 00 Lexus RX 300. I do oil changes in both by myself. I favor Mobil 1, 0w30 and favor 6,000 mile intervals to offset the product cost.
Mobil once bragged of 25,000 mile changes. My information is that Europeans favor Synthetic for reasons I mentioned and even go longer. My guess is that 10,000 intervals with synthetic oil and a premium filter (very critical) are perfectly safe for normal driving. I do mine as stated to preserve my 6 year powertrain warranty--which most likely will never be a problem--but.
INKY
As to concerning car dealers, I have serious doubts. With higher labor costs (and the "genuine" manufacturer filter/oil), the service, most probably, is not profitable to them.
What the oil change does provide to dealer, is a steady inflow of customers. The customers, sooner or later, will need a more serious services and/or repairs, and the majority of them will do it at the same dealer.
Or even, while waiting for the oil change, the customer will visit a showroom - and, later, will buy a car from this dealer.
As an example: The local Firestone car service station at Hamden, CT, changes oil for $9.99, with coupon. This includes labor, up to 5 quarts of oil and filter. About $13 total, including taxes and the state disposal fee. Additionally, the station mechanics are inspecting the car for free with the oil change (the courtesy service for the AAA members, i.e. practically to almost everybody).
For me it looks as an obvious "lost leader". The real business they do on the subsequent repairs, due to customer loyalty. And the courtesy inspections helps too - it is a good occasion to show the customer the obvious problems with his car.
INKY
Any comment?
Many cars in Europe specify oil changes at 10,000 or 12,000 miles. I used to use Mobil 1 in my VW and changed the oil at 15,000 miles. 140,000 miles later still no discernable oil consumption between the 15,000 mile changes.
I am not sure what is going on on Mobil 1 oil grades. IN Europe, Mobil 1 used to be 5W50 and after a reformulation about 4 years ago it became 0W40. When I arrived in America 2 years ago I find Mobil 1 available in various grades but none that would appear to compare with 0W40. Why the heck would anyone want 10W30 ? What's wrong with 0W30?
INKY
1. Advance Autoparts
2. Pep Boys
3. Walmart
Many many garages seem to get great deals on Pennzoil, especially the weird weights like 15W40.
Just ask Wall Mart what oil it uses? Havoline I believe also will package under the Pep Boys label and perhaps a few others.
INKY
John
On the other hand, Puralator advertises that its premium filters, the "Pure One" brand, have the highest multi-pass efficiency. And that the multi-pass tests better reflect the real life needs. The engine oil is being filtered constantly for months, not only once (single pass).
I believe the both filters, and other premium filters, are much better than the stock ones. Am not sure, if the ultimate difference between the the premium filters is important.
I do not hope to run my cars a million miles. Most probably, they will die from age (gaskets, seals, bushings, wires, etc.) long before the engine would wear-down. With any brand of premium filters. And, possibly, even with cheap ones.
"Recently, Ford and Honda announced that they will be factory filling their 2001
model year
vehicles with 5W-20 viscosity motor oil. In addition, both Ford and Honda will
be
recommending 5W-20 in their owner's manuals and on the filler cap.
In an effort to meet the needs of the industry and our consumers, Castrol will
launch Castrol
GTX 5W-20 in early 2001, which can be purchased where other Castrol motor oils
are sold. As
always, Castrol GTX 5W-20 will be formulated to provide maximum protection
against viscosity
and thermal breakdown".
Arnie
Later, guys
I had oil changes done at my Nissan dealer twice and both times they filled oil to about an inch over the MAX marking on the dip stick. The 2000 Sentra has only 5,000 miles now. The oil warning light never came on during this time. Do you think some damage could have been done to the engine?
If the oil starvation occurs from foaming, will the oil warning light come on?
By the way why do so many places tend to over fill oil? It's a waste of resources and money.
But I'm curious as to how much damage it causes?
I've heard its not good..
Odd, they are throwing away money.
Recently, I was browsing through one of the Auto repair for Dummy books, the author claims that the 7500 miles is just a ploy by the auto company to wear out your car prematurely so you'll buy a new car. Is there any truth to this claim? I certainly have seen no evidence of this any where.
In any case, can someone point me to studies on oil change intervals? The only study I have seen is the Test on Taxi done by Consumer Report. Several posters have pointed out the short-coming of the CU article. I was wondering if there were other articles.
Paul
Al
for some (many) messages about placemarks and posting problems.
Pat/Roving Host
adc100: My 83 F150 called for 10w40, my 91 called for 5w30. The new requirements are because of tighter tolerances which comes from improved technology. I realize that GMs would not use the new oil because they have too much slop. My 83 is still being used as a backup for some in-laws that insist on having chevies and my 91 is still running as peppy as day 1 with 175K on it. The only problem with recommending 5w20 is that it is not readily available yet. Probably in 2-3 years, it will replace 5w30 as the de facto oil viscosity.
Later
