Visitor Agreement.
INKY
Later
Changing dino oil gets rid of it.
Long syn changes leave acid in to eat the engine.
Thats why I use dino.
Later
I'm not a mechanic, but I've never seen a car using 20W50. Dealer said because the Suzuki V6 runs hotter than typical engines (around 200F). I'm now using the 20W50, and it's as loud as ever (it almost sounds like a diesel...)
Should I switch to the synt now? Do I need to flush the engine? I'm thinking of doing it myself instead of paying $60 to the dealer for this.
vehicle has hyd. lifters and they were the noise
you heard than the 20w50 would have had some
effect.It sounds like you have more mechanical
problems other than lifter noise,can you take the
vehicle elsewhere and have a different mechanic
diagnose the noise?
For our first car, the Buick Regal with 3800 V-6, GM recommends 10W-30 at summer (above 60F), the 5W-30 at cold winter (below 0F), and either 5W-30 or 10W-30 between 0F and 60F. For the second car, Chevrolet Malibu with 3100 V-6, GM recommends 5W-30 for both summer and winter.
GM recommends using either synthetic 5W-30, or 0W-30 for extreme climate only. Not applicable to my Connecticut.
Harry
Everyone save your money. Synthetic is a big waste of money. Just maintain your cars according to schedule, together with proper warmup of the engine, and everything will be fine.
I was wondering, do both of your cars have the same engine type and have been driven in similar manners and conditions? Just wondering if we are comparing apples to apples or apples to oranges.
A 5w30 vs 10w30 noise argument is not valid because the only difference is immediately after startup. The big possiblity is that after changing to synthetic, you were real sensitive to the engie noise and that translated into a perception of noisier.
The advantages of synthetics are based on the individual. I would not be so inclined to use synthetic if I still changed oil every 3k. Every 7500 miles is a decent compromise because it still falls within the manufacturer's recommendations, reduces my cost and time and gives me the advantages that may come with synthetic. Extending past the manufacturer's recommendation is a sure way of having grief if a problem arises. You may win in court, but in the long run the only winner is the lawyers. My faith in the "you can go 25,000 miles without an oil change" claimers are the same as those who had a carburator that could go 100 mpg.
One last thing; when an engine cools off, moisture will condensate in the engine. This moisture will mix with the oil, reducing the properties of the oil, whether synthetic or dyno. If a car owner does at leat one trip every 2-4 weeks where the vehicle gets 30-40 miles of continuous operation, this does not become a problem. Ten miles does not cut it! You must get the engine hot enough and long enough to burn off the water. Going too long with only short runs will cause many potential problems. I would not recommend synthetic to a person that only drove 3-5K a year because the moisture buildup is more of a problem. That is why they add the 3-6 month time periods in the recommendations.
It goes to show that dealers are always out to get your money, even if with warranty... They wanted to sell me the Synt oil, which I'll probably do any way, but I'll do it myself rather than pay them $60... Thanks.
If you look in the service manual I think the lightest oil Nissan
recomends in that engine is 10w/30. Depending how many miles
on it and where you live you could use 10/40. I use durablend
15/40 during the summer and it works great. No oil leaks and
the engine runs quite. Just and idea.?
I've been using Amsoil for 7 years.
Later
Just to be even more safe. And in the dusty conditions cut those intervals in half.
BTW, why do you think that "this method ensures that all internal parts are well mated to each other."?
Hope this answers your question.
But my question was in relation to your mileage table.
I have a new Buick Regal, a 2000 model. Its manual recommends not driving at constant speed for the first 500 miles. I believe, this is for break-in.
Is it true that a slightly dirty oil filter will filter better than a perfectly clean one?
What is the minimum warm-up time during the winter? Say around -10C (15F)
I'm set in my choice when it comes to oil and filters, so please don't go hyping up your brands to me.
Basically, any oil that will get into the pan will do so whether the plug is installed or not. So you might as well drain the oil when its hot and let it drain over night (if that's what you want to do). By letting the oil cool, contaminants that might otherwise be drained with the oil will have an opportunity to settle on the bottom of the pan and NOT get removed when you drain it the next morning.
come again???
-Chris
viscosity matters... dino vs. syn doesn't... slipperier, indeed...
beware what you read on the net...
-Chris
bnormann
Maintenance & Repair Message Board
Much slipperier!!
ha ha ha,almost choked on my Pepsi on that one.
-Chris
ps. how's the porsche in the winter? or is it hibernating?
perhaps "dino" is not the same viscosity as slipperier what ever that is???
Rule 1. you can not compress a liquid.
Rule 2. Any liquid of the same slipperier/viscosity will produce the same pressure running through the same pump.
Rule 3. If there IS any variance in all things equal, it is clearly due to Moron A , and Moron B, being both wrong!
Consider it a public service. Von Dervare
Viscosity is the oils ability to flow (BASICALLY). I have no patience to go into it further right now.
Has nothing to do with it's ability to lubricate.
As was said,viscosity and bearing clearances are what affects the oil pressure. For every thousandths of bearing wear, there is a 20% decrease in oil pressure.
If a person wants to promote synthetic oil,there is a topic for it.
But to say that oil pressure drop is normal because it is synthetic is not accurate. Oil pressure drops because of ONLY 2 things,
a loss of viscosity or clearances(whether oil pump or bearings) becoming looser.Plain and simple.
