Visitor Agreement.
vonder ... you're kidding... someone actually posted that for real? how did i miss that?
-Chris
Heidi
-Chris
Jim
It sounds like the Great synthetic oil everyone talks about has flushed some gunk into the relief of the oil pump and is causing it to stick.
BUT,have a manual oil pressure guage put on it to confirm the oil pressure.
It may be that the oil pressure sender wire has come loose or the sender is bad. A direct ground of the wire will peg the guage.
div2,
The video you are talking about deals with 10w30 oil and if you are running at -10F you wouldn't be running that oil anyway.
And it also shows the oil pressure below 40 psi, which couln't happen, the oil pressure in that situation would be near 80 psi.At 40F,the oil will work in seconds to get through the entire system.
I'm sorry, but the brand name oils (Chevron,Valvoline and others) will adequately lubricate the system without any damage to the engine. Most of the time, the serious damage results from someone believing what the snake oil salesmen tell them and they ignore the basic maintenance schedules.
Thanks again. . .hs
I believe, though, the synthetic oil is listed on the sticker, as with other options.
BTW, this monthly auto care column would be where? I'd like to see it.
But I'm with 0patience on this one; plain old dead dino for me, thank you. I got 17 winters out of one car and 10 from another cold-starting in Anchorage using non-synthetic stuff. Maybe if I lived in Fairbanks or Duluth....YMMV.
Steve_
Vans and Aftermarket & Accessories Message Boards
BTW,
the AlCan highway was not near as nice as it is now.
not for everyone,driver #1's cost effectiveness
is not the same as driver # 2's.
I also agree that Opaitience puts down syn oil
every chanece he gets,an example being post 369
the bold type "great" oil is now the culprit of the writers problem.
It's true this is not the syn.oil forum it is
the engine oil forum,but that does not mean we
can never talk about syn. oil here as syn oil is
still engine oil.
So, the biggest benefit to me is the extended drain interval, that more than makes up for the cost.
I can remember non-detergent 30W for air cooled V W Bugs no blend, just 30 viscosity (weight to me)
The fork oil for my motor bike is 10W, so how the hell does that make sense? It is damn near 0 degrees F. here right now, and I'm to much woosie to ride! But it is nice to know that oil will flow as a 10 viscosity (weight) in winter I guess.
The 80W-90 in that bike (differential gears) presently resembles glue, as cold as it is.
One thing that gets me is why does my Volvo with out over drive want 80W-90 gear oil in the tranny, when my Volvo with over drive wants auto tranny fluid?
Same gear box,the only difference is the over drive unit??????
He's not an engineer, and this is all heresay:-)
Steve_
If you'd like to check to see if this is the problem, post me a message here with your email address and I can email you the test procedures to check if the unit needs to be replaced.
Campo57
I figure that it's a pretty good high heat condition test to sit in bumper to bumper traffic
when the air temp is 105 degrees.
Is there any true to the story that synthetics should stand up better under these conditions?
(1.) What synthetic oil to use - 5W30 ??
(2.) Should I drain out the oil that comes from the factory and use the Synthetic oil before driving off from the dealership ?
(3.) If not, should I wait until I break in the engine (1000 miles) before changing to the synthetic oil ?
(4.) Someone suggested that I completely flush out the existing oil before adding the synthetic oil. Is this a special procedure or just a normal oil change ?
Appreciate any feedback.
1) Use the same weight oil as recommended by Toyota. The only possible variation on this would be if, say, 5W-30 was for temps up to 90 degrees F, you could go higher with synthetic. A synthetic oil will lubricate properly over a greater temperature range (high and low) than regular oil.
2 & 3) The oil that comes in the engine from the factory is perfectly good. I would leave it there for 1000 miles.
4) According to the information contained on the web sites of producers of synthetic oil, synthetic and conventional oils are compatible. So there is no need to flush the old oil.
To Sienna owner, 500 -1000 miles, no flush, same weight as specified in the manual and use Mobil 1, Amsoil or Redline with Mobil 1 or Amsoil or Pure One filters. Yes they are better then the OEM, my oil analysis shows it!
http://www.synerlec.com/faq.html
INKY
Where did the info come from that Royal Purple was not 100% synthetic? I don't use it, too hard to find and expensive but I am curious.
If your street products are not 100% synthetic, why are they priced similar to a full synthetic?
The Synerlec technology provides the best protection and performance increases available, however, it is very expensive. We have blended our street oils to exceed the performance characteristics of any other blended or "Full" synthetic. If having a full synthetic is important, we have our racing line which can be considered a "Full" synthetic.
They say it isn't full synthetic.
Later
Al
Later
Al
I'm know it offers superior protection, and I dont question that, but will you own your car long enough to reap the benefits? If you will own your car 25 years or more its a mute point but most people dont own their cars that long. I'm bringing this up again because I'm a long oil change interval person. 6000-7500mile changes with regular dino oil (no additional filter changes either). Never had any engine problems. Driving an 89 Taurus right now that has 140k and still gets close to 30mpg on the highway on 6000 mile changes. No engine problems ever. All but one of my cars were traded in at between 140k and 180k or 5-10 years old (except the Tarus which I'm keeping until it dies). Engines running perfectly when traded/sold/given away. Remember, I'm not questioning the merits of synthetic oil itself, rather the reason for using it....to extend the life of the car. That is why people use it, right???
If I did use synth I would probably go 25-50k miles per change and just change the filter a couple of times. It would save a ton of time.
OFF TOPIC:
My big question is how to I keep transmissions from breaking down? Thats where I've been thinking of going with synth. Thats usually been the reason I have had to trade cars in. Engines seem fine on long oil change intervals. Transmissions on the other hand are a little weird. I have tried 15k intervals and 30k intervals and they work about the same. At around 100-150k the transmission starts to die. My sister owned a car where she NEVER changed the transmission fluid and still got to 140k before it was traded. I dont have the guts to try that.
On the tranny side, again, cold climates a definite plus. I have used synthetic and do in my trannies but the longest test I have is 130,000 miles so it still does not meet your standards. I think tranny components simply do not last long beyond 100,000-150,000 miles regardless of what you use. And, synthetic transmission fluid is significantly more expensive then dino and if you get it flushed to get all the fuild you are talking 7-10 quarts versus a drain of 3-5 quarts. I use the drain and fill myself, flushes scare me.
Later,
Al
Thanks for the help in advance.
timmyg
Later, Good Luck
Al
Bill
Switched at 30,000 and at 50,000 oil seepage will occur about a year later (when crap from dino oil has been cleaned off) , usually valve cover or oil pan and torqueing the bolts usually stops it. On cars switched at 1000 miles seepage occurs around 90,000 miles. Same areas, Would seepage occur anyway, who knows.
Seepage is defined as wet area, drops of oil forming but never really leaking on to ground or even seeing spots on the driveway. Not a major issue or requiring any repair work to date.
You wont be sorry switching,
Al
I've home-tested synthetics on quite a few of my cars, and my personal results seem to indicate that there is a little bit of improvement in fuel mileage, but not enough to be statistically significant (.5 of a gallon per mile in winter). Best thing was much faster warm-ups. Also, I stretched the oil changes to 5K w/ synthetic, so that was convenient, and thus evened out the cost versus regular oil changed at 2,500.
I'm not a big fan of believing that if the oil looks clean, it's just fine...I go by mileages.
RE: engine life---my research so far shows no "real life" evidence that using synthetic is going to extend your engine's life per se...good care and good driving habits are the key, with or without synthetic.
The benefits of synthetic over regular oil are, IMO, a matter of DEGREE, not a quantum leap, as say for example the benefit of radials over bias ply tires.
You pay a little more and you get a little more. If you want miracles, try prayer.
