--- Bror Jace
The most recent oil (for the past 3 years or so) was Castrol. I have changed 3 different synthetics over the life of the car. ALthough I tried to stay with one, this proved to be impossible since the first oils I used were not always available. I have to check my records to be precise as to their brands. But this is my also my point I believe. I just think that the oil is one part of the equation.If you check the discussion on "low oil pressure" you will see that as of last week I left synthetics for a heavier weight oil because my oil lamp came on. As it turns out it my pressure was fine, but my sensor was not. I might as well stayed with my synthetic but to be honest, I don't think I want to spend more money that necessary on this car.
As for my MX-3, it was the 25th anniversary edition. I spent a lot of time maintaining this thing properly, but to no end.It started to burn oil at 50,000 KM. it was scrapped at 150,000 Km when someone ran over me with a pathfiner, but at this point the idle was terrible, it was burning 2-3 litres of oil between changes etc... It turned out to be a blessing that it was in an accident becuase I would of had to rebuild or change the engine. The peripherals on this car were also a pain. Bearings, steering [non-permissible content removed]/lies, suspension you name it.
BTW, I do a lot of driving including city. The Subaru has seen everything although I did admit most of it was highway
Amsoil had a similar recommendation at one time, I think, but recommended adding an adapter to allow a second filter, and changing one of them each time at the service interval, alternating the one changed.
My question is, does anyone know why fossil based oil is completely changed rather than using a "change the filter and add a quart" technique, and if synthetics could be done this way using the vehicle's normal single oil filter without endangering the engine, or is there a break down of some type, like detergent qualities, in them, too?
Synthetic oils depending on the application can last anywhere from 3 to say 10+ times as long as conventional oils because their oxidation rates are way lower.
As you may have read on this board or on the synthetic board oil analysis is the main tool to tell you how long an engine oil is doing its job. I know this guy who was an Amsoil dealer 10-15 years ago and even though he did not have the second filter on went over 50 miles between changes. Last I knew him he had over 150K on the vehicle. I'm really not sure how long the additives last. One thing which occurs is the TBN (total base number) goes down as the oil becomes acidic and etches moving parts in the presence of moisture.
In a sound engine engine you should easily be able to go a year with a filter change in between with any good quality PAO synthetic oil. But oil analysis could back this up. Personally I go 10 month in one of my vehicles and 12 in the other. I'll probably do the 7500 mile gig on my new one though.
Your service story sounds like a fish story unless the one oil was syn or the guy didn't know how to use a mic. More evident would be the wear on the cam lobes.
Most people don't keep their cars long enough to ever prove one way or the other if a synthetic oil alone would extend your engine's life. Even large fleet owners who have had good luck with synthetic oil are also throwing in lots of other variables, like regularly scheduled maintenance on all engine components.
If you don't check and replace belts and hoses, or flush your cooling system, or you don't check your dash gauges often, or you drive carelessly, all this would affect engine life.
BTW Mr.Shiftright..you should have that info by Sat. Have a good holiday.
This is not to say that dinos can't do the job, but why is Mercedes suggesting to customers that they use synthetics exclusively? They must think there is some advantage to make this request.
Mercedes-Benz USA, LLC
A Daimler/Chrysler Company
March 27, 2001
One of the many benefits of owning a Mercedes-Benz is the confidence that comes from knowing your vehicle is backed by some of the world's best automotive engineers. Of course, another is our desire to make sure you continue to get superior performance as long as you own your Mercedes-Benz. For that reason, we ask that you review and follow the two recommendations below regarding the maintenance of your vehicle.
Mercedes-Benz now recommends pure synthetic motor oils.
Based on vehicle performance testing, our engineers have concluded that for vehicles equipped with flexible Service System
(FSS), continued optimal engine performance at service intervals called for by FSS can only be maintained through the
Consistent, long-term use of pure synthetic motor oil.
For that reason, pure synthetic oil is now the only engine lubricant recommended by Mercedes-Benz for 1998 and 1999 model year vehicles equipped with FSS While conventional oils deliver reliable performance, pure synthetic motor oil is engineered to flow faster than conventional oil, thus lubricating your engine more efficiently. Switching to pure synthetic motor oil at your next oil change will allow your engine to perform at its peak
Among the brands of synthetic oil we suggest are Mobil 1, Valvoline, Castrol and Shell. Detailed information on motor oil for your vehicle can be found in the endorsed Mercedes-Benz Factory Approved Service Products booklet
So, if you are currently using one of the recommended brands of pure synthetic motor oil in your vehicle, please continue to do so following FSS-recommended maintenance intervals. If you are using conventional oil, we strongly recommend that you switch to pure synthetic oil at the time of your next FSS scheduled maintenance interval.
Mercedes-Benz - registered trademarks of Daimlerchrysler AG. Stuttgart, Federal Republic of Germany
http://www.autotruck.net/ms/archives/1998/1198/1198bnz.asp
Here's another definition:
http://www.mbca.org/MBCA_flexible_service_system.htm
It's basically an oil monitoring system (probably like GM's, although I would hope more sophisticated) that encourages extended drains.
So it sounds like MB is trying to cover all bases/liabilities by recommending synthetic oil for anyone who is going to take a leap of faith on very long oil change intervals by religiously adhering to FSS.
In other words, MB is saying that they believe that synthetic oil will do a better job with extended oil change intervals, but that if you don't extend them, the implication is that regular oils are fine.
I would basically agree with all that if I'm reading what I think I'm reading.
The principle of what they are doing is somewhat troubling though. It's very similar to Ford's misdesign of their origional 2.3L engine where clearances and Lobe material were incorrect. They covered it up (in my opinion), by telling the consumer to use this "special" ford oil. That was their '74 model (Pinto). I have often wondered if the oil was synthetic oil!!! Again, one of the reasons I don't always believe that dealers/companies always have my best interests at heart!!
Well, if it all works out in the end, I guess that's the way we're going, whether we like it or not.
My main objection to extended oil change intervals has always been the same. you need to have a human set of eyes, ears and hands in that engine compartment and under that car more often than every 15,000 miles in my opinion.
That is why I always keep at least 4 different brands on hand and mix them all. Look at penzoil their oil is dark and looks dirty, looks like their working off used oil. Some oils are clear as water. I always blend 1 synthetic with 3 or 4 other brands. I have done this to all my used cars and I have never experienced any so called wear and tear problems.
Did it to an 86 turbo coupe, bought it with 65,000 miles and sold it with 190,000, absolutely no signs of engine wear. Did it to an 89 sable and sold it with 150,000...again no engine wear damage. And now I am applying the same method to my 1994 STS to preserve some serious engine hardware.
Who knows, maybe all oils all are alike, most people believe all gas is the same with a name brand or the discount leaders sold by Costco, Chubbs, East Coast, Crown etc.e tc.
1. In July, there will be a new SL oil classification. The SJ will be gone.
2. Quaker State now makes a 5W-20 weight, but in order to reduce wear it is sold only as a synthetic blend. It conforms to the new SL classification, even though it is not listed as such right now.
3. Manufacturers that recommended 10W-30 just a few years ago now recommend 5W-20 even for the same engine. The rep agreed with many here that it was done to reduce gas mileage, not add protection. Higher weights might be used since they were recommended before.
4. At least for the time being, however users of Fords and Hondas that recommend 5W-20 should continue to do it because 5W-30, and 10W-30 have NOT been altered yet to conform to the SL standard. That will begin in July, and should be in the channel soon after that.
5. Quaker state blends are 20% for 4 X 4 and 25%for High Performance synthetic oil. It's not a mystery amount.
There are dozens of different engine oil brands on the market, who do you trust?, the guy who's oil costs 18$ case could be an inferior product than the 9$ case. You just don't know.
g1994sts- how many of those oils meet the ACEA A1/B1-98 specs. You might want to check on that. Plus if you are going to the trouble of concocting the witches brew...even a "bad" batch of Mobil 1 will outperform all conventional oils.
I understand your concern, but I'm not sure you are on to the solution. BTW I also have a healthy doubt when it comes to any manufacture's claims.
I purchased a new Sentra last year and changed to Mobil 1 after 32 miles. That's just me. I could see no possible reason for not changing.
BTW if you are then going to switch to syn and the requirement is 5W-20, Amsoil I understand is the only syn available. Again, If it were me I'd go to Mobil 5 or 10W-30.
Oh-one other thing, being really easy on the car during break in gives the engine the best chance for a long and healthy life.
g1994sts, I blend oils as well ... but only for power equipment like lawnmowers, snowblowers, etc ... I think you are taking a gamble ... but only a really teensy one. Good luck. At least you know the blends sold by the manufacturers are usually a rip-off.
Mr. Detailer, interesting info. I see Mobil is already claiming their dino juice meets/exceeds the new "SL" classification. Where did you find those syn. blend percentages? Their website? I looked around a few months ago and couldn't find that kind of info from anyone.
I also agree that the engines have not really changed ... rather it's the policy and politics that are pushing the new 5W20 oil. Fewer pumping losses mean a 0.5-1% better mileage or so.
Lastly, I've heard from too many Ford and Honda owners that have been told to leave the factory oil in for 5,000 miles for it to be nonsense or some kind of myth. Besides, what motive could they POSSIBLY have for lying to you? By keeping you away during that period, they are losing out on at least 1 service call!
--- Bror Jace
http://www.machinedesign.com/
Use the search article button and look for the editor above on the date above.. Article says by 2010 Auto engine oil should last 20-30K as standard. Very informative. It is in PDF format..
someone replied: valvoline max life. From what I
understand this oil is meant to be use on Higher mileage cars. My vehicle is a new toyota V6 truck which requires a 5W-30.
Don't care much on what the dealer use. Your response would be appreciated.
hmpower, the ONE application I refuse to recommend synthetic for is cars that sit and sit. You are wasting money as your motor oil will 'time out' and require changing long before the synthetic lube's chemical bonds begin to get tested.
Valvoline Max-Life is for old, new and newly rebuilt cars. Check the bottle or call them at 1-800-team val. If you are a little leery about this anyway, use somehting else for the first couple years ... like their All-Climate formula.
--- Bror Jace
--- Bror Jace
http://www.chevron.com/prodserv/nafl/automotive_motor_oils_fs.htm
--- Bror Jace
