Honda Accord problems
1. The engine "stumbles" just a little during warm up. The stumble occurs about 2 minutes after I crank up and head for work every morning. The same in the afternoon,then it runs fine.
2. The transmission seems to be "hunting" first gear at times when I almost come to a stop, then speed back up. It acts like it doesn't know what gear to go to.
Do you have any thoughts on these minor problems?
I am new to town hall and in fact new to US. I am planning to buy a used car. I have seen one Honda Accord 1992 DX. It is in good condition only problem is when it accelerates, you can feel the gear change. Its kind of rough auto transmission. According to owner it is from begining and it is common in Honda accord. Is it correct ?
Is it adviseable to buy the car (92K miles excellent condition) with such problem?
jjm5: With out driving the car it is tough to say that it is normal. However the shift quality of the trans should be a possitive one. Meaning a bit hard no slippage good solid engagement. The trans can be tailored to be smoother by changing the shift cable adjustment. But as I said you do want it to be possitive. A correctly adjusted cable moves the trans arm at the same time that the throttle plate moves without being tight at idle..If the car has been taken care of then they last a long time..
titopuente: That smell is usally caused by a rich mixture,or as you said unburned fuel. If your part of the country uses that winter fuel(oxygenated) then that could be a reason. I have not yet come across a bad computer control of that system, it is dependable. I will keep an eye out for any write ups on it for you...
- Anthony
I used the ABS again...it was raining like crazy in Toronto yesterday and it did not feel like 10 HZ, it felt more like 5 pulses per second. Does the ABS frequency vary according to speed? Or are the pulses to the brake pedal reduced so as not to provoke panic?
Auburn: Thanks a lot!
My Accord just recently met the pothole from hell which brought the car to a dead stop from 20 mph, resulting in some rather significant damage to the 'front beam' under the car.
Insurance will pay, so I'm planning to have the dealer replace it. I just wondered if anyone out there knows how significant a repair this is? If it's something that is difficult enough that the car could end up worse off for the repair?
Any thoughts would be much appreciated.
Silver: OUCH! The suspension system would take most of the ouch (that's what they're for) but that's as much as I know.
titopuente..Yeah us Jersey'ans use the crap also. Glad to hear that was all it is..see ya.......
Now, I got a new problem. The background light of my clock suddenly went out. Besides, I noticed that there is no light on the markers/labels of the cruise control buttons on the steering wheel, the windshield wiper control rod, the power mirror and window buttons on the door. I'm not sure if they are supposed to be lit or the lights are also dead. My car is Accord 1999, LX V6. Could someone having/knowing the same model give me the answer?
It seems not to be a simple fuse-blow-out problem, since the clock is still working. I went to a dealer yesterday. He told me it might be caused by the alarm system which was not installed by Honda. It's possible but I don't think it's likely. The alarm was installed one year ago and the clock light went out just last week.
Anyway, I made an appointment and let's see what happens.
(I've noticed, too, that not one person has posted having a problem with their MANUAL tranny Honda...heh heh heh...)
-Lancerfixer, militant 5-speed supporter
There are several other dealers in the Denver area who do not use high pressure sales tactics. We purchased our CRV from Fisher Honda in Boulder. Ask for Suzi Smith or Craig Sweeney.
Did you post your story in Smart Shopper
I know they will be interested in your experience.
Your Host, Bruce
What you think, it is the same thing???
Hey great help so far for everybody, thank you very much.
Snowman.
I do hope the cruise control buttons on the steering wheel and the control levers be illuminated. It's not important, but nice to have during the night.
I have seen many discussions about hesitation on this list. My car (1999 LX V6) has the same problem (or behavior if you like). I was dispointed by the transmission, but didn't think it as a problem. Now I think I should at least let the dealership look at it.
One thing different is that my car ALWAYS hesitates during acceleration. The shift is not smooth at all. The problem is severe during warm up. After that, it gets better but I can still feel the hesitation.
Should I increase the engine idle speed or adjust some electronic controls in the transmission?
Most people seem to like Purolator and Delco. What are your thoughts on this?
If your car is a 98 or 99 with a L4 motor then an idle adjustment could cure your stumble as per a bulletin on them. The pgmfi checker and procedure must be followed in order for it to be correct..
Silvercoupe,
I in 17 years with Honda have never been told that Fram makes Honda filters but even if they did they would be of a different spec than what they sell in the stores. I own a Honda and advise all to use Honda parts for every occasion. You would not believe me unless you have seen it but over the years the cars I have seen that have aftermarket parts on them are always the ones that need the most repairs. The substandard parts, now matter how good they worked on your chevy(which I own and also buy OEM parts for)just cost you more money in the long run.I always suggest to people that they can have any mechanic work on the car but put only Honda parts in for the best performance. See ya.........
I always thought Honda made problem-free cars. Has the quality slipped since they started making them in the U.S.? All of these problems with the engine and transmissions are incredible to me for a new car. Why buy new when you are likely to suffer headaches?
I was just kiddin, I hope you didn't take my post seriously. But thank you for being the only person to answer my question. :-þ
tl565,
The whole reason for this topic is for problems, hence it's title, "Honda Accord Problems." I love my '00 EX V6 Coupe, it's a great car. The only problem I've had is a rattle coming from the rear headliner, and it is fixable, I just haven't had the time to take it to Honda. Honda has made the Accords in the US since 1985, so I doubt it's our American slakers causing problems. I've never had any engine or tranny problems with my Accord. Actually, the tranny is made in Japan. I'm a die-hard Nissan fan and I'll always be one. The Honda is growing on me though, 2,300 miles and counting.......
The tranny problems seems to occur in late 99 and 00 models...a friend of mine is in the business. Please don't scratch Hondas off your list, they are highly dependable (bullet proof) cars that if cared for properly (no need to pamper, rev the engine high up and corner...they're made to do that) there is EXTREMELY little chance for them to cause any problems. My neighbour still drives an 83 civic and in the course of using that car he went through an early 90's grand prix! And just like what Auburn said...this is an Accord problem board, the people with no problems won't post and those who do and know this site will (and most of the time its the same person presenting problems over and over)....how many people have problems?...a few...how many Accord owners are there?...too many!
ADG44: Hondas have already grown on me. Hondas seem to be the only carmaker to blend bulletproof reliability, performance, low maintenance, fuel frugal and comfortable cars in one package at a reasonable price. My upcoming car is a current gen. Prelude 5spd. I drove it, cornered it, floored it and fell in love with it. And to top it all off...its fuel efficient! Great for a soon to be university student. The only con...DAMN insurance :-(
(fast car+testosterone+18year-old=DANGER) oh yeah!
I believe that this is temperature related problem. As auburn63 suggested, I idled my car in one morning a bit longer (2minutes) before, sometimes in the middle of the winter, in that specific morning did not stumble. The reason that I did not have this as habit because of my 91 Accord.I never wormed up my 91 Accord more than 10 seconds even winter time but, hey what is the big deal.
Since the weather is warming up, I am having problem to generate the same feeling, today it did not do it. Morning temp was around 50. Since they are very sophisticated engines, they might be sensitive to cold whether and require a little bit warm up time.
Silvercoupe, I do not suggest you to go up for 89 or 93 octane. I am using 87, I though the same thing and I upgraded it for a while but actually lost the power. My car did not accelerate as strong as it did with 87. So I switched back.
Spokane, your explanation makes good sense. It could be a unique specs of VTEC engines, ha?
Sorry to hear about your problems. I was wondering when your car was made. Rumor is that early 2000 production had more problems. I think your dealer's service dept. really sucks. Well, I know the feeling. They fixed everything, so you should be happy. Right? What a joke. I found myself in a similar situation. Honda service dept. doesn't seem very competent. However, there are some very knowledgeable people around here in this forum (auburn63, spokane, etc). auburn63 is actually a Honda tech, and he knows the stuffs. So ask them around. Good luck.
--terminalis
