2025 Chevrolet Silverado Lease Deals, Incentives, Rebates, and Prices
Anabanana745Anabanana745 Member Posts: 17
edited November 2024 in Chevrolet
Is lease info available yet for 2025 models?
Interested in 36/12 or 48/12 on a silverado LT trail boss 4wd in zip 27607
«13456789
  • kyfdxkyfdx Moderator Posts: 275,430
    .00240 MF and 63% residual
    .00265 MF and 56% residual
  • rayachito1986rayachito1986 Member Posts: 18
    can you please share silverado 1500 crew 4x4 LTZ 3.0 engine
    Money Factor/Residual 36/12
    95901 zip
    any incentives?
  • MichaellMichaell Moderator Posts: 270,592
    95901 zip
    any incentives?
    .00204 and 62%
  • mustangz5mustangz5 Member Posts: 87
    Do you have numbers for the 25 EV LT? 24&36 12k, 44011
    .00365 MF and 84% residual
    .00360 MF and 78% residual
  • MagillaEVMagillaEV Member Posts: 6
    edited December 2024
    What are the December rates for a ‘25 Silverado EV LT 36/10 & 24/10 zip 95128.
    Can you stack Conquest & GM employee incentive?
    December rates start on Tuesday. Ask again, then
    Same question. Thank you!
  • Tbpilot06Tbpilot06 Member Posts: 23
    Hi. Looking for December rates for LTZ SB 4x4 in 63021
    .00365 MF and 85% residual
    .00360 MF and 79% residual
    No info on GM Employee incentives
    .00204 MF and 60% residual
    Thanks sorry forgot to say 36/10 please
    63%
    Hello, Can you please share MF and Residual for 2025 Silverado 1500 Crew High Country 5.3L or 3.0L 4x4
    36/12 zip is 95901
    Thank You
    36/12 zip is 95901
    Thank You
    .00158 MF and 61% residual
    63%
    For some reason they said MF is .00247 instead of .00204 like you said. They are offering 2500 incentives and waived acquisition fee. Still works well within the food range I believe with 8000 discount also on the vehicle.
    Wondering if they are marking up the MF?
    Tbpilot06 said:
    63%
    Either that, or using a lower credit tier until they run your credit and see you are top tier.
  • khoward2001khoward2001 Member Posts: 56
    Hello, Can you please share MF and Residual for 2025 Silverado 1500 Crew High Country 5.3L or 6.2L 4x4 and 2025 Silverado 1500 ZR2 6.2l
    42/10
    Zip:
    28546
    42/10
    Zip:
    28546
    HC
    36: .00158 MF and 62% residual
    39: .00158 MF and 59% residual
    48: .00212 MF and 56% residual
    ZR2
    .00204 MF and 63% residual
    .00204 MF and 61% residual
    .00245 MF and 57% residual
  • abm54671abm54671 Member Posts: 28
    Hello, may I have please have the MF/Residual value and any incentives for
    2025 crew cab 4x4 RST with 5.3L V8
    36/12,000 in 28405.
    36/12,000 in 28405.
    .00207 MF and 61% residual
  • btafybtafy Member Posts: 2
    May I please get MF/RV and incentives for a 2025 Chevy Silverado 1500 ZR2 3.0 Diesel
    42/10
    Zipcode: 75071
    42/10
    Zipcode: 75071
    .00188 MF and 62% RV
    .00188 MF and 60% RV
    Term not available
  • superfastf7superfastf7 Member Posts: 3
    Hello, could I please have the MF/Res/incentives for 2025 Silverado RST Duramax. 12k/36 and 12k/39.
    Zip 05444
    Zip 05444
    .00189 MF
    61%/59% residual
  • pdurant1980pdurant1980 Member Posts: 29
    Hello, could I please have the MF/Res/Incentives for 2025 Silverado 1500 LTZ and LT TrailBoss?
    Zip Code 36526
    Thank You!
    Zip Code 36526
    Thank You!
    TB
    .00223 MF and 63% residual
    .00249 MF and 56% residual
    LTZ
    .00188 MF and 62%
    .00228 MF and 56%
    36/12,000 in 28405.
    Can I also have the MF/RV for LT trim?
    36/12,000 and 24/12,000
    36/12,000 in 28405.
    .00189.00207 MF and 61% residual
    .00243 MF and 70% residual
    .00189 MF and 61% residual
    Same for either trim
  • twheat61twheat61 Member Posts: 8
    Don't know if this the right place, but looking for information on a 2025 Silverado EV LT. 24 mos 12/15k. 89052
    Thanks in advance.
    Thanks in advance.
    .00365 MF
    84%/83% residual
  • mburgosmburgos Member Posts: 90
    Hello, could I please have the MF/Res/Incentives for 2025 Silverado 1500 RST with 2.7L Turbomax engine.
    Zip code 30180.
    Zip code 30180.
    .00189 MF and 59% RV
    $1000 incentive
    Zip code 30180.
    $1000 incentive
    add 1% for a 36/12????
    mburgos said:
    Zip code 30180.
    $1000 incentive
    2%
  • Iron_100Iron_100 Member Posts: 26
    2025 Chevrolet Silverado 1500 Crew Cab Short Box 4-Wheel Drive LT Trail Boss
    5.3L EcoTec3 V8 engine
    Zip 32819
    Thank You
    Zip 32819
    Thank You
    2025 GMC Sierra 1500 Crew Cab, Short Box, Elevation 4WD
    5.3L ECOTEC3 V8 W/ DFM
    Zip 32819
    Zip 32819
    Please post in the GMC Sierra discussion
  • pblancopblanco Member Posts: 4
    Hello can you please share the MF/Res/Incentives for 2025 Trail boss, 4x4, crew cab, short bed.
    5.3L and 3.0 Diesel.
    Zip 32259
    Zip 32259
    .00208 MF
    63%
    61% residual
    edited January 2025
    Hello, can you please share the MF/Res for 2025 RST, 4x4, crew cab, short bed 5.3.
    Zip 33183
    48/12
    Thanks again.
  • CJMJRCJMJR Member Posts: 5
    2025 Silverado LT (2FL) MF and RV please. 4x4 Crew cab
    12545
    Zip 33183
    48/12
    Thanks again.
    .00173 MF and 61% RV
    .00173 MF and 59% RV
    .00231 MF and 55% RV
    12545
    .00205 MF and 66% RV
    $1000 incentive
  • Mny2burn20Mny2burn20 Member Posts: 17
    Could I please have numbers on a 2024 Silverado RST EV 36/10 and 48/10. Zip 65201. Thanks
    .00220 MF and 69% RV
    .00250 MF and 62% RV
  • mmendoza2mmendoza2 Member Posts: 200
    Good Afternoon,
    May i please have the MF and residual values for a 4 cylinder 2025 Silverado LT Trail Boss 4x4 in South Florida (33027) for the following terms:
    48/10
    Any conquest and/or loyalty incentives?
    mmendoza2 said:
    Good Afternoon,
    48/10
    .00208 and 64%
    .00208 and 62%
    .00233 and 57%
    $1000 incentive
    Check with your dealer on conquest or loyalty incentives
  • scho1985scho1985 Member Posts: 9
    Hello.
    May I have the MF/RV/Lease Incentive for 2024 Chevrolet Silverado 1500 LT Trail Boss Four Wheel Drive Crew Cab / (turbomax engine 2.7) in 92821?
