2025 GMC Sierra Lease Deals, Incentives, Rebates, and Prices
2456789
  • MichaellMichaell Moderator Posts: 271,055
    mustangz5 said:
    Can I get the numbers for an EV max range? Zip is 44070. Looking for both 24 and 36 mth with 12k per year
    mustangz5 said:
    5sc I believe > @Michaell said:
    Is that the 5SC or 5SD package/trim?
    .00156 and 61%
    .00185 and 57%
  • jimmcdonjimmcdon Member Posts: 10
    2025 sierra 1500 Elevation, SLT, Denali 36/10 MF/RV
    93401
    93401
    Which cab style?
    4x4 or 4x2?
    crew cab 4x4
    93401
    jimmcdon said:
    crew cab 4x4
    ELE - .00231 MF and 62% RV
    SLT - .00225 MF and 63% RV
    DEN - .00173 MF and 62% RV
    $2000 incentive
  • junior010104junior010104 Member Posts: 2
    Can I get the money factor and residual for the following 2025 models for two different zip codes (84075 and 99501):
    36/10 3500 crew cab AT4 4x4 standard bed
    36/10 3500 crew cab Denali 4x4 standard bed
    36/10 1500 crew cab AT4 4x4 standard bed
    36/10 1500 crew cab AT4X 4x4 short bed
    36/10 1500 crew cab Denali 4x4 short bed
    .00309 MF and 63% RV
    .00325 MF and 66% RV
    $500 incentive on the 1500's
  • Tbpilot06Tbpilot06 Member Posts: 23
    Can I get 36/10 on SLT 4x4 crew cab in 63021 please? Thank you
  • kyfdxkyfdx Moderator Posts: 276,153
    .00225 MF and 63% residual
    $500 incentive
  • wis99skiwis99ski Member Posts: 39
    36/10 AT4 1500 diesel 18902. Still only $500 incentive for December? Cash incentives seem light for trucks? Thanks.
    $500 incentive
    It is a 2025 model; probably better deals to be had on the outgoing 2024's.
    edited December 2024
    Hello, looking for tier 1 MF and RV on the following 2025 models for zip 99501 and 84075. All crew cab and standard bed fully loaded with the 6.6 diesel.
    36/10 AT4 2500
    48/10 AT4 2500
    48/10 AT4 3500
    Also for a 2024 AT4 3500 crew cab with 6.6 diesel for a 36/10 and 48/10.
    36/10 AT4 2500
    48/10 AT4 2500
    48/10 AT4 3500
    36/10 - .00309 and 63%
    48/10 - .00335 and 56%
    Either 2500 or 3500
  • Aaron23JAaron23J Member Posts: 14
    Can I get the MF and RV for zip code 48842
    24/10k
    2025 GMC Sierra 1500 4WD Crew Cab 147" Elevation w/3VL
    24/10k
    .00235 MF and 74% RV
    $3000 incentives
    RV, MF and Incentives
    SLE 4x4 Crewcab 36/10 42/10
    Elevation 4x4 Crewcab 36/10 42/10
    SLT 4x4 Crewcab 36/10 42/10
    Denali 4x4 Crewcab 36/10 42/10
    93422
    93422
    .00220 MF and 62% residual
    .00220 MF and 62%
    .00215 MF and 63%
    .00164 MF and 62%
    $500 incentive
    We don't have the 42 month term info
  • Bigtony1660Bigtony1660 Member Posts: 25
    Can I get the residual and MF for Sierra EV max range 36/15 and 39/15 in 40383?
    Is that the 5SC or 5SD package?
    5SD
    5SD
    .00170 MF
    55% and 53% RV
  • sman88ksman88k Member Posts: 7
    Could I please get the MF and residual and any incentives on a 2025 1500 Sierra Elevation 4wd Diesel ?
    10k/24 months
    10k/36 months
    10k/39 months
    Zip 07644
    10k/24 months
    10k/36 months
    10k/39 months
    Zip 07644
    .00240 MF and 70% RV
    .00220 MF and 62% RV
    .00220 MF and 60% RV
    $500 incentive
  • spr2014spr2014 Member Posts: 23
    May I have RV, MF and incentives in Denali crew cab short bed 4x4 for 36/10 in 28270?
    .00164 MF and 62% RV
    $500 incentive
  • Iron_100Iron_100 Member Posts: 26
    Hello, could I please have the MF/Res/Incentives for
    2025 GMC Sierra 1500 Crew Cab, Short Box, Elevation 4WD
    5.3L ECOTEC3 V8 W/ DFM
    Zip 32819
    Zip 32819
    .00220 MF and 61% residual
    $500 incentive
    2025 GMC Sierra 1500 Crew Cab, Short Box, Denali Ultimate 4WD
    DURAMAX 3.0L TURBO-DIESEL
    Zip 32819
    Zip 32819
    .00164 MF and 61% residual
    $500 incentive
  • marioemilanmarioemilan Member Posts: 3
    GMC sierra 1500 SLT money factor and residual zip code 33130
    2025 GMC sierra 1500 SLT money factor and residual zip code 33130
    4x2 or 4x4?
    Which engine?
    Hello, can I get the money factor and residual value of 2025 GMC sierra 1500 SLT Drivetrain 2WD Engine 5.3L EcoTec3 V8 engine zip code 33130. Lease term:
    36M 10k miles
    36M 12k miles
    39M 10k miles
    39M 12k miles
    36M 10k miles
    36M 12k miles
    39M 10k miles
    39M 12k miles
    .00253 MF
    63%/61% residual for 36/39 mo, 12K/yr
    $500 incentive
  • 1slo6fo1slo6fo Member Posts: 3
    Hello, can I get MF, RV and any incentives on a 2025 1500 AT4 4x4 3.0L in 76082 48/10, 48/12.
    48/12
    .00253 MF and 55% RV
    $500 incentive
    $500 incentive
    Any difference in 48/10
    $500 incentive
    56% RV
  • jwm0206jwm0206 Member Posts: 5
    Hello. Can I get the MF, RV, and Incentives for a 2025 GMC Sierra in zip 15632:
    SLT Crew Cab, Short Bed, 5.3L V8, 4WD, 36 month lease, 12k miles/year
    Denali Crew Cab, Short Bed, 5.3L V8, 4WD, 36 month lease, 12k miles/year
    .00215 MF and 62% RV
    .00164 MF and 61% RV
    $2000 incentives
  • xmann19xmann19 Member Posts: 11
    Morning, can i get numbers for a 2025 Sierra in zip 44221:
    Elevation CC SB 3.0L diesel 4wd
    SLE CC SB 3.0L diesel 4wd
    24/36 10k/year
    Thank you!!
    24/36 10k/year
    Thank you!!
    .00240 MF and 70% residual
    $500 incentive
    Either trim
  • ColinexlColinexl Member Posts: 1
    Could you please provide RV, MF, any incentives for the:
    2025 Sierra EV Max Range
    36mo/12K miles
    Zip code is 94501
    Thank you very much!
    36mo/12K miles
    Zip code is 94501
    .00170 MF and 57% residual
    No incentive info
  • bnapilotbnapilot Member Posts: 1
    edited January 2025
    Hello! Currently in the market for a 2025 GMC Sierra 1500 Denali Ultimate - Any ideas on a RV/MF?
    24/12
    Zip 37209
    24/12
    Zip 37209
    24/12 - .00146 MF and 68% RV
    36/12 - .00164 MF and 61% RV
  • djk123djk123 Member Posts: 5
    Hi and thanks in advance. Looking to lease a 2025 GMC Sierra 1500 Elevation 4WD / V8, residual and money factor info is appreciated. Zip is 28374.
    36 or 39 mo / 12k annually
    Double or Crew Cab?
    Crew Cab. Thanks.
    djk123 said:
    Crew Cab. Thanks.
    .00220 MF
    61% or 59% RV
    $2000 incentive
