Visitor Agreement.
I've heard of a LOT of people who have had the defect. My dealer immediately knew about the problem and said it is very common flaw on the Civic.
Did you ever find the leak & fix it? I've got exactly the same car with exactly your problem... water leak into the trunk. I wonder how much it costs to replace the tail light seals?
Jim
You are not alone. My wife is now recoving from a near fatal accident when our brand new 2005 Civic LS had the transmission completley lock up on her as she was driving down the freeway, totaling the car. We had about 1000 miles on the car. I plan to start a web sight, with crash pictures, devoted to this know problem. The car started to pull to the right and she lost all control of the steering as it was in a solid skid, crashing into the guard rail, blowing the air bags and spinning around several times before comming to a stop and starting on fire, burning her coat as she was getting out of the car. We have an eye witness, who just happens to have a degree in engineering and will atest to the facts. The police report was filed in Fort Worth, TX.We have the car quarentiend and are working on legal reresentation. As of yet no one has been helpful,"saying it's our insurance's problem". My advice get rid of it ASAP. :lemon:
Suggestions?
HINT: You can remove the taillight assembly and coat the old gaskets with a LATEX black sealer (NOT silicon sealant). This washes up with water and you can squeegee it into the tightest places. Great for windshields, too.
http://www-odi.nhtsa.dot.gov/ivoq/
Is it OK if I call you shifty? ! Anyway, thanks for the advice. I'll see about taking off the taillights & see what shape the gaskets are in.
Do you know if there is supposed to be a drain hole? I notice that the slopes of the body where the hatch seals on the left and right, guides water down to the taillights. I wonder if the water is supposed to go out a drain hole that might be stuffed up.
for about $150.00/pair , Infinity and kicker sell something that i'm sure is better than stock.
let me know what you find.
Was your eyewitness able to see the positions of the driver's feet before and during the incident?
You wrote that this was a know(n) problem. Known by whom? It is recommended that you search the National Highway Traffic Safety Administration (NHTSA) Office of Defects Investigation "Complaints" website here.
http://www-odi.nhtsa.dot.gov/cars/problems/complain/complaintsearch.cfm
You will not find a single report of such a transmission complaint with 2005 Civics.
The two mechanics that I went to, said that overheating is likely do to the torn, but not yet blown head gasket, and that repairs would cost around $600. I did not agree with them, as I did not see the white smoke, and the car has passed emissions flawlessly.
I took the car to a local shop and asked them to do a coolant flash - they said that they could not flush the system completely, as something was blocking the flow (could be the thermostat). They also told me that the metal radiator cap had torn inside, and was letting the air into the system. They also advised me to disconnect the fan and shor the switch - to see if the fan would function.
I checked the fan, and saw that if shorted it worked. For some reason though, when connected as it should be to the car, it would start only when the temp. approached the red mark. (Many people report this issue) This meant that the temp. in the radiator was lower than in the engine - the fluid was not circulating properly.
I went to a local store and bought the cap and the thermostat for $11 total and replaced them myself. The thermostat replacement is very simple, two bolts hold the housing together, but it is tricky to get the wrench to them, unless the one with pivoting head is used.
As soon as I replaced both, the car stopped overheating. It has been 6k miles and 4 months since then - and not a single temperature spike.
Hope this helps someone.
Eugene
Also, when down shifting into 1st and 2nd gear the tranmission makes a higher pitched noise that sounds like the transmission is reving up. Once you let the clutch out to engage the gear the noise disappears.
If you have transmission noise with the clutch released, that is more likely the front mainshaft bearing.
High pitched whining during downshifting are your synchronizers saying "hey, don't do that so fast".
I hope there is a solution to this. They need more options on the choices for interiors.
I have no concerns about maintenance. Unless, that is, if I were in the habit of wearing greasy or dirty clothes, which I am not.
Perhaps Honda is becoming a little more flexible?
OhioCarGuy
I also have a 99 manual and I can detect a slight difference in noise with the clutch pedal depressed and released. vix is right, it's likely your throw out bearing.
Also, the sound you're hearing when you downshift into 2nd and 1st is just gear whine. 1st is much louder because the gears are spinning very quickly. You really shouldn't downshift into 1st while you're moving, unless its a very slow crawl, like at a stop light.
I prefer the lighter brighter interiors. Then again, I don't live in the often gloomy rainy Northwest.
HEY, we do have August!
How much did it cost to fix (I presume at a dealer)?
Unfortunately when I bought the car, I couldn't get the dealer to give me the service manual like they did other times.
You sure don't need a Service Manual for that!
I have the same problem with my 98 Honda Civic LX. I replaced the battery in the transmitter and re-programmed it twice, but no luck.
I press a button on the transmitter and the LED lights up, but the doors will not lock or unlock.
Did you ever get your keyless entry working? Would you have any suggestions for me?
Thanks for your help.
Billsfriendbill
Sorry
I know the perfect solution: Weathertech Window Deflectors.
JM2C
