Visitor Agreement.
Original owner with warranty still active
During the winter of 2005, when my car gets really cold, I sometimes notice a rattling sound when I shut my doors or trunk. The rattle is not a sharp metallic sound. The rattle suddenly occurs and almost abruptly dies down -- no fading away.
When I drive the car or let it warm up, the rattle disappears. Which is really frustrating because everyime I drive to the dealership, I will not be able to recreate the sound. The dealership mechanics want to take apart parts under my car and probe around. I want to keep this as my last option.
I crawled under the car when it's cool and carefully knocked parts around with my hand to recreate the sound. Sometimes I could recreate it, sometimes I can't. I cannot fully fit under my car (I have no jack stands), so all I could tell is that the sound seems to come from between the rear axle and muffler.
Seeing how heat gets rid of the rattle, I am guessing that a baffle or internal part of the exhaust system is loose. Another possibility is some obscure suspension component that is loose.
Does any have any similar experiences, solutions, and/or advice concerning this issue? Is this issue normal and ignoreable?
thegrad
I am 100% sure it is not the "tag" (license plate) rattling against the trunk. My license plate rattle bugged my in the past and I sticked these scratch-free cushions behind them.
I crawled as deep as I could under my car (I don'thave jack stands) and had a friend shut the doors or trunk a few times.
The rattle comes somewhere around the rear axle and exhaust pipeline. It is audible even when I am sitting inside the car with doors closed. I knocked different things around and could recreate the sound, but localizing it was difficult.
I am starting to think this is just a insignificant, freak issue. The issue alarmed me 'cuz I had a Honda Accord LX for ~13 years and never heard of such a mysterious rattle.
In fact, if you can find a NEW carb at close to that price, I'd do that. Rebuilds on old Honda carbs are not all that successful...but it can be done.
They are expensive because of supply and demand and because they are so devilishly tricky to do.
ed
i just got a performance camshaft for my 1.6L civic si. does my engine require any upgrades in order for my aftermarket camshaft to work properly? plus so far i have changed the following, cold air intake, header, and full exhaust i believe everything from air intake to exhaust is well balanced (correct me if im wrong) i am now thinking of changing my factory pulley system with a AEM pulley system or something, with the new pulley would there be anything say "unbalanced"? any help or repley would be very helpfull!!! thanks!
I have had a head gasket replaced on my 95 Honda civic and now I have a check engine light. :sick: The head gasket left with a little smoking around where the oil goes and where the belts are on the right hand side is there anything I should look for out of the ordinary? Please help. Thanks
These stations have never been a problem and come in perfectly clear and noise free on any other car radio, stereo receiver, or cheap $10 clock radio.
Is anyone experiencing anything like this? Have any dealers had complaints about this? Is the window antenna a potential source of the problem? Is it possible to reseat the antenna cable at the back of the unit without ripping the dash apart? Chances are, if I took it back to the dealer I bought the car at, the radio would be clear because they're about 25 miles closer to the station antennas than I am.
I'm a bit ticked that a unit with this price tag would have worse FM reception than a K-Mart clock radio. Any ideas?
No, my brakes do NOT have 2 inches of freeplay. It gently brakes as soon as I press the brake pedal. As I press the brakes deeper, my braking feel is smooth - no jerks or sudden "grabs" that slow down my car. It is progressive throughout the whole prcoess.
However, my transmission sometimes downshifts when I break on a hill, which does cause a gentle jerk as the downshift helps slow down the car. This downshift is commonly reported on Edmunds.com review of the 2001-2005 Honda Civc, as well as other car review sites, so if this is what you are talking about, then the jerk is normal.
If I were you, and owned a fifteen-year-old vehicle, I would have a competent mechanic diagnose the problem. I would also have him inspect the entire vehicle to see what other work might be necessary.
Best of luck with your purchase.
Incidentally, typing in all upper-case is considered shouting here.
Make: HONDA
Model: CIVIC
Type: PASSENGER CAR
Year: 2005
Complaint Number: 10129820
Summary:
MY DAUGHTER WAS DRIVING HER STANDARD NEW HONDA CIVIC 2005 HOME FROM THE DEALER ON MAY 9TH. SHE HAD 60 MILES ON THE CAR AND WAS CRUISING IN 4TH SPEED AT 45 MILES AN HOUR ON I5 SOUTH IN THE SEATTLE AREA WHEN THE CAR CAME INSTANTLY TO ALMOST A COMPLETE HALT CAUSING AN INTENSE JERKING OF THE CAR. SHE WAS ABLE TO SHIFT TO NEUTRAL AND COAST TO THE SHOULDER WITH WHAT MINIMUM MOMENTUM SHE HAD LEFT. AS THERE WAS NO IMPACT THE AIR BAGS DID NOT DEPLOY WHICH MOST LIKELY INTENSIFIED THE NATURE OF HER INJURY. CURRENTLY HER RADIOLOGY REPORT STATES SHE HAS A FRACTURE OF THE T-11 VERTEBRAE AND TO DATE SHE IS UNABLE TO SIT, THEREFORE DRIVE, WORK, OR FINISH HER COLLEGE PROGRAM. HONDA HAS DIAGNOSED THE CLUTCH AS DESTROYED AND SAYS THAT SHE MUST HAVE INTENTIONALLY DOWNSHIFTED FROM 5TH TO 1ST GEAR WHILE TRAVELING AT 45 MPH AND DESTROYED THE CLUTCH HERSELF. THEREFORE THEY ARE TAKING NO RESPONSIBILITY FOR THE VEHICLE. MY HUSBAND AND I ARE CURRENTLY TRYING TO DECIDE WHETHER TO HAVE THE CLUTCH REPLACED OR JUST HAVE THE TRANSMISSION PUT BACK IN AND EITHER WAY TOW TO CAR TO MY DAUGHTER'S CONDO AND WAIT OUT OUR NEXT MOVE. HONDA IS CHARGING US $500.00 JUST TO PUT THE CAR BACK TOGETHER AND THE TOW WILL BE OVER $200.00 BUT IF WE LEAVE IT AT THE DEALER IT IS $50.00 PER DAY. OUR SERVICE ENGINEER HAS THE DESTROYED CLUTCH STORED IN EVIDENCE. THESE 2 YOUNG PEOPLE WILL NEVER DRIVE THE CAR AGAIN EVEN IF THE CAR IS REPAIRED. SHE DIDN'T SHIFT AT ALL AT THE TIME OF THE INCIDENT AND COULD HAVE EASILY BEEN IMPACTED AND INJURED EVEN MORE. SO WE HAVE A NEW CAR NO ONE WILL DRIVE AND SO FAR 2 ATTORNEY'S HAVE REFUSED TO TAKE THE CASE.
Do Your Homework before giving advice. The 2005 Transmission is a DEATH TRAP!!!!!!!!!!!!! :lemon:
Make: HONDA
Model: CIVIC
Type: PASSENGER CAR
Year: 2005
Complaint Number: 10143164
Summary:
WHILE I WAS DRIVING ON THE STREET, THE AXLE/SPINDLE TO THE RIGHT FRONT WHEEL/TIRE OF MY VEHICLE BROKE. THEREFORE I LOST CONTROL OF THE VEHICLE AND I HIT TWO PACKED VEHICLES. *JB
:lemon: Every "expert" on this problem needs to do their homework. before giving incorrect facts!!!!!! :lemon: I Did! This is the third crash. Here is another one.
I would get the car fixed and then if your daughter can't or won't drive it, sell it for what you can. I wish your family the best.
Your original post #4614, based upon your description of the event, implied that your wife was driving an automatic transmission vehicle. Perhaps, as you wrote in post #4695, "Do Your Homework before giving advice. The 2005 Transmission is a DEATH TRAP" you should do YOUR homework. The vehicle in that singular "complaint" has a manual transmission, totally unrelated to any automatic transmission that may have been in your vehicle.
I am compelled to reiterate, as I wrote in post #4627, that "You will not find a single report of such a transmission complaint with 2005 Civics." Please keep your facts straight.
Your post #4614, complained about a transmission problem. Why then does your new post #4696 cite another owner's unrelated May 9, 2005 concern about their axle/spindle? Please keep your facts straight.
05civicwarning was not saying that the May 9, 2005 broken clutch accident had anything to do with his daughter. His original post #4614 was about an automatic transmission mishap apparently recently experienced by his wife.
thanks,
They highlighted the story of a lady who had owned Hondas for 11 years and told how Honda refuses to fix a safety defect witht he transmission. Honda told her she is responsible for all the costs.
http://www.wjla.com/news/stories/0106/297245.html
Hmmmm, wonder why Honda does this? Maybe Canadian Hondas are sold to dealers cheaper than to US dealers and Honda is trying to stop Canadian dealers from selling to US buyers by not honoring the warranty? Seems pretty harsh to me.
It sounds like they told her about the lack of warranty, so it sounds more like bad luck and bad judgment to me. Since they paid to bring it here from Canada with risk, the two ought to get together and take it back to Canada for its warranty work.
