2025 Chevrolet Silverado Lease Deals, Incentives, Rebates, and Prices
2456
  • kyfdxkyfdx Moderator Posts: 263,008
    edited January 14
    scho1985 said:
    Hello.
    May I have the MF/RV/Lease Incentive for 2024 Chevrolet Silverado 1500 LT Trail Boss Four Wheel Drive Crew Cab / (turbomax engine 2.7) in 92821?
    36: .00208 MF and 64% residual
    39: .00208 MF and 62% residual
    48: .00233 MF and 57% residual
    $1000 incentive
  • Brade96Brade96 Member Posts: 49
    Hi can I have the RS and MF for the 2025 Chevrolet Custom turbo max crew cab 2WD for zip 33312. 24/12 and 36/12? Thanks.
    .00295 MF and 72% residual
    .00257 MF and 65% residual
    $1000 incentive
    how about RV and MF for the LT (2FL) crew cab 2WD for 33312 ----24/12 and 36/12? Thank you.
    Can't tell if the 2FL only comes as 4WD for 2025, but those are the only numbers we have.
    .00257 MF and 75% residual
    .00205 MF and 68% residual
    $1000 incentive
    ok and for the non 2FL LT? Just to compare? TY
    .00227 MF and 71% residual
    .00173 MF and 62% residual
    No lease incentive
    Either 2WD or 4WD
  • mburgosmburgos Member Posts: 88
    edited January 17
    Hi can I have the RS and MF and any incentives for the 2025 Chevrolet 1500 RST 4WD turbo max crew cab for zip 30180. 36/12? Thank you.
  • MichaellMichaell Moderator Posts: 260,489
    .00173 MF and 61% RV
    $1000 incentive
  • igetsofunkyigetsofunky Member Posts: 5
    Can I please have the MF and residual values for a 2025 Silverado 1500 LT Trail Boss 4WD in 12110 for the following terms:
    48/12
    Any conquest and/or loyalty incentives?
    Thank you in advance!
    48/12
    .00208 MF and 63% residual
    .00208 MF and 61%
    .00233 MF and 56%
    No info on loyalty/conquest
  • ShepDogShepDog Member Posts: 2
    edited January 22
    Can you please give MF/RV & incentives on 2025 Silverado RST Crew Cab 4WD with 6.2 in 76210 for
    36/15k
    .00173 MF and 59% RV
  • Lucid_DragonLucid_Dragon Member Posts: 7
    May I have the MF/RV/ incentives for 2025 Silverado 1500, Crew, Shortbox, LTZ, 2WD? Thanks!
    Forgot to include: 36 mo/12k in 77429
    Hi could I have RV and MF for a ‘25 RST crew cab 4x4 with the V8 in zip 33312 for both 24/12 and 36/12 leases. Thanks.
    .00227 and 70%
    .00173 and 61%
  • Jonandchris_1Jonandchris_1 Member Posts: 18
    Could I get RV and MF and lease incentives for 25’ Silverado 1500 double cab custom 4wd 36 month 15k miles. 46706 zip
    Also RV and MF and lease incentive for 25’ Silverado 1500 double cab LT (2fl) 4 WD 36 mon 15k miles. 46706 zip.
    And RV and MF and lease incentive for 25’ Silverado 1500 crew cab custom 4WD 36 Mon 15k miles. 46706 zip.
    .00242 MF and 62% RV
    .00200 MF and 64% RV
    .00257 MF and 63% RV
    $2000 incentive
  • ShooterhuffShooterhuff Member Posts: 1
    Can I get RV and MF 2025 1500 crew cab short bed LT 4x4 3.0 diesel 10/36, 12/36, 15/36 zip code 16501
  • wheelspinwheelspin Member Posts: 67
    Assuming Feb numbers are out? Can I get residual and money factory for 2025 Silverado EV LT Ext. Range? Also any incentives?
    24/10k
    78738
    24/10k
    78738
    Nope - new GM programs will be released on Tuesday.
    Ask again, then.
  • Ccron889Ccron889 Member Posts: 17
    edited February 2
    Hello. Can I please get MF & RV for 2025 1500 LT Trail Boss Crew Cab 4WD? Zip: 92562
    24/10k
    36/10k
    24/10k
    36/10k
    .00241 MF and 71% RV
    .00208 MF and 64% RV
    Can I get February residual and money factory for 2025 Silverado EV LT Ext. Range? Also any incentives?
    24/10k
    78738
    24/10k
    78738
    .00292 MF and 85% residual
    No incentive info
  • c99camaroc99camaro Member Posts: 8
    Can you please provide the Residual and Money factor for
    Double Cab LT 2FL 4x4 36/15
    Crew Cab LT 2FL 4x4 36/15
    Zip code 12065
    Zip code 12065
    .00200 MF and 64% residual
    .00205 MF and 66% residual
    $1000 incentive
    78738
    27/10 and 36/10
    78738
    27/10 and 36/10
    .00292 and 83%
    .00284 and 79%
  • jpeajpea Member Posts: 2
    Can I get February residual and money factory for 2025 Silverado LT 4x4 Duramax?
    zip is 95476
    zip is 95476
    Double or Crew Cab?
    zip is 95476
    Double or Crew Cab?
    Crew, please.
    jpea said:
    zip is 95476
    Double or Crew Cab?
    Crew, please.
    Can I please have the MF and RV for a 2025 Silverado 1500 LT Trail Boss Crew 4WD in 12110 for the following terms:
    48/12
    Any conquest and/or loyalty incentives for leases?
    48/12
    .00208 MF and 61%
    .00233 MF and 56%
  • rvegarvega Member Posts: 2
    edited February 17
    Hi, Can I get the residual value, money factor and lease incentive for Chevy Silverado 1500 Rst 4x2
    looking at 10,000/36,000 in 33498
    Double Cab or Crew Cab?
    crew cab
    rvega said:
    crew cab
  • HTX_MomHTX_Mom Member Posts: 3
    Hello, Can I please have the MF and residual values for a 2025 Silverado EV LT - Extended Range in 77429 for the following terms:
    24/10
    Any conquest and/or incentives?
    24/10
    .00284 MF and 79% residual
    No incentive info
  • tseck73tseck73 Member Posts: 7
    edited February 19
    Looking for RV/MF for 36/10 in 27608:
    Silverado 1500 LT 4x4 Crew Cab 3.0 Duramax
    Silverado 1500 LT 4x4 Crew Cab 5.3L
    Silverado 1500 RST 4x4 Crew Cab 5.3L
    .00173 MF and 62% RV
    Either engine.
    24/10
    No incentive info
    Question - when you quote these, are they only from GM Financial? Does the dealership also check other lenders?
    HTX_Mom said:
    24/10
    No incentive info
    Yes, only GM Financial.
    Most dealers wouldn't check other banks on a lease, unless one had something amazing. I once got a US Bank lease at a Toyota dealer, but it was probably the first one they'd ever done.
  • mmendoza2mmendoza2 Member Posts: 193
    Good Afternoon,
    May i please have the MF and residual values for a 4 cylinder 2025 Silverado LT Trail Boss 4x4 in South Florida (33027) for the following terms:
    48/10
    Also, may i please have the MF and residual values for a 4 cylinder 2025 Silverado RST (2wd) in South Florida (33027) for the following terms:
    48/10
