2025 Jeep Wrangler Lease Deals, Incentives, Rebates, and Prices
2456723
  • MichaellMichaell Moderator Posts: 271,124
    2024 Jeep Wrangler 4xe sport s 4 door
    Zip code 80128
    42 month 10,000 month
    Residual and money factor
    .00046 MF and 52% RV
    Same incentives
  • blist33blist33 Member Posts: 4
    Good evening, looking for MF RV and incentives
    2025 Willys 4xe and
    2025 Sahara 4xe
    10k / 48mo
    12k / 48mo
    2025 Willys 4xe and
    2025 Sahara 4xe
    10k / 48mo
    12k / 48mo
    48./12
    SAH - .00159 and 48%
    WIL - .00112 and 50%
    $500 2025 National Start Something New Bonus Cash exp. 02/03/2025
    $7500 2025 Stellantis Financial Services EV Incentive
  • md99800md99800 Member Posts: 46
    edited January 2025
    windnsea00 said:
    Hi, what is the MF & residual for a 2025 Willys 4 door 2.0T?
    36 months. 12k miles. 92037.
    .00327 MF and 69% residual
    ___
    Is that a typo or is it really 69% residual for 3 years? That's crazy high for 3 years. Granted the MF is really high too. So it offsets I suppose.
    My info request...
    83854 Zip
    2025 4XE Willys and Sport
    27/10 and 27/12 MF, RV, Incentives
  • kyfdxkyfdx Moderator Posts: 276,270
    ___
    My info request...
    83854 Zip
    27/12
    Sport S: .00102 MF and 61% residual
    Willy's: .00015 MF and 58% residual
    $8000 incentive
  • Raja GuptaRaja Gupta Member Posts: 22
    ATL, GA - Could I get the residual and money factor on:
    2025 Willy's 4xe 27/5 and 42/5
    2025 Rubicon 4xe 27/5 and 42/5
    RUB
    .00181 MF and 64% residual
    .00194 MF and 57% residual
    Willys
    .00015 MF and 61% residual
    .00055 MF and 55% residual
    $8000 incentive
    RUB
    Willys
    $8000 incentive
    Thank you! Are these the Jan numbers or did they just not change from Jan to Feb? Thanks in advance!
    RUB
    Willys
    $8000 incentive
    February programs start tomorrow
    Ah, ok - thank you! I will come back tomorrow! Lol - thank you!
    Just reposting this to get Feb numbers. Thanks!
  • jbudzinskijbudzinski Member Posts: 30
    Can I please get February numbers for 68526 for the following:
    2025 Wrangler 4xe Sahara and 4xe Rubicon: Residual/MF/Incentives for 27/12 and 36/12. I assume 10k miles adjusts by a percentage too?
  • Cliffy1980Cliffy1980 Member Posts: 66
    2025 Willys 4xe and
    2025 Sahara 4xe
    2025 High Altitude 4xe
    7500k / 36mo
    Zip 01950
    edited February 2025
    RUB
    .00165 MF and 61% residual
    .00178 MF and 56% residual
    SAH
    .00063 MF and 57%
    .00101 MF and 52%
    $8000 incentive
    +1% for 10K/yr
    2025 Willys 4xe and
    2025 Sahara 4xe
    7500k / 36mo
    Zip 01950
    .00046 MF and 55% residual
    .00101 MF and 54% residual
    .00101 MF and 54% residual.
    $8000 incentive
  • anderm30anderm30 Member Posts: 123
    Hello, could you provide the 27/10 and 27/7.5 and 36/10 and 36/7.5 numbers for a base Sport 2 door with the manual transmission? Zip is 37919. Thanks!
    27/10: .00360 MF and 76% residual
    36/10: .00327 MF and 69% residual
    Thanks! Is the 7500 mile residual just a 1% increase? Also, are these Stellantis numbers? Thanks again!
    Yes and Yes
    Yes and Yes
    Thanks again for your help! Could you give me the 36/10 numbers for a 2 door Willy’s and Sport “S” with the manual? Zip is 37919.
    Yes and Yes
    Sport S - 66%
    Willys - 66%
    Same MF
  • cr8zkevcr8zkev Member Posts: 3
    Any chance I could get the info for 2025 Willys 4xe, 27/10 and 42/10? Zip code 56071
    Thanks!!!
    Thanks!!!
    .00026 MF and 60% RV
    .00037 MF and 52% RV
    $500 2025 National Presidents Day Bonus Cash exp. 03/03/2025
    $2500 2025 National Lease Bonus Cash exp. 03/03/2025
    $7500 2025 Stellantis Financial Services EV Lease Incentive
    Thank you!!!
    One more dumb question that I tried searching through the threads for. So if my local Jeep dealer is quoting a higher MF or lower RV than what you wrote, is that just something where I say why aren't the numbers closer to what the Stellantis figures are? Likely b/c they're using different banks I'd guess; but can I request they use Stellantis to get the better numbers? Like obviously the dealer wants to make money and I'm just trying to get a sense of what a fair markup on the MF would be or if there should be no markup at all on it.
    There can be a markup on the MF, but the RV is fixed by the bank and the dealer cannot alter it.
    Likely a different bank; the computers are often set up to spit out the program that results in the lowest payment.
    But, have them run the Stellantis programs, as well, and compare.
  • tjnorm22tjnorm22 Member Posts: 17
    Hi! Can you give me the residual / MF for a 2025 Jeep Wrangler Sahara JLJP74
    36 months 10/12k miles. Or whatever lease months are better rates.
    43082
    43082
    Is that 4X4 or 4XE?
    Is that 4X4 or 4XE?
    4x4
    43082
    39/12
    .00327 MF and 63% residual
    No incentive info
  • aheyinkyaheyinky Member Posts: 6
    Hi! Could you please provide me with the following for zip code 40505
    15K miles/36 for the Jeep Wrangler Sport
    15K miles/36 for the Jeep Wrangler Sahara
    2-door, 4-door, or 4xe?
    43082
    39/12
    No incentive info
    Thank you! That's a rough money factor to work with.
  • Rubi21Rubi21 Member Posts: 4
    2024 Jeep Wrangler 4xe Rubicon
    27 month 12,000 miles
    Zip code 34711
    Can I please get residual, money factor, and incentives
    Zip code 34711
    Please re-post in the 2024 Wrangler discussion
  • ACremona22ACremona22 Member Posts: 29
    2025 Sahara 4xe
    36 month 10,000 miles
    Zip code 60565
    2025 Sahara 4xe
    Zip code 60565
    .00101 MF and 53% RV
    2025 Willys 4xe
    27/12 or 24/12, whichever has better terms
    Zip 34231
    Residual and money factor please
    Hi!
    Can you give me the RV/MF and any incentives for a
    2025 Jeep Wrangler 4xe Sahara
    zip: 43082
    10k/12k per year and whatever length is the cheapest.
    Rubi21 said:
    2025 Willys 4xe
    Zip 34231
    27/12
    .00026 MF and 59% residual
    Total Cash of $10500 includes:
    $2500 2025\ National Lease Bonus Cash exp. 03/03/2025
    tjnorm22 said:
    Hi!
    zip: 43082
    27/12
    .00063 MF and 57% residual
  • LaboscoLabosco Member Posts: 5
    Hello can I get res, mf and incentives on a 25 Wrangler Willy’s 4xe for 27/10 and 42/7.5 zip 53405. Thank you!
    .00026 MF and 60% residual
    .00037 MF and 53% residual
  • Pgator45Pgator45 Member Posts: 18
    Zip 33629
    2025 Sahara 4xe
    27/10k
    42/10k
    MF, Residuals and incentives please.
    30328 - Could I get the residual and money factor on:
  • roncepumroncepum Member Posts: 27
    Hi!
    I am looking for the residual and money factor and any incentives on:
    2025 Sports S 4xe
    27/12
    42/12
    Zip: 29611
    Hello, I am interested in the March numbers for 36/7.5 for a base 2 door Sport and Willys with a manual transmission. Zip is 37919. Thanks!
    Hello can I get res, mf and incentives on a 25 Wrangler Willy’s 4xe for 36, 42 and 48/10k zip 53405. Thank you!
