2025 Chevrolet Silverado Lease Deals, Incentives, Rebates, and Prices
1356
  • MichaellMichaell Moderator Posts: 260,585
    mmendoza2 said:
    Good Afternoon,
    May i please have the MF and residual values for a 4 cylinder 2025 Silverado LT Trail Boss 4x4 in South Florida (33027) for the following terms:
    48/10
    Any conquest and/or loyalty incentives?
    .00208 and 64%
    .00208 and 62%
    .00233 and 57%
    $1000 incentive
    No info on loyalty/conquest
    mmendoza2 said:
    Also, may i please have the MF and residual values for a 4 cylinder 2025 Silverado RST (2wd) in South Florida (33027) for the following terms:
    48/10
    .00173 and 62%
    .00173 and 60%
    .00231 and 56%
    $1000 incentive
  • Alexbenzi07Alexbenzi07 Member Posts: 2
    Can I please have the MF, RV, and any incentives/conquest offer for a 2025 Silverado LTZ & High Country 4WD 3.0L Duramax® Turbo Diesel engine Crew Cab Short Bed.
    36/10K
    39/10K
    08648 NJ
    (Does shopping out-of-state also affect the MF?)
  • kyfdxkyfdx Moderator Posts: 263,119
    edited February 28
    36/10K
    39/10K
    08648 NJ
    LTZ
    .00173 MF
    63%/61% residual
    HC
    .00129 MF
    62%/59% residual
    No info on conquest
    Same programs everywhere
    36/10K
    39/10K
    08648 NJ
    LTZ
    .00173 MF
    63%/61% residual
    HC
    .00129 MF
    62%/59% residual
    No info on conquest
  • mmendoza2mmendoza2 Member Posts: 193
    48/10
    .00173 and 62%
    .00173 and 60%
    .00231 and 56%
    $1000 incentive
    As always, thank you for all the info
  • bocadawnbocadawn Member Posts: 5
    Can I get the MF and RV for a 2025 Silverado 1500 Crew Cab, Short Box ZR2, 4WD with Rally Package please in 34982.
    Appreciate you!
    Appreciate you!
    .00173 MF and 60% RV
    THANK YOU!
  • LeaseColoradoLeaseColorado Member Posts: 56
    Could you please share the new March program numbers for the EV RST Max Range in 80023 for 36/10?
    .00205 MF and 69% residual
  • igetsofunkyigetsofunky Member Posts: 5
    Could you please provide the MF and RV for a 2025 Silverado 1500 LT Trail Boss Crew 4WD in 12110 for the following terms:
    48/12
    Also, the same info for zip 02184.
    Any conquest and/or loyalty incentives for leases?
    Thank you in advance!
    48/12
    .00208 MF and 63% residual
    .00208 MF and 61% residual
    .00233 MF and 56% residual
  • c99camaroc99camaro Member Posts: 8
    When you have a minute can I have the residual and MF for the following?
    2025 Crew Cab RST 4x4 with the V8. 36/12
    2025 Double Cab RST 4x4 with the V8. 36/12
    Zip code 12065
    Zip code 12065
    .00173 MF and 61% residual
    .00182 MF and 62% residual
  • DougleaseDouglease Member Posts: 16
    Hi!
    Can you please provide the MF and RV for a 2025 Silverado EV LT Extended Range for 36/10k and 24/10k in 43110 zip?
    Thanks for you help!
    Douglease said:
    Hi!
    24: .00292 MF and 85% RV
    36: .00284 MF and 79% RV
    We appreciate all that you do. Thanks a lot!
    Can I get MF and RV for a '25 Silverado EV RST with added All Weather Floor Liners and Black Nameplates options?
    24/10k with any/all lease incentives/discounts/deals/program numbers
    36/10k with any/all lease incentives/discounts/deals/program numbers
    Zip code 43110? Thank you!!!!
    .00300 MF and 75% residual
    Sorry, but no incentive info on the Silverado EV
  • Jay1345Jay1345 Member Posts: 1
    May I have the MF/RV/Lease Incentive for 2025 Chevrolet Silverado 1500 LT (2FL) Four Wheel Drive Crew Cab / (turbomax engine 2.7) in 14564?
    .00187 MF and 66% RV
    $1000 incentive
  • Sal93Sal93 Member Posts: 32
    Can I get MF/RV/ Incentives for 2025 silverado 1500 RST 2wd 5.3L V8
    36/12. Zip 94804
    36/12. Zip 94804
    Double or Crew cab?
    Double or Crew cab?
    Crew
    36/12. Zip 94804
    Sal93 said:
    Double or Crew cab?
    Crew
    .00173 MF and 61% RV
    Could you please also share the 24/10 numbers?
    Sorry, I don't know the original question
    EV RST Max Range in Colorado
    24/10
  • 2025colorado2025colorado Member Posts: 2
    Could I get MF/Residual/incentives for 36mo/12k miles & 24mo/12k miles in 85286 for the following models;
    1. 2025 Silverado Crew Cab 5.3L LT Trail Boss
    2. 2025 Silverado Crew Cab 5.3L LT
    3. 2025 Silverado Crew Cab 5.3L LTZ
    LT TB
    .00241 and 70%
    .00208 and 63%
    LT
    .00227 and 70%
    .00173 and 61%
    LTZ
    .00218 and 70%
    .00173 and 62%
    No lease inentives
  • shikataganaishikataganai Member Posts: 36
    Hi. When you have a minute I’d love the MF, RV, and incentives (I think there are none) for a 2025 Silverado EV in AWD Work Truck 1FL trim. 24/12 and 24/10 in zip 80238.
    I don't see a 1FL
    Standard, Extended, or MAX range?
    I don't see a 1FL
    Sorry, that was a package. 3WT trim so I think standard range. Thanks.
    .00365 MF and 89% residual
    No incentive info
  • mullymully Member Posts: 29
    Can you provide the MF and RV for a 2025 Silverado EV LT 24/10k and 36/10k in 77433 zip?
    Can you also provide the MF and RV for a 2025 Silverado EV RST Extended Range 24/10k and 36/10k in 77433 zip? Thanks again!
    .00292 and 85%
    .00284 and 79%
    .00300 and 75%
    .00205 and 69%
  • jleasejlease Member Posts: 40
    May I have the MF/RV/Lease Incentive for 2025 Chevrolet Silverado 1500 LT (2FL) Four Wheel Drive Crew Cab / (turbomax engine 2.7) in 19081?
    24/15
    Thanks very much!
    24/15
    Thanks very much!
    .00240 MF and 74% residual
    $1000 incentive
  • wheelspinwheelspin Member Posts: 67
    Can I have MF/RV for 2025 Silverado EV WT Extended Range? For 78738.
    24/10
    24/10
    .00365 MF and 82% residual
    .00350 MF and 78% residual
    edited March 20
    Hi. When you get a chance could I get MF/RV on a 24/10 lease, zip 80238, for a 2025 Sierra EV RST, in both Extended and Max Range 4WD if that's ok? Thanks!
    .00300 and 75%
    Either range.
  • Bluebullitt256Bluebullitt256 Member Posts: 4
    MF and residual for 2025 Silverado EV LT extended range for zip code 35640. 24 months 15k per year
    .00292 MF and 83% residual
    Can I have MF/RV for 2025 Silverado EV LT Extended Range?
    27/10 for 78738
    27/10 for 78738
    .00292 MF and 83% RV
  • md99800md99800 Member Posts: 40
    Can I have the 36:10 numbers for the Silverado 1500 WT, 4x4 please? I don’t know if there’s a difference but specifically I’m looking for the 4-door.
    Zip 83854
