Store Bought Waxes Part II (No Zaino Posts)
1293032343577
  • canccanc Member Posts: 715
    Is No. 26 any better than the Gold Class on your Solara?
  • westy5westy5 Member Posts: 24
    Thanks to all who responded; your advice is appreciated.
    Since this is a busy string and folks here pay attention to details, I was wondering if anyone has used a protectant (ScotchGuard, etc.) to protect their cloth seats and carpet?? Since my car is brand new, I wanted to get the jump on dirt and stains and didn't know if this was necessary.
    I know this questions is not related to Waxes, but I couldn't find a related topic. Thanks for your help.
  • protege_fanprotege_fan Member Posts: 2,405
    I used scotch guard on my new seats when I first got it. I don't know if it's working or not, as I do not allow food/many drinks in the car. :)
    I read that 3M is no longer making scotch guard, so you may want to stock up on it.
  • adc100adc100 Member Posts: 1,521
    hambone...I don't think it does either. But then again, I wouldn't expect any difference. I really am happy with the #26, but I can't resist trying other stuff.
  • mrdetailermrdetailer Member Posts: 1,118
    On my cars that are outside all of the time I found that the #26 held up for 7 months, but the Gold class help up well for about 3.
    I don't think that any eye droppers or hoses can really determine true beading behavior. It takes a rain to do that.
    On my Meguiar's #26, it beads clost to new for about 8 weeks when washed. Perfect-It by 3M even less.
    Yet with both waxes after a couple of months they still bead beautifully in the rain. And this is after the last 3 weeks of continual rain or snow. I washed again last Saturday before the outside hose froze and the cars still look great.
    Hope they can hold up until Mar -- April.
  • atokadatokad Member Posts: 30
    I took your advice adc100 and got the Porter Cable 7424..figure I might as well jump in with both feet!! I never used a buffer before so it should be interesting. I also got an accessory kit from CMA...Cant wait to try it..
  • hambone32hambone32 Member Posts: 68
    Canc,
    I haven't tried #26 on my Solara. However, I am certain it will last longer than Gold Class. Of all the nice things I can say about Gold Class, I cannot say it is long-lasting, which is why I'm putting on more durable wax for the winter.
    You will love the 7424. I have one with the CMA kit and it's an incredible combo. Worth every penny, IMHO.
    A couple comments:
    1. Make sure you use the 6" counterweight with the CMA pads, which are 6". The 7424 I bought from Coastal has the 5" counterweight installed and came with one 5" white pad. If you use the 6" pads you will notice vibrations especially at higher speeds (setting 5 and above). The 6" counterweight is like $2.00 but can be hard to find retail; no availability at Home Depot or Lowe's.
    2. The CMA pads are great but you'll want a few more to use with specific products. I don't know your product lineup but use one pad for one product to avoid contaminating the pads. For example, I use 3M SMR with one white pad. I wrote on the back of the pad "SMR" so I don't confuse what product with what pad. I do the same for the several other products I use as well.
    Have fun with your 7424. It's really easy to use and the results are outstanding.
  • pjyoungpjyoung Member Posts: 885
    Or you'll make that old sears buffer sitting on the shelf shed a tear and possibly rust.
    I'm such a wannabe geek.
    Sears orbital buffer
    Porter Cable 7424
    Eagle One 20/20 glass cleaner
    Sprayway glass cleaner
    I cant wait to get it!! I did get the counter weight when I ordered the machine from Coastal Tool
    Do you know where i can get Meguires Swirl Remover 2.0?? They dont show it on their website..they only shoe regular #9
    Whats a good speed for normal application of glazes/wax??
    LW
    From what I can tell the 2.0 is the new version of #9. It's available at my local autozone. If you don't see it on the shelf, see if they can order it in. It should also be available at auto paint supply stores.
    My local auto paint joint had 2.0 on the shelf. It was at my local NAPA as well.
    I start at speed 3 to first apply an even coat and work into the paint. I then bump it to 5 or so to finish it off. When you're done there should be almost no product to wipe off. If there seems to be a lot of product on the paint you used too much. Don't be afraid to experiment, though. A little trial and error, ya know.......
    I called Meguires and the guy said if you order from them you will get the newer version 2.0
    Does anyone know if you can layer #20 like Klasse and other polymers or is it a one shot deal??
  • joebob6joebob6 Member Posts: 239
    Never used #20 but since it says "cleans, polishes, and protects" I doubt it can be layered. The cleaners and polishing agents would likely strip the underlying coat.
    If there is anything that says it will clean while it protects, it cannot be layered. Try the #26. I had one that lasted 7 months this summer with 3 layers. Still looked great.
    If the Data in thewaxtext.com is accurate, multiple wax coats is more important than I imagined. They essentially declared most waxes dead after 2 months.
    I have 3 coats of 3M Perfect-It Show Car Wax on my Blaze Red Mazda. Snowed again last night. I use a block heater so the snow had melted on the hood. So far the beading is still excellent. Washed about 10 days ago and looked shiny for 2 days until the next snow storm came in.
  • dhanleydhanley Member Posts: 1,531
    I have done a few wax tests myself, and i must say, i wonder why my results are so very different than thewaxtest. Maybe our surface prep? Our test techniques?
    Meguiars gold class lasted a very long time for me, for example, and i was unable to duplicate their results with two of the higher end polymer products. For example, el cheapo zymol beads as well for me after ~3 months as klasse does.
    At this point, i'm starting to think that for me "easy on" is the most critical thing, as i hate fishing wax off the trim and out of cracks.
    dave
    I believe that they originally "prepped" the surface for the wax tests, but found that it turned out to be 90% prep and 10% wax. But I do believe that they only used one coat.
    Actually, in looking out for the "Average Joe" who isn't willing to put in the preperation hours that an enthusiast would, I think the wax test guys are giving some good information.
    But I think most of the posters on this and other boards are the types who will apply another coat of wax long before the first coat has quit beading. And I think more coats of anything will equal more protection. So you and Mr Detailer are most likely right - any of the posters on this boards cars would have better results than the wax test guys - we're all pretty much "enthusiasts" about it.
    I've found that using the Clay Bar then Glazing over time makes the wax finishes more durable.
    Have any of you used the Quik Detailer, and if so, have you applied it between Gold Class wax applications? I'm wondering if I can use the Quik Detailer between wax coats, just like the Zaino instructions.
  • truckdude1truckdude1 Member Posts: 88
    Our Dark green pearl Civic Just hit 6 months old.We want to wax it again, as the car is always outside, with no garage. The paint looks very shiny still, but is showing alot of swirl marks and the surface paint is rough ! What is a good wax for HIGHGLOSS SHINE and SOME PROTECTION?? Is it true you must use polish and then wax? or can i just wax it, i want a mirror shine from it, and the water isn't beading anymore so I need to wax it soon, please reply.
    Thanks-
    Truckdude1
    Yes, you can use Quik Detailer (QD) between wax coats if you like. It's not gonna remove wax so you're safe.
    Keep in mind you can't really build coats of Gold Class like you can a polymer sealant. If you apply three coats of GC you'll really end up with only 1.5 or so. This is due to the solvents in the GC.
    How are you? Long time, no talk.
    I can't remember if you've already used a product on the Honda, but if you have then applying another coat of it will be OK. It will give you a little protection that you need and get you thru most of the winter.
    However, if you want your car to really sparkle, then it will take some work and several products. Here's what I'd do:
    Wash - Use blue-colored Dawn to wash you car. This is a one-time only use. Blue Dawn has a formualtion that strips wax, dirt, grime, and yucky stuff off your paint.
    Clay - Your paint has a all kinds of crud on its surface. To check, run your hand lightly over the flat surfaces, or put your hand in a plastic baggie and do the same. You will feel a roughness; deposits that need to be removed. Body clay does this. It's available at all your fave parts stores. Brands are Meguiar's, Clay Magic, Mothers, etc.
    Polish - Now that your paint is clean, it needs polishing to remove any stains, dullness, and oxidation. Polish will make your clearcoat sparkle. Two suggestions are Meguiar's Medallion Paint Cleaner and 3M Swirl Mark Remover. Both are mild enough to not do damage but strong enough to remove most all swirl marks.
    Protectant - Lots of products will offer protection. A few choices here are Meguiar's Gold Class (lots of shine but doesn't last too long), Meguiar's Medallion protectant (lasts a long time but not quite the gloss of GC), 3M Perfect-It Show Car Paste Wax (great stuff and recommended by our own Mr. Detailer), Meguiar's #26 Hi Tech wax (a well known product widely used by detailers and car show folks), Eagle One Wet paste wax (easy to use and quite durable)
    These are just a few products; there are tons of things out there but at least these can be found in retail stores nationwide. NAPA carrys a lot of 3M products and Pep Boys also has a big selection.
    Hope all this helps.
    Well when the Honda was 3 months old we applied one coat of Meguiars Goldglass it worked well. But the car is still shiny good, but the paint isn't dirty, an PLUS we DO NOT have enough time to clean up the car that well, so all we can do is wax it, but i was wondering should we polish and wax? Will that make the dark green paint shinier than only wax? We want alot of mirror shine so our car stands out. Please help and im greatful for what youve said in your earlier post
    Truckdude1
    If you want it to look better then you NEED to polish first..there is no way around it. just waxing wont make a big difference if any atr all..all it will do is provide protection..the key to a mirror shine is surface prep..
    Ok, I understand the notion of surface prepping, but what if your car is brand new, like Truckdude's Civic? There shouldn't be that many contaminants on the paint yet.
    Well, the Gold Class is a combo polish/wax product. Actually, it's more polish than wax which is by design and why it does such a good job of making the paint shine. So if you're pressed for time the Gold Class will be fine. But when you want better results, the description I gave above will steer you in the right direction.
    Canc - Yes, a brand new car can use a good polish. You be amazed at the kind of crud that gets on a car while its sitting on a lot. And if the dealer's lot boy got to it with a buffer, swirl marks galore. New cars need mild polishes like glazes which remove and cover up swirls while making the paint look rich and glossy. Follow that up with a good wax or polymer and you've started the car off in fine fashion.
  • cnorthrupcnorthrup Member Posts: 74
    I am somewhat new to the whole routine of prepping, polishing, then waxing my car.
    I have new 330i which I did wax (One Grand) to get thru the winter. In the spring I will need to either use a mild glaze or a polish depending on the abuse it sees thru the winter. As of now it does have some very minor marks which were probably created during the dealer prep.
    My questions are do you always have to strip the old wax before you are going to apply a glaze or polish?
    I read a lot about dawn and today I see a referenct to blue dawn?
    Is this the same stuff as for dishes and if so what kind of dilution needs to be used?
    CNorthrup
    Re: blue Dawn. Yes, it's the same stuff you buy at the store. If you are using a five gallon bucket, a teaspoon or so will do for a one-time wash. The Dawn will remove the old wax and much of the surface contaminents like grease, oil, and most water-soluble crud. The primary benefit of Dawn washing is that it gets you to Square One. Now the finish can be evaluted to determine what the next step is.
    You don't always have to strip the old wax. Blue Dawn will remove most all of it, and any polish you use will remove what's left, if any. Keep in mind that most paste waxes last 90 days or so. If the One Grand product you've used is Blitz paste wax and it's been 3-4 months since you've used it, consider the Blitz gone.
    When the weather improves consider doing a full-tilt detail. Wash, clay, remove scratches, polish until the paint sparkles, then protect. Five steps minimum.
    For those of you who are interested in improving your detailing expertise or just want to expand your base of knowledge, here is a terrific guide to detailing, called "Autopia Car Care Guide To Detailing". It's available by download only and is on sale for $14.95 thru the holidays.
    This is a wonderful resource for any enthusiast, especially those who desire more from their car's appearance but are not sure what products to use and what techniques really work.
    You can read a few sections before buying. Even the info shared for free is informative and educational.
    http://www.autopia-carcare.com/accgtd.html
    Enjoy!!
  • britton2britton2 Member Posts: 305
    Meguiar's Quik Detailer is excellent - probably one of the best available and not too harsh on the ole wallet too -I usually use a quick detailer immediately after washing - I'm not a fan of wiping down a dirty car -
    I read somewhere that it really isn't necessary to polish a car for the first 2 years - however, if you must - the I'd try Eagle One's Polish and Wax - you can find their products at Pep Boys - everything they make is good
    Bretfaz: thanks for the info about car care. You seem to know your stuff around here. Anyway, you said that Gold Class is a wax AND polish? Can you explain that? Also, since I've never used a clay bar before (but you sound rather convincing), is there any way that a clay bar application can go wrong?
    Britton: Thanks for the info about the detailer. How's the Corolla doing?
  • binubinu Member Posts: 81
    The bottom half of my car doors are splashed with tar after having to drive thru road construction.
    I have tried dawn, turtle wax tar remover but have so far succeeded in removing 5 out of the 100 tar spots. Can anyone advise any better ?
    and the site goes nuts. Glad to see new and interested posters.
    I've found that some bug and tar removers are OK. But, if you want a fast product that takes it off with little effort you need to purchase Kleen Strip from an automotive paint supply store. You will need to rewax after applying Kleen Strip.
    Until you gett better information. I use Avon "Skin-So-Soft"
    the Corolla is doing great - last tank got 31.5 MPG (city) using 89 octane - very glad I got the car!
    Truckdude1, Canc, and all others interested.
    Yes, you can get your car better looking than new. My cars are outside all the time. We got a break in the weather Saturday so I washed the cars. Still gorgeous. Took a picture of the beading. Will try to post once I get the picture developed and scanned.
    Bretfraz had excellent advice.
    1. Any time the finish doesn't feel mirror smooth clay bar, clay bar, clay bar. Do a small section, wipe off and reapply if needed again. I did detailed instructions on this in an earlier post a couple of months ago. To avoid fine scratches NEVER apply glaze with a machine without using the clay bar first. I've found that a clay bar, and glaze every 6 months is ideal. Not too often, and still keeps the finish looking great. The first session may take a while, but subsequent ones are much faster if done regularly. In my view, all easily available clay bars perform equally. Meguiars was the most available, and the least expensive. Clay bars not only improve smoothness, but since the microscopic contaminants are removed, clarity improves.
    2. Glazes and polishes. Once my car finish has been restored, I don't use any higher grit surface Prep and swirl removers. I now use only fine glazes and polishes. If there is any "magic product" that deepens the shine, glazes are it. These products contain some type of fine abrasive like clay, or silicone and special paint nourishing oils. Meguiar's #7, according to their support has a clay that breaks down, and can't be overused. 3M Imperial Hand glaze is very fast with a machine, or by hand and leaves a slightly deeper shine in my subjective opinion. I use both regularly. They have dramatically improved the appearance, and, over time, produce a deeper shine with each application.
    However, if someone has a buffer and wants to use an extremely fine grit, I would recommend 3M Perfect-It Foam Polishing Pad Glaze/Swirl Mark Remover. If I had a newer car this is the one I would use. I tested them out in a shop by squirting some on my fingers and rubbing. This is substantially finer than any other product I've seen. Use the Dark Car formula for Reds, Blacks, Merlots, and Dark Greens or Navy Blues. Use the light formula for all other cars, including silver and gold. I used it on a white car last fall, and really liked the results. It will be part of my regular routine in the future. It is a little more technical to use so follow the instructions carefully.
    Yes, using a glaze is more work than a combination product, but the depth of shine is dramatic.
    3. Waxes. Pardon my French, but Zaino has some things right. First unlike most other products they do recommend using a clay bar for surface prep. Second they recommend using multiple coats of the final product. It's no surprize that they look good. I still won't use it because I prefer products that are more forgiving to use, and are less expensive. I also want to go to a store if I run out and pick it up easily.
    I found that no matter what I do, using a cleaner wax like Mothers Cleaner Wax, or Meguiar's Gold Class doesn't last very long. Using 2-3 coats of a pure "wax" without cleaners lasts much longer.
    Last April & May I did the techniques recommended above and put on a coat of Liquid Meguiars #26 Hard Yellow Wax with Carnauba, followed up a week then 2 weeks later with a paste coat of #26. Now granted, it was summer, an easier time for car finishes, but that stuff held up for 7 months and was still functioning well. The only reason I removed it was to put on a winter coat. And I had washed at least 6 times in an automatic car wash because it was free at the time.
    Frankly it was hard on my OCD car care behavior. With Gold Glass, to preserve the just new shine, I had to put on a new coat about every 6 weeks. The Hard Yellow was a lot less work. And at most required Quick Detailer after washing. But, honestly, it just didn't need another application. Oh, well, more time for the honey-do list.
    This fall I have 3M Perfect-IT Show Car Wax on 2 cars, and Meguiar's #26 on a third. 3 coats on 2 cars, and 2 on the other (It snowed before I could put on the 3rd coat of 3M.) Both waxes are holding up well so far, but the 3M on one car is a month older than the #26. 3M doesn't bead well after washing, nor does it feel like a wax coat like the #26 because it's mainly a polymer. But it does bead well in rain, and melting snow. It's performance has been impressive so far. Both still look very good. After washing Saturday, I could see a clear reflection of twigs and branches that were about 25 feet off of the ground.
    Final word. In winter if the hose at home is frozen, I am forced to use the Automatic Car Washes. Always pay the extra to get the wax application as well. It at least restores some of the stuff that might have been taken off by the automatic wash.
    If you go to Canadian Tire and looked at all their "waxes" most of them are products known as one steps. A one step product polishes and protects the paint in one step, hence the name.
    Depending on the product the cleaner is either a chemical-type or abrasive-type, but the job is the same; remove light oxidation, scratches, stains, and surface crud while leaving a coat of protection behind. Sounds wonderful, doesn't it? Well, like any product that is designed to do several things in one step, it doesn't do either job well. All these one step products compromise something somewhere. Regarding Meguiar's Gold Class, it's designed to polish paint to a high level first and foremost. As Mr. Detailer said, it doesn't last too long. That's the compromise. One steps are OK for the casual car owner; someone who doesn't want to spend a lot of time or money on their car. The best store bought one step I've ever used is Meguiar's Medallion (that sound you just heard is all the regulars groaning that I sound like a broken record, LOL)
    Your specialty and boutique products are designed to do one specific job. Polishing requires one product, protecting requires another, scratch removal needs yet another. For example, the last detail I did on my car used five (5) different products. There is no way one product can do the job of five specially designed ones.
    About clay - The only way I can imagine overdoing it is by rubbing too hard or not using an adequate lubricant with the clay. It's actually quite easy to use. I'll bet that once you try it you'll get the hang of it in 30 seconds.
    To remove tar I use a 3M product especially designed for the job. Most auto parts stores carry it and so does NAPA, who carries a lot of 3M. It comes in a little aerosol can and is called something like "Tar, Grease, and Wax Remover". Sorry, I don't have it in front of me.
    Kleen Strip, Prepsol, or comparable product from an auto body supplier will work great. The stuff I have is basically Naptha and mineral spirits. If you have that kind of stuff around the house, test it first on an inconspicuous area before using it on the tar. Most products like the above will work great for removing tar. Personally, I think that Turtle Wax stuff is lousy.
  • protegextwoprotegextwo Member Posts: 1,265
    ...the regulars and newbies at this discussion. I would like to extend my warmest wishes for a blessed and joyous Christmas. May the spirit of this holy season fill and brighten your New Year! Above all, be safe, spend quality time with your loved ones and enjoy the holidays in moderation.
    God Bless,
    Larry
    BTW my daughter in N.C. was looking for a new car and one of my recommendations (in fact the strongest) was the Protege. Nissan Sentra was out due to lack of dealership within 25 miles. Unfortunately when I went down there this last week there was a white Daewoo Leganza in the driveway. I almost passed out from frustration. She never takes my advice. I must say however that it is very well built. My main fear is warranty issues due to financial problems. Hopefully GM will come to the rescue.
    "Daewoo Leganza in the driveway"
    Well, Daewoo is producing some very attractive vehicles. The price is right and their cars appeal to younger new car buyers. Perhaps your daughter is like "the Honda Accord buyer of the early 80's"? She might be on, to a good thing? Nonetheless, how much advice did WE take from our parents, when we were young and living away from home? :-)!!!!
    Have a Merry Christmas my friend!
    -Larry
    Tomorrow were going to clean our car.We are going to wash with blue dawn. WE FOUND a product called "ZYMOL" looks great and costed 15 dollars.does anyone know if it works, to make our car like a mirror shine, thanks?
    Truckdude-
  • lossoullossoul Member Posts: 3
    I am new to the whole idea of the basic acts of washing, waxing, polishing and what ever else is used to help protect the paint and keeping the car looking great. I have always owned old beaters and my idea of washing the car was to wait for rain, but i just bought my first new car today and I want to keep it that way. So any suggestions would be great
