It it is a smooth surface. Treated the painted black trim as any other painted surface. I have a Mazda that responded well to this treatment. Your car will thank you. I generally don't wax the flat black paint like that found on windshield wiper mounts, and repaint it when the finish gets bad.
Specialized car wash soap is necessary between wax coats. My personal preference is Meguiars Gold Class Car Shampoo. In the spring you can get a large bottle for a pretty good price. This soap makes a well maintained finish pop. Really makes it look good. I also use Kitt Car Wash with Carnauba regularly. Other's I've used in the past that seem to work well are Turtle Wax Emerald wash, Blue Coral, Westley's. Probably just about any car wash will do a good job. They are designed to clean without stripping the wax.
Specialized car wash soap is necessary between wax coats. My personal preference is Meguiars Gold Class Car Shampoo. In the spring you can get a large bottle for a pretty good price. This soap makes a well maintained finish pop. Really makes it look good. I also use Kitt Car Wash with Carnauba regularly. Gives a good shine, but I don't really any special wax ability. Other's I've used in the past that seem to work well are Turtle Wax Emerald wash, Blue Coral, Westley's. Probably just about any car wash will do a good job. They are designed to clean without stripping the wax.
I just started reading out this thread. Interesting stuff. I haven't read all of it, but I've noticed people comparing the beading abilities of polymers vs. waxes. I would like to point out that just because your polymer is beading 8 months later doesn't mean it is protecting your paint (the wax that isn't beading obviously isn't either, though). UV is probably the most damaging thing to your paint, not water pools. Just because the polymer is still there beading water doesn't mean it's UV protectants are still there. The sun is brutal, and I would wonder if the UV protection in your "miracle" polymer is still cutting it. I would suggest that any type of protection you use should be put on 3-4 times a year (or more often). Any thoughts or info on the life expectancy of UV protectants?
I personally use Meguiars wax because I am pleased with the shine, cost, and ease of use. Plus I like the company. They seem concerned with making a good product, and have reasonable/believable tips for making your paint look its best. I don't begrudge anyone their polymers, but I just think that you should consider more than its long-term beading ability. At the worst, you'd have to apply it as often as wax...
Even if you don't like Meguiars, they have an informative clinic on swirl marks on their website. Check out www. meguiars.com and then click on "clinics". The biggest thing to prevent them is to use clean, quality towels and applicators, just as others have said.
If the finish feels even the slightest bit rough those contaminants will scratch the finish especially if a machine is used. I don't use a machine unless it is smooth to the touch.
I have a '92 Mitsubishi Eclipse that is in need of a good waxing. I have faithfully waxed it twice a year (for the past three years) with Meguiars' Cleaner Wax. As I have become more conscience of my cars, I would like to treat the finish better than with a simple cleaner wax.
The car sits outside in the Oklahoma sun and ice year round. I have purchased a bottle of Meguiars' Body Scrub and would like to apply this prior to a coat of #26. The car's finish isn't in horrible shape, but it does need some help.
Has anyone had experience with this product?? In the future, would I use the Body Scrub prior to each wax job, or should I use it every other time?? Every third wax job?? Also, I have a '02 Protege5 with a good coat of #26 on it. Is this type of Body Scrub used for semi-neglected cars only and not my new car??
The body scrub is a product that should be used on more neglected paint. If the paint doesn't feel smooth after you wash it, then use the scrub (gently run your clean hand over the paint to see if it feels smooth or bumpy). It is a cleaner that will remove contamination and such that washing won't. It does a similar job to clays, just in a different way. You don't need to use it every time you wax your car. Only use it when the paint doesn't feel clean from a wash. I wouldn't think you would need to do this more than once or maybe twice a year, if that. The frequency would certainly depend on how often you wax, how much time your car spends outside, how often you wash it, and a million other things. The Body Scrub is a mild formula, so don't worry about using it on your new car. But don't use it if the paint doesn't need it.
Meguiars cleaner/Wax is a great product. Don't feel you need to stop using it if you like it. You might try polishing the car first if you want some extra shine. If the paint is nice and smooth, the body scrub won't shine it up much. It is mainly to remove bonded contaminants. If your paint needs the scrub, go for it. After that, you might start using polish before the waxing if you want to.
Any of you polymer fans ever try Meguiars Polymer Sealant (#20)? Also, anyone know if Medallion Premium Paint Protection is a polymer based product? I like the shine from Gold Class Wax, but wouldn't mind checking out the Medallion if it provided similar results but lasted longer.
It's a pretty harsh product, IMO. It's fine for neglected paint jobs that are quite oxidized and rarely see protection. It doesn't sound like the Eclipse is in too bad shape but only you can see it. If you want, try some Body Scrub on a small area to test effectiveness.
Personally I think it's best to start with something mild and less abrasive. If that doesn't work then escalate the aggressiveness of the product. I'd suggest starting with Meguiar's Swirl Mark Remover 2.0 (newest version of Meguiar's #9 SMR). Or try 3M's Finesse-It II polish available at NAPA and other auto parts stores. The 3M product is a bit more aggressive than the Meguiar's 2.0.
If you want to stay all Meguiar's products then consider this system: Step #1 - Clean paint with paint cleaning clay. I don't care for Meguiar's clay (too soft for me) but Mothers, Clay Magic, and Eagle One are all good choices for clay. This will remove the surface crud you can feel on the paint. Step #2 - Meguiar's Mirror Glaze #2 Fine Cut Cleaner (if you feel your paint job needs some serious cleaning) Step #3 - Meguiar's Mirror Glaze #9 Swirl Mark Remover 2.0 which will remove the swirls you put in with the #2. Step #4 - Meguiar's #26 paste or whatever non-abrasive wax you prefer.
If you do this killer detail you only should need the #2 once per year and can do the clay, #9 and #26 2-3 time per year.
The Meguiar's products in the burgundy-colored bottles are their mass-market consumer line. They're OK for the person who wants a simple product that doesn't cost too much. If you want better results and product performance you need to step up to meguiar's Mirror Glaze professional products in the tan bottles. Many auto parts stores carry them as do auto paint stores. Once you start using the Mirror Glaze products you'll want to trash the Cleaner/Wax stuff as the MG line provides much better results.
rjs- I haven't used #20 but I think Mr. Detailer has. I've heard some nice things about it but I've also heard that products like Klasse, Blackfire, and Zaino outperform it. Medallion is a polymer product (no carnauba, IIRC). The difference between Medallion and Gold Class is that Medallion is designed to last a very long time where GC is designed to provide a very high gloss at the expense of durability. I think Medallion is the best one-step store bought product I've ever used but the paint has to be in very good condition as Medallion has a very mild chemical cleaner in it.
On the body scrub bottle I bought it said to use if you only waxed once a year. On neglected car finishes it's a great product.
But I threw away my bottle. Why? because once you get the finish restored if it's protected you don't need it.
It did NOT take the place of a clay bar in my experience. On 2 cars with neglected finished I used a Meguiar's Swirl Removal and Surface Prep, then the Body Scrub. On the red oxydized finish the red really came off with the Body Scrub. More so that the Surface Prep with a natural abrasive. When I was finished it was still a rough surface. The next spring I used a clay bar and the finish is now glassy smooth.
I wouldn't use the Body Scrup on a new finish, use #7 Glace and #26 Hard Yellow for a durable finish. And, nothing will make the car as smooth as a clay bar.
I would think Fine-Cut cleaner would be harsher than the Body Scrub. Also, isn't it made to be applied only by rotary buffer? The body scrub is certainly harsher than the Swirl Removal and Surface Prep (I assume this is the Gold Class product that they don't offer anymore). The SR&SP was supposed to be a polish with some light cleaner in it. I would think you should have applied them in the opposite order (scrub then SR&SP) I have used SR&SP without much success. I wonder if I got a bad bottle of it, though, as it applies funny and it is almost impossible to wipe off (maybe it was stored in the sun or something before I bought it). Good call on pointing out that the paint on that Eclipse doesn't sound too neglected. I was going to point that out, but got caught up in explaining what the body scrub is supposed to do. I have to say, I had a Corvette that was kept outside for 4 years, and I never felt the need to use a cleaner or clay bar on it. I washed it all the time and waxed it all the time with Gold Class wax (about once a month). The finish never was rough after a washing. I think if you keep the paint clean and protected, the gentle cleaners in polish and wax will do just fine.
bretfraz: Thanks for the info on the #20 and the Medallion. I seem to be a sucker for the Gold Class emblem, even though I keep thinking I should switch over to #7 and Medallion wax. The swirl removal clinic on Meguiars even mentions that #7 will get rid of (or maybe hide) light swirl marks (which are all I ever get).
Good point. I called Meguiar's and they said Body Scrub is a non-abrasive cleaner (i.e. chemical cleaner only) and that it is less aggressive than Fine Cut, which is both a chemical cleaner and light abrasive. I've had great success with Fine Cut but you're prolly right, it may be too aggressive for that Eclipse. So maybe start with Body Scrub then follow with a polish like #7 then wax. Remember that #7 is mostly oils and fillers with a very light polish that fills and hides more than it removes swirls. #26 or Medallion will work well over the #7 (I've used both that way) but #20 won't like the oils in #7 and won't bond well with the paint.
I agree very much that beading is at best a poor test to determine if your finish is being protected or not. On the other hand, a real, valid test would probably cost a lot of money to do. For example, polishing a painted panel every day for a year and subjecting it to a harsh conditions chamber.
I am currently using Meguires #20 and #26 and it is producing very nice results. The #20 leaves a good shine and you can use it as a final product. However take the extra time and use #26 or Blitz on top and it will look 100% better. It has been 2 months since I applied the combo and the paint is still smooth and slick..
I'm still not sure what to do; it's ultimately my call I guess. If the paint is in decent shape, would it be best to use the #7 polish followed by a coat of #26?? What will the harm be (if any) in using the Body Scrub if my Eclipse really doesn't need it??
I used the #26 on my '02 Protege5 and loved it and have contemplated purchasing a bottle of #7 polish. Would I use the polish everytime I waxed my car?? Unfortunately I cannot comment on other products as I an still new to this "serious" detailing business.
Do yourself a favor and when your container of #7 is used up try the 3M Imperial Hand Glaze. Its much easier to use IMHO. I'm really not a 3M fan. I don't care at all for the 3M "Perfect-It"
Your #7 and #26 would be a good combination for a car with a finish in good condition. I use the polish just 2 times a year, spring and fall. Overkill if used more often in my opinion.
With ADC, I like the 3m Imperial Hand glaze, and use it with a machine regularly. It seems to give a slightly deeper shine. Both Meguiars #7 and Imperial Hand Glaze are good Products. On your newer finish there is a Milder 3m polish called Perfect_It Swirl Remover and Foam Pad polish, or some other absurdly long name. It must be used by machine, but i really liked the results. Choose the dard for reds, blacks, or other rich colors. choose the light for silvers, golds, and other medium, or light colors.
Westy5: I don't think there would be any real harm in using the body scrub. It would just cleanse the paint. It really shouldn't remove much if any of the paint layer. If you are still concerned, maybe you should try a clay bar instead. Body scrub should help with swirl marks if you have them. I don't believe clay does anything for swirl marks. As mrdetailer said, if it doesn't seem like it needs cleaning, then don't bother with any of it. Just polish and protect.
What sort of interior cleaners do people use/recommend? I have been using Meguiars Gold Class interior something or other. I like that it is non-greasy and doesn't create an unnatural shine, but it doesn't smell that great. It smells chemically. Also, what happens if interior products get on wood trim? I always make sure to wipe it off immediately, but you never know when you'll miss something.
What do people use on real wood trim? My owners manual recommends water, but there has to be something better than that...
I've never tried any of those clay products. Can the clay be used more than once or does it get tossed after use?
For the Dash 303 has the most UV protection, and produces a nice mat finish to cut down reflection. I also like Meguiar's professional (#46 I believe) Interior cleaner. They are better than the Gold Class. However, I'm going to use my current bottle until it's gone. It is pretty good. I've also heard that Lexol is very good.
Instead of water for a wood finish I recommend Murphy's Oil Soap. I even wash furniture if the little ones have gotten some type of sugar coating on it.
So I'm posting this to get the topic back to the top of the list - surely the weather hasn't been that bad that some of y'all couldn't get a quick wax in...or has it? We had a gorgeous weekend here in KC a couple of weeks ago, followed 2 days later by the ice storm from hell. Almost 400,000 people without power at one point. One thing I discovered - a good coat of "wax" helps the ice fall off the car!
Now that you mention it, PJ. Guess I haven't been paying attention too closely.
Weather here in the ATL has been pretty good this winter so I've been able to keep the car clean and get on a few coats of Souveran here and there. The Blackfire underneath has been holding up really well so I haven't really needed to wax, just been doing it for the added depth and slickness more than anything.
Maybe others will chime in with their winter detailing challenges.
400,000 w/o power? Man, that's unbelieveable! Hope everyone's back online. The power in my area went out during an ice storm 2 years ago. No juice for 2 days. Not fun.
Just the thought of not having power during the wintertime makes me shudder. I was in the Ice Storm we had here in Canada, and in our Canadian winters, we didn't have power for 2 weeks...
On a lighter note, my winter detailing consists of washing the car with Zymol car wash, and detailing with Meguiar's Quik Detailer. The Gold Class wax coat seems to be holding up pretty well so far.
For the past 3 or 4 days, due to driveway repair and repaving, I've had to park my car out on the street. Wow, does it get dirty fast! (Having the crew scraping the asphalt off the driveway and rolling on a new layer probably didn't help either.) Open-air living really dims a finish. I will have to wash the car and wax it again -- after the driveway sets up so I can drive on it. Maybe next week...
The weather has been unbelievably warm for winter in upstate NY. Average temperature was 9 degrees above normal in January; November felt more like September; and it has been abnormally dry since last summer: very little snow or rain.
Great for car detailing--was applying protectants outside as late as Thanksgiving week and could have done so even later, and have been washing the cars more regularly during the winter than anytime in the last ten years, at least. And they stay clean--for winter anyway.
Unfortunately all this warm, dry weather has at least one drawback---upcoming drought. They've already got warnings down in Pa., and if things continue like this NY can't be far behind.
Too blasted cold. Coldest winter in 20 years. Average temperatures are 10 degrees below normal. Had to break down and use wand car wash a couple of times.
in my area have been having a little "wintertime fun", which consists of keying cars in parking lots. A friend had his Grand Prix keyed at an elementary school open house last Thursday, and my wifes Taurus got keyed at a grocery store parking lot yesterday afternoon. Both cars got scratched to the primer. I swear, I.m going to hang out at the grocery store parking lot with a video camera and catch the weasles that are doing this. Sorry to be off topic, but I gotta vent.
You are probably violating their civil rights and might get sued. Just kidding, but its not far from the truth. In the old days, if you caught a kid doing that you probably could kick his but and get away with it. I pray for the day that I wind up on a jury where someone is suing someone else. definitely vote against the plaintiff
Here in Kansas City, six people were suing a restaurant because they got sick after eating a meal served at a conference they were attending. Plaintiffs were seeking $40,000 in damages. The jury awarded $121 to split between the six of them. There is hope.
Wen people finally get tired of the fact that lawsuits drive prices up maybe the stuff will end.
In keeping with the topic. I have used #26 on two of my vehicles and have several coats on them. I used some Collinite Fleetwax over the #26 and also on the wheels (on one car). I'm trying to decide whether I want to either clay, remove the wax with Dawn, or just continue with a layer of #26 on one car and the Collinite on another. They both look really good and really neither of them is a garage queen. No garage.
I placed an order from Meguiars that arrived last week. I ordered both Medallion products and #7 along with their Extra degreaser. The Extra had cracked at some point during it's shipping and sogged up the box, and ate up the labels on everything. I called Meguiars and they didn't hesitate to reship my whole order. I am interested to try out the Medallion protectant. I was pleased that I didn't have to argue to have my shipment resent.
As far as personal injury type lawsuits, I think is isn't so much that jurors think the huge award is reasonable, but rather they think if it happened to them, they'd want to cash in. I can't imagine any juror thought it was reasonable or fair to award some smoking idiot $3,000,000,000 because he got emphazema. Some dope was awarded $400,000,000 in a suit against GM because he got ejected from his 10+ year old car in an accident. He didn't even have a seatbelt on, but jurors still awarded it. Then again, maybe they do think it's fair. Most people don't feel they are responsible for what they do or for what happens to them. Society's response to anything bad seems to be "Why doesn't/didn't the Government do something?" as if you need the government to point out that smoking is unhealthy, or that wearing a seatbelt is a good idea...
You're assuming that many of them WILL be able to buy a $25,000 car!
Can't wait for the warmer weather to get here so I can wash my car myself instead of using the high pressure touchless wash or the wand wash! My car is clean, but not the way I want it to look.
I was assuming they'd buy a $5000 car with a $20,000 sound system...
I was wondering, what can be done to repair a keyed car? Is it usually expensive?
I agree that touchless and high pressure car washes aren't the same as doing it yourself. My friend, who had her van pinstriped, brought it to a high-pressure car wash. The pinstripe was broken off at one end and when she washed the car with the high pressure water gun, the pinstripe flew off!
EVEN up there they have those deafening sound systems that rattle the house windows? Maybe that's why they're not learning anything. They're all deaf!
A keyed car sounds like a job for a professional to me.
I like pinstripes on a car, but the painted on ones are much more reliable. Had that done on my 94 Infiniti J-30. I watched as the guy measured and taped the area and used his little roller bottles to do the job. Perfect. No problems.
My friend who's car was keyed (Grand Prix - drivers side rear door) told me that it's gonna cost $500 to fix his. I can hardly wait, since they got the entire drivers side of my Taurus (front and rear fenders and both doors).
I don't think he put clearcoat on. Did the 94 Infiniti J-30 even have clearcoat? He had all these little roller bottles in all different colors. He had a book, I think, of different designs. He was independent of the car dealer. They just hired him to paint on the pinstripes. Mine was two-tone. You might be able to see them in my pics at Geocities. Just click on my profile above or here-
http://www.geocities.com/MotorCity/Flats/7501/ and scroll past the 300M soap opera story to get to the Infinity pics as well as pics of my other cars. I wish I still had ALL these cars to drive except the 300M. That I just liked to LOOK at! ;-))
Nevermind. I must have had the pinstripe put on after I took these pics. I know I didn't have them on when I picked up the car. Sorry. If I find more pics of the Infinity, I'll post them after I get back from FL next week.
Anyone ever heard of Liquid Lustre? Pink liquid paste squirted out of bottle. I saw it at Darrell Starbards custom car and rod show?? Does anyone have experience with it?
Believe it or not, I have this stuff. Kinda long story as to why. Anyway, I've tried it on my car with so-so results. Didn't seem to remove swirls or surface crud very well. Left a decent but not super-slick finish. Easy to apply and remove with a MF for the most part. Has a pretty strong solvent smell. This usually means that over time it will dry out the clearcoat.
I'm gonna detail a friends car with it when I get around to it. I'll let everyone know how it works but so far its just average.
1)What really works well... 2)Is readily available in town... 3)Not real expensive and lasts... 4)Takes a licking and keeps on ticking type of car wax protection...
Thanks for your reply brezfrat...
rjs-how is the Aurora 4.0 doing? What have you found out with your products you got?
works as well as regular and frequent washing and waxing. No miracles. Name brand (Meguiars/Mothers) carnubas and separate polishes will give you good service. I'd stay away from combination cleaners/waxes like the Zymol at Walmart. If your willing to mail order 1Grand, Malms or P21S make relatively good products that, IMHO are slightly better than national brands. Generally, it is the last 10% difference between a show car finish and a detailed daily driver that most folks are discussing in terms of gloss, depth of shine, etc... Very hard to achieve on a daily driver. Personally, I have used Malms over the last 2 years and been happy with results.
There is no one product that does it all. The best looking cars got that way thru hard work, multiple products used in a specific manner, and a good amount of money spent on tools and products.
The vast majority of stuff you find in stores is produced and marketed to the masses whose expectations aren't that high. You can find a few diamonds in the rough but it can be tough digging. The auto appearance products industry sells and markets so much snake oil and stuff with mystical properties that you really need to know what you're doing or you'll get sucked in. At least this stuff doesn't cost too much; that Liquid Lustre cost me $20 for two bottles.
The best performing and/or longest lasting products are the boutique products like Klasse, P21S, Blackfire, Zaino, Pinnacle, maybe a couple others. None of these can be readily found at retail. The sale of these products are limited to those who are willing to spend the $$ and the time to make their cars look terrific. Many of them require a certain amount of expertise in order to get the best results.
But you can get very nice results with products bought in stores. Technique matters much more than product here. Brands like Meguiar's, 3M, Eagle One and Mothers make good products that are fairly easy to use and can be found at retail (if you're willing to search a little bit). Keep in mind that you'l still need to use several products and multiple applications to get the best shine and longest protection out of them.
Actually, I find myself a bit more skeptical of mail-order-only products. The fact that a company has bothered to establish a relationship with some physical store is a good sign to me. I order almost all of the products I get, but they are products that I could find at a store if I had to.
Aurora5000: The Aurora is doing great, how's yours doing? What have you been using on it? I will be trying out a combination of Meguiars Medallion paint cleaner (to get out some very light swirls from the dealer) followed by their #7 and then Medallion Paint Protection. I always used Gold Class before, so I will post my impressions of this new combo. Hopefully this weekend will warm up a bit.
What I have found is that it's very important to use the best quality bonnet available and they've got to be extremely clean.
Many of the terry bonnets in stores are poor quality right out of the package and get worse with use.
Some of the buffer mfr's sell or distribute bonnets:
http://www.gem-industries.com/main.html
http://www.hescoinc.com
http://www.nealsharbor.com/wax.html
Hope these help. BTW, what product are you using that's creating these swirls?
As always, your thoughts are appreciated.
dave
#20 is also good for clear-coated rims too!!
WESTY
Brenda
The cigarette companies got busted for lying about their own reseach for years, and for marketing to prohibited audiences.
Not sure about the GM suit you reference.
dave
Sorry, off topic, but HOMEWORK might be a good alternative and parent(s) who know WHERE their kids are and with whom!
fastdriver
I wonder what they'll think when they'll be older and they'll buy a $25,000 car and someone scratches it carelessly.
fastdriver
fastdriver
Anyway, about the pinstripes, I've never heard of painted-on pinstripes. Did the guy put a clearcoat layer on top after?
fastdriver
fastdriver
