Store Bought Waxes Part II (No Zaino Posts)
http://www.3m.com/US/auto_marine_aero/aad/
Click "Car Care Store"
-Murray
I took my car thru one of those touchless washes once this winter. Won't do it again. It did a terrible job and who knows what is being sprayed on your car!
My 2 cents only.
The water restriction reglations do not apply to businesses that require it, like car washes. So I take my car to the local coin-op for its regular bath. Been doing this on and off for almost 9 years.
Just take your usual car washing tools and lots of quarters. Find a good car wash that has room to work and is clean. Just use the "rinse" selection and stay away from the other stuff. Save the waxing and polishing for when you get home.
It's a bit of a pain but it works for me just fine.
Droughts must be relative. It's hard to image how Ya'all in the East can even have droughts with all your green trees.
Later,
Al
I was under the impression that some car washes recirculate and filter the water so they don't use nearly as much.
-Murray
http://www.properautocare.com/klasapguid.html
This site also reviews swirl marks.
I'd be leary of the product.
Check this site.
http://www.autopia-carport.com./ForumIndex.htm
The coin-op seems to use more water because the pressure is higher, but in fact it uses less than home washing, on average. That is why some areas with water restrictions will allow coin-ops to operate, but will restrict washing the car at home.
Water recycling at coin-ops: Coin-ops in much of the country don't recycle water--they are connected to the sanitary sewer or else use dry wells.
In some areas however, water reclamation systems have been required for some time for any new car washes opening up (particularly in the South and Southwest). Drive-thrus are another matter--most have water reclamation systems.
Even those must be hooked up to the sanitary sewer, however, because reclamation systems only capture about 70% of waste water used at a car wash.
Forcing car washes to retrofit is difficult--water reclamation systems cost between 50K to 100K, which is too much for many of the Mom-and-Pop type operators to afford.
Up here in Central NY we were on the border of drought warnings for the East Coast. Got 2 and a half inches of rain yesterday, and a few inches of snow the day before--Flash flood warnings in several areas--so I am hopeful that we will be able to avoid drought--so I can wash my car at home (among other reasons).
But if you are unfortunate enough to live in a drought stricken area--Bretfraz's suggestion for using the coin-op is a good one. I grab a bucket (a couple actually) and use them every couple of weeks during the winter (unless there's a break in the weather)--and it does a pretty good job for me.
I don't turn on the hose until it is in position, and turn it off if I have to move over a pre-rinsed area. I'll bet I don't even use 10 gallons per car. I definitely use more water in the shower than washing my cars.
Doing a little internet search I saw estimates of between 3 to 12 gallons per minute out of a garden hose. So unless you are only spending 2-3 minutes rinsing your car off (possible, I guess, though not for me)--odds are you are using more than 10 gallons--not including what's in the bucket(s).
I use a shut-off valve on my garden hose too...but I spend more than two minutes just rinsing the car off before I ever start washing it.
Thanks, MOD7
It is essential to get it off as quick as you find it. I've seen it etch paint. Thank heavens, not on mine.
What water falls on the driveway generally goes into the downhill grass beside it. Gnerally not much.
Don't forget that a home wash is almost free. I can buy 2 years worth of car wash soap for the price of just one fancy wash.
1. Subaru -- white -- one coat only of 3M Perfect It Show Car Wax.
2. Dodge -- Meguiars #26 wax, 3 coats
3. Mazda 3 coats of Perfect-It Show Car Wax.
We had a good rain last week and I found the following: The single coat of 3M was still beading, but the general appearance seemed flat and didn't bead as if newly applied. I had waxed the hood on the Dodge with Meguiars #26 just a week before the rain. It beaded fairly well there, but surprisingly not significantly less on the parts that were not re-waxed. Not quite ready to refinish at this time. The Mazda still beads great at this time.
We had a beautiful Saturday so I decided to work on the Subaru since it needed it the most.
Washed the car twice with Dawn. Then I stripped -- LET ME MAKE THIS CLEAR -- the car surface with Klean Strip Surface Prep and Wax remover that I obtained from my Auto Paint Supply Store for $4.13 a quart.
Next, I did a clay bar treatment. It obviously gets easier and faster if done regularly. It only took about 45 minutes and I can still use the bar again. By then, I noticed that the surface was starting to shine more.
I then washed the car again. I was astonished when it beaded well at this stage, even though I had used nothing but Blue Dawn to wash it, and no wax or glaze had been put on the surface.
I applied a coat of 3M Imperial Hand Glaze with my wax buffer on the hood and roof, followed by a 3M Swirl Remover for light cars (a finer grit) on the entire surface. It was also applied by the buffer.
The last thing was a coat of 3M Perfect_It Show Car Wax paste applied by hand.
While the car looked good before, it really shines now. Clarity and depth definitely improved. In a week or 2 weather permitting I'm going to add a coat or 2 of Meguiars #26.
Conclusions for me.
1. Surface preparation is at least as important as the brand of wax used.
2. The value of using a claybar 2 times a year cannot be over estimated. It even stops swirl marks from forming because there is no grit. I've never used a machine without a clay bar first on my Dad's dark green Taurus, and his 1995 looked much better than his neighbor's 1998 Taurus of the same color. No swirl marks.
3. Glazing is indispensable. It removes small surface imperfections and adds depth to the shine. A very smooth surface doesn't allow pollutants to stick.
4. Combination cleaner/waxes are not as durable as doing a glaze, then waxing separately. It's actually less labor in the long run.
5. Paste waxes if applied by hand to a well prepared surface really go a long ways and are very economical in the long run. I have a can of Meguiars #26 that I have used for 3 years on 6 different cars -- over 35 separate applications.
6. In winter don't hesitate to use the automated car washes as long as wax is also applied. It only costs a dollar or 2 more. It seems to help strengthen the durability of the remaining wax. I also found that the more expensive exclusive car washes use better products than the gas station ones. Our cold winter simply wouldn't allow hand washing for at least 4 months this year.
4. Multiple coats of wax protect far better than a single one. My Mazda has 3 coats of 3M Perfect-It Show Car Wax. It has gone a full six winter months -- still looks great and still beads. The Subaru with only 1 coat of the same wax was getting flat by 5 months. 3 coats of Meguiars #26 lasted better than one coat of 3M.
5. For the peak of perfection the claybar-glaze should be done in spring and fall, with an additional coat of wax applied every 3 months between by hand. While the wax may still protect, I definitely noticed the higher reflection when I put a coat of #26 on the Dodge's hood. Nothing else was done.
As far as the products, it appears that 3M is more durable in winter, though it's beading is not as obvious. Last April I put on 3 coats of Meguiars and they still looked good into the next October -- November. On a well prepared surface both products are highly recommended.
I'll update you again on this in about a month when I redo the Mazda.
The Sandman
If you have not done the multi step process before I would also recommend Meguiars Surface Prep #2 before glazing. It gets out light scratches without out being as harsh as rubbing compounds. After a good prep I only use glazes.
I've had to order the 3M Perfect-It Show Car Wax from the Internet at
http://www.3m.com/US/auto_marine_aero/index.jhtml
and then click on Online Store. I also really like their Surface Prep 70 and ordered a gallon of it last Thursday. For a while SHIPPING IS FREE. You can also order the Imperial Hand Glaze and Perfect-IT Foam Polishing Pad Glaze and Swirlmark Remover (The latter is very fine, and best for newer vehicles.) Make sure to choose dark for navy blues, hunter greens, reds and blacks. Use light for light to medium colors.
You might want to see if you can get a quart size of glazes as well. The quarts of glaze I bought at the paint store cost 16 for IHC, and 19 for the Perfect-IT. 3M glazes produce the richest finish to me.
Glazes should be applied lightly on the foam pad. So once the surface is well prepped, it won't use much.
You'll find some Meguiar's stuff at NAPA as well as Pep Boys. Was at a few AutoZone's and Advance auto parts recently and saw several Meguiar's items there too.
But 90% of my products I get online. Several regular posters as well as myself have provided links to the online retailers we use and trust. Do a little searching and you'll find them.
I've had a high shine since I started detailing, but this combination really pops.
2. On the clay bar, I have used a number of quick detailers. Meguiar's #34 Final Inspection, and Erazer quick detailers are my current faves. Water, or soap and water didn't work well for me.
Hope this helps.
Perfect-it SMR also contains fillers but is a bit more abrasive than Imperial Hand Glaze, I think. It definitely does more to get rid of swirls and marring.
The foam polishing pad glaze is the mildest I have ever seen, but together with Imperial Hand Glaze they produce a great finish.
Personally, I don't go stronger than that, and make sure to use a good Carnauba since it fills in swirl marks.
Thanks in advance, and my apologies for asking this question again.
3M Swirl Mark Remover
Imperial Hand Glaze
Imperial Machine Glaze and Foam Polishing Pad Glaze.
Since the finish is in good shape I NEVER use a swirl mark remove now. I just use glazes.
My father has a very dark green Taurus. Now, I always used the clay bar on this one, then glaze, and then wax. The machine didn't scratch it at all. This car has absolutely no swirl marks.
My questions is: "Since my paint is new and in great shape, I am not wanting to polish, clay, etc., but simply put on a good coat of wax. Do I need to strip (blue Dawn) off my existing 3 month old wax, or can I simply thoroughly wash the car with a non-stripping soap and apply a new coat of #26??"
Your comments are appreciated.
Still, I can't manage to remove oil marks on the bonnet completely. Clay bar remove mirror paint.
And I highly recommend claying and polishing. Even brand new cars need it. The best detail jobs I've ever done have been on brand new cars and all needed some amount of polishing.
After you wash you car, lightly run your hand along the hood and roof. Feel any roughness? That is surface contaminents that need to be removed prior to waxing/polishing. Body clay removes them. A light polish followed by the #26 and your car will look and feel better than it did when it came from the dealer.
You may want to hunt around the local independent auto parts stores to see if they have any 100% cotton chenille mitts in stock. I've been to numerous AutoZone's and Advance auto parts in three states and none had 100% cotton mitts available.
