Visitor Agreement.
These guys have most everything,
Northern Shield Protective Coatings
827 Danforth Place
Burlington, Ontario
L7T-ISI
905-522-7343
Canada Only-800-913-9299
E-mail nspc@attcanada.net
Ask for David
Also check out UAP/NAPA stores
Don't forget to consider the many online retailers. Perhaps ask http://www.autobarn.com , http://www.autodetail.com , or http://www.autogeek.net .
Finally, you may want to contact the mfr's directly and ask if they have dealers in your province.
Hope this helps.
Second: what is the best product for the plastic on the outside of a vehicle. I have a jeep grand cherokee laredo that has the lower half of the vehicle covered in a gray plastic (unpainted). any recommendations on protectant that will not discolor when they wear off?
My Mazda has Gray trim. Eagle One Wet Tire Gel works really well as does Meguiars Trim protectant. But I don't know of a product like that that doesn't give a richer appearance when applied. But the Eagle one is so easy to apply even on damaged surfaces, it can be fixed easily if washed off. I apply Eagle One about once a month.
Also when you wax the paint, put some masking tape on the cladding where it meets the sheet metal. If you get wax on the cladding by mistake you'll spend an eternity getting it out of the textured plastic. Just a little tip from someone who's made that mistake a time or two. :-)
In which direction should clays be rubbed on paint? Circular or sraight back and forth?
If you are using Klasse, you probably would not want to use a glaze unless they recommend it. Pinnacle is a Carnauba type and a glaze would be good. Both brands of "wax" are considered very good. It's down, but Pinnacle had the top performing natural wax in both shine and durability. Klasse was also listed as very good if both products were used, the all in one, and sealant.
psalms
Before you do that look at the MSDS of Blue Poly. Just for grins.
If I remember right your vehicle is pretty new and if you garage it all the time you may not have too many pollutants.
Thanks for all the advice.
psalms
I got all fired up reading this thread and ordered some Erase clay, Imperial Hand Glaze and Collonite wax and still haven't had time to get it all done. It looks like I will have to give up golf one day and just go for it.
If anything, try getting an aluminium polish such as "Mother's Aluminium Mag Polish". It comes in a small (red!) can, and it might work for you.
I have seen the Mothers Aluminum Mag Polish but then I was thinking that my wheels don't really fit my description of 'Mags'. I thought Mags were the giant silvery wheels, more chrome type wheels. Perhaps I am over-analyzing, but I really don't want to mess up my wheels. I just would like to know a good polish to clean what the spray cleaners leave behind.
Canc, thanks for responding, I appreciate it. I know this board is about waxes but I don't know where else to go for help.
Ask away.
I am completely comfortable with a clay bar and glaze in one day, then waxing later. Getting the very smooth surface and the extra nourishing oils in the paint right away should be fine for at least a week.
If you're just going to use a clay bar, I would use Meguiar's Quick Detailer as your lubricant It has a tiny bit of wax in it and may help. The problem I see with just a clay bar (experience here) is that if it rains water spots may appear that require claying again to remove. Maybe your rain doesn't leave the stains mine does. Lots of dust and salt from the desert get into our rain before it hits the mountains and drops its load.
As for the MSDS of Blue Poly, I only mentioned it so those who are interested in it can see some of the ingredients. Here's the link to P-QS MSDS files:
http://www.pennzoil-quakerstate.com/techdata/l7_msds_fs.htm
You said you used an Eagle One cleaner? Was it A2Z wheel cleaner? If so, that stuff is pretty strong and will remove a good amount of wheel crud but not 100%.
If the crud you're talking about is black then its disc brake dust. That stuff can cause some real problems if not cleaned completely. Some types of pad dust can become acidic if mixed with water and etch the wheels. So you'll want to get this stuff off ASAP.
First, try rubbing the discolored areas with your finger. Does it come off that way? If so use a soaped up soft cloth and scrub lightly to remove. You can also try using a soft bristled brush to scrub hard to reach spots. When
I clean dirty wheels (like I did today) I sometimes use 2 or 3 different brushes to get them totally clean.
If there is still discoloration after cleaning then try applying some polish to the area. I assume you have some wax/polish around. Sometimes a little aggressive polishing will remove stains and spots. Experiment a little.
If the discoloration still remains after all that then it's possible the clearcoat or paint on it is damaged. Kinda hard for me to say without seeing it but it does happen.
Good luck, let us know how things go.
The discolored areas do not come off on my finger when I rub it. Canc recommended Mothers Aluminum Mag Polish, is that the stuff to use? Also, what wax is good for wheels?
If the crud isn't coming off by finger-rubbing that means it's prolly on there pretty good. The Mother's polish is very aggressive and not made for painted/clearcoated wheels like yours. Its more for chrome or polished wheels that have no clearcoating on them.
Do you have some car polish/wax that you use on the paint? Many of those products have cleaners in them to remove swirls and oxidation. That can work so give it a try on a spot and see what happens. Hopefully that's all the polishing you'll need.
As for maintenance and protection, whatever you use on the paint is OK for wheels.
adc100 - after reading all 1900 posts here and visiting several of the recommended websites for car care I decided on the Erazer Clay and Lubricant, 3M Imperial Hand Glaze, and the Collonite Marquis D'Elegance. I was going to get the Collonite Insulator Wax but thought I would try this first. My real debate was between the Collonite wax and Grand Blitz wax. Being one of the resident experts I figured you probably had some of this on a shelf somewhere already. LOL!
I hope to get this project done before the end of next weekend. I truly appreciate the core group of "experts" that are here to help out all of the beginners like myself that just want to learn how to take care of our cars.
The one product that I have already bought and used is the 303 Protectant. I love this stuff. It is wonderful on exterior plastic cladding, tires, wheels (repels brake dust), interior (probably better here than anything I have ever seen), and I have also used it on many things around the house like my spa cover, leather shoes, golf shoes (just wipe 'em clean), leather golf bag (repels dust just like in the car interior).
A less drastic method is to try Eagle One wet Tire Gel, or Meguiar's Tire Gel (I prefer the satin finish) I wouldn't use Meguiar's trim gel. It is too light to retain a good finish for any neglected bummpers or trim. Repeat at least monthly more if it rains. (if only we could have that curse) Only takes about 10 minutes.
TnTitan. I really like Eraser lubricant for a clay bar. It also works well as a detailer. My personal opinion is that it's the quickest to apply, and has an excellent shine. I mentioned Meguiar's Quick Detailer because I know it contains a little bit of wax for some protection. I don't think Eraser has any. But if it's only one day I don't think you have much to worry about. Good Luck. Looks like you've made a good choice of products.
A Microfiber towel is so soft that it won't scratch the tint. So that combo I'm sure would work well. Plexus is an aerosol so I can't imagine easier usage.
I'm sure others will chime in with their comments. Hope this helps.
