2025 Chevrolet Silverado Lease Deals, Incentives, Rebates, and Prices
1234689
  • kyfdxkyfdx Moderator Posts: 276,004
    SuaveRC said:
    Hello. May I get the MF, residual value and incentives for a 2025 Silverado crewcab 1500 RST 4 wheel drive please?
    36/15,000 miles
    39/15,000 miles
    What is your location?
  • SuaveRCSuaveRC Member Posts: 24
    78748
    78748
    .00173 MF
    59%/57% residual
    78748> @kyfdx said:
    .00173 MF
    59%/57% residual
    How do I tell a dealership that she is lying as she tells me the MF for that truck is .00273 with RV 57%? Other than sourcing this website, I don't have anything to prove her wrong. Hope this makes sense % you understand.
    78748> @kyfdx said:
    .00173 MF
    59%/57% residual
    Residuals can't be altered
    I don't think it's a coincidence that the MF quoted is exactly .00100 higher. That's a giant markup. (equivalent to 2.4% APR higher)
    Just tell them if you don't get the base rate, you'll shop elsewhere.
    Appreciate it
  • RobJuRobJu Member Posts: 2
    edited May 2025
    Good morning, may I please get the MF, RV and incentives for 2025 Silverado 1500 ZR2?
    48/10 (if that's a thing)
    Zip code: 20110
  • MichaellMichaell Moderator Posts: 270,923
    Zip code: 20110
    .00212 MF and 57% RV
  • maxcortsxmaxcortsx Member Posts: 146
    EV LT in 94555 for 10k/24 please
    .00292 and 85%
    Not sure how much makes a difference so.....may I please get the MF, RV and incentives for 2025 Silverado 1500 ZR2?
    48/10
    Zip code: 20901
    48/10
    Zip code: 20901
    zip won't matter regarding MF/residual
  • srr22980srr22980 Member Posts: 48
    Hello, can you please provide the lease incentives, MF & RV for 2025 Silverado 2500 ZR2 crew cab gas and 2025 Silverado 2500 High Country crew cab gas 36/10, 39/10, 42/10 & 48/10. Zip 52205.
    no info on 42 month term
    ZR2
    .00363 MF and 70% residual
    .00363 MF and 67%
    .00380 MF and 58%
    HC
    .00344 MF and 67%
    .00344 MF and 64%
    .00360 MF and 57%
    Hello, can you please provide the lease incentives, MF & RV for 2025 Silverado 2500 ZR2 crew cab diesel 36/10, 39/10 & 48/10. Zip 52205
    Diesel is same as gas
  • mikeysosa1mikeysosa1 Member Posts: 63
    Hi. Could you please provide me with the MF, residual value and incentives for a 2025 Silverado crewcab 1500 high country 4 wheel drive please?
    36/12,000 miles
    39/12,000 miles
    36/12,000 miles
    39/12,000 miles
    33186
    36/12,000 miles
    39/12,000 miles
    33186
    .00129 MF
    61%
    58%
    .00129 MF
    61%
    58%
    And for 24/10 or 24/12?
    .00129 MF
    61%
    58%
    24/12
    .00123 MF and 68% RV
    Thank you so much!
  • Slickz94Slickz94 Member Posts: 15
    Hi could you please help me get the RV and MF for this heavy duty truck down below? Trying to see what it is compared to a GMC Sierra 2500 AT4X. Thank you!
    2024 & 2025 Silverado 2500HD ZR2 Diesel
    Zip: 43016
    Zip: 43016
    2025
    .00363 MF and 69% residual
    .00380 MF and 57% residual
    Ask 2024 model questions in the appropriate discussion
    My apologies to bother you again but does the residual value change based on the engine that’s chosen in the high country, like if it’s the 5.3, 6.2, or diesel?
    Makes no difference with this model
  • tphiliptphilip Member Posts: 108
    edited May 2025
    May i please have the MF and residual values for a 2025 Silverado EV LT e4WD
    ZIP 60090
    Any conquest and/or loyalty incentives?
    Any additional benefits for loaners or demos?
    Thank You!
    ZIP 60090
    Thank You!
    Please re-post in our dedicated Silverado EV discussion
  • svtampa813svtampa813 Member Posts: 20
    May I please have the MF and RV for a 2025 Silverado RST and High Country / 5.3L and any Lease Incentives
    ZIP 33559
    ZIP 33559
    2WD or 4WD?
    Double or Crew Cab?
    Crew Cab 2WD RST and 4WD High Country
    ZIP 33559
    2WD or 4WD?
    Double or Crew Cab?
    ZIP 33559
    2WD or 4WD?
    Double or Crew Cab?
    RST: .00173 MF and 61% residual
    HC: .00129 MF and 61% residual
  • Ccron889Ccron889 Member Posts: 40
    edited June 2025
    Can I please get MF, RV, and any rebates for:
    2025 1500 CrewCab Custom & LT Trail Boss
    24/10k
    36/10k
    Zip: 92562
    24/10k
    36/10k
    Zip: 92562
    Custom
    .00295 MF and 73% RV
    .00257 MF and 68% RV
    TB
    .00241 MF and 71% RV
    .00208 MF and 64% RV
    $1000 incentive with the 2.7L turbomax engine only
    Have these changed for June by chance? Thank you
    June programs for GM will be released on Tuesday.l
    Ask again, then.
    Ask again, then.
    Checking back on any new incentives for the previously quoted RST ad HC please? Thanks!
    Ask again, then.
    Only change is the MFs
    .00174 MF
    .00130 MF
  • 67camaross67camaross Member Posts: 2
    2025 1500 CrewCab LT 4x4 3.0
    36/15K
    39/15K
    Zip: 05454
    36/15K
    39/15K
    Zip: 05454
    .00174 MF
    59%
    57% residual
    .00174 MF
    59%
    57% residual
    Thank you!!
    Hello, can you please provide the lease incentives, MF & RV for 2025 Silverado 2500 ZR2 crew cab 36/10, 39/10 & 48/10. Zip 52205
    .00364 MF and 70% residual
    .00364 MF and 67%
    .00381 MF and 58%
    24/10k
    36/10k
    Zip: 92562
    Custom
    TB
    Any new incentives on this quote?
    24/10k
    36/10k
    Zip: 92562
    Custom
    TB
    Custom
    .00296 and 73%
    .00258 and 66%
    TB
    .00242 and 71%
    .00209 and 64%
    Same incentives
  • Tim5150Tim5150 Member Posts: 101
    Can I please get MF/RV for Silverado 1500 Crew Cab, 4WD, 3/36 and 2/24, in zip code 32547 in these trims:
    LT Trail Boss
    LTZ
    RST
    High Country
    LT Trail Boss
    LTZ
    RST
    High Country
    Too many combinations.
    Please cut the request in half.
    Ok, let's just do 3/36 in:
    LT Trail Boss
    RST
    LT Trail Boss
    LTZ
    RST
    High Country
    LT Trail Boss
    RST
    TB - .00209 MF and 63% RV
    RST - .00174 MF and 61% RV
  • quattromikequattromike Member Posts: 160
    edited June 2025
    Can I have the MF, residual value and any incentives for the Silverado 1500 Custom Extended Cab with a Shortbed for 36/10k in zip 60433?
