2024 Jeep Grand Cherokee Lease Deals, Incentives, Rebates, and Prices
13031323436
  • MichaellMichaell Moderator Posts: 265,315
    edited May 7
    Are there numbers still for 2024 Grand Cherokee Laredo? Gas 4x4, 19090
    24/10, 36/10
    There are numbers, but they aren't customer friendly.
    What would 3/36 or 2/24be for 4xe trailhawk and summit residual and money factor? Zip 53005
    SUM
    .00015 MF and 53% RV
    .00076 MF and 45% RV
    TRL
    .00001 MF and 52% RV
    .00033 MF and 43% RV
    Total Cash of $15600 includes:
    $7500 2024 Stellantis Financial Services EV Incentive
    $8100 2024 National Lease Cash exp. 06/02/2025
  • kyfdxkyfdx Moderator Posts: 268,104
    Hi, could I please have the MF/RV/Incentives for a 2024 Jeep Grand Cherokee 4xe base?
    24/12k
    zip code 92707
    Thank You!
    .00003 MF and 52% residual
  • mharnes1mharnes1 Member Posts: 13
    24/12k
    zip code 92707
    Thank You!
    same for zip 20109?
    what is the typical residual reduction for loaner mileage? one model has 6600mi, the other 5800mi.
  • eternalkingdometernalkingdom Member Posts: 7
    Hello, I am looking for the incentives, MF and RV for the 2024 GC limited (4x4), 4XE (4x4), & laredo(4x4) for zip code 48188. 24/10k and 36/10k if possible, thank you!! :)
    24/12k
    zip code 92707
    Thank You!
    same for zip 20109?
    Yes, same.
    We don't have the info on adjustments for loaners
    4XE
    .00003 MF and 53% residual
    .00088 MF and 45% residual
    We don't show any lease support for the standard 4X4 models, any longer
  • JNickelz83JNickelz83 Member Posts: 16
    May I please have the MF, RV & Incentives for 21801, Overland 4xe, 36/15K?
    .00016 MF and 42% residual
    edited May 12
    Hello, I am looking for the incentives, MF and RV for the 2024 GC Trailhawk 4XE (4x4), Summit 4XE (4x4)& Overland 4XE (4X4). zip code 48188. 24/10k, thank you!!
    TRL - .00001 MF and 53% RV
    SUM - .00015 MF and 54% RV
    OVR - .00015 MF and 55% RV
  • ron_kamiron_kami Member Posts: 3
    edited May 12
    Hello, looking for MF, RV and incentives on 2024 summit/summit reserve 4xe, 24/7.5 and 36/7.5 zip 11235. Thank you!
    .00076 MF and 47% RV
    Either trim
  • maxcortsxmaxcortsx Member Posts: 143
    Hi, 10k/24 94555 for just the GC 4XE and TH 4XE
    Base - .00003 and 53%
    TH - .00001 and 53%
  • madmax700madmax700 Member Posts: 72
    Hello.
    Can I kindly get the MF & RV for 2024 Jeep Grand Cherokee 4xE Overland-
    24/10
    Zip 11758
    Any incentives ?
    madmax700 said:
    Hello.
    24/10
    Zip 11758
    Any incentives ?
    .00015 MF and 55% residual
  • goldstar324191goldstar324191 Member Posts: 1
    Hi, Can I get the MF & RV for 2024 Jeep Grand Cherokee 4xe Trailhawk?
    zip 14850
  • Scough17Scough17 Member Posts: 4
    Hi can i please get the MF & RV for 2024 Jeep Grand Cherokee 4xE, 4xe Overland, and 4xe summit
    01915
    zip 14850
    .00033 MF and 41% residual
    01915
    Sorry 10k 24 and 10k/36
    01915
    4XE
    OVL
    .00016 MF and 45% residual
    SUM
    .00015 MF and 54% residual
    .00076 MF and 46% residual
  • 123123RR123123RR Member Posts: 20
    24/10
    24/15
    33496
    24/10
    24/15
    33496
    Which trim?
    2024 Jeep Grand Cherokee 4xE Trail hawk please.
    24/10
    24/15
    33496
    .00001 MF
    53%
    51% residual
  • ZP31ZP31 Member Posts: 6
    Hi can I please get the MF,RV, and incentives on the 2024 jeep grand Cherokee 4xe in 60645
    24/10
    TYIA!
    24/10
    TYIA!
    Which trim?
    edited May 18
    Which trim?
    I believe the base and the overland
    24/10
    TYIA!
    ZP31 said:
    Which trim?
    Base
    .00003 MF and 53% RV
    .00088 MF and 45% RV
    OVR
    .00016 MF and 45% RV
  • Suave0420Suave0420 Member Posts: 37
    Hello, need help getting MF, RV, and Incentives for a Base GC 4xe in zip 66061. Looking at 24 and 36mo terms for both 10k and 12k mi/yr.
    24/10: .00003 MF and 53% residual
    36/10: .00088 MF and 45% residual
    How does the RV/MF change going up to 12k/yr? Appreciate the reply
    -1%
  • sspirogasspiroga Member Posts: 22
    Looking for RV, MF, Incentives, Rebates for 2024 Base 4XE in zip 33647. 24/15 and 36/15.
    .00003 and 51%
    .00088 and 42%
  • thenewrenewthenewrenew Member Posts: 20
    Hello, I am looking for the incentives, MF and RV for the 2024 GC Trailhawk 4XE (4x4), Overland 4XE (4x4) & Anniversary Edition 4XE (4X4). Zip code 11211. 24/10k. Thank you!
    TH - .00001 and 53%
    OVR - .00015 and 55%
    ANN - .00003 and 53%
    TH - .00001 and 53%
    Thank you. Are the MF different for one-pays?
    Do you know if these also qualify for $2k overaged inventory and $500 drive clean rebate (NYS)?
    TH - .00001 and 53%
    With those money factors, a one-pay lease wouldn't make any sense. Not enough savings
    No info on your other two incentives
  • illfillf Member Posts: 47
    edited May 29
    Hello, Can I get the RV, MF, and incentives for the following for this month: 24/12k, 24/15k, and 36/12k lease on a 2024 Grand Cherokee 4xe Overland, Summit, and Trailhawk trims. Zip code is 78653. Current CC lease, if there are incentives. Thanks!
  • WalperWalper Member Posts: 67
    edited May 29
    Hi, may I please get the MF,RV, and incentives on the 2024 jeep grand Cherokee 4xe base in 33437. Thank you!
    24/10
    24/12
    We only have the Stellantis (SFS) numbers, so not sure that your CCAP lease will help you; check with your dealer.
    24/12
    OVR
    .00015 and 54%
    .00016 and 44%
    SUM
    .00015 and 53%
    .00076 and 45%
    TH
    .00015 and 53%
    .00076 and 45%
    24/10
    24/12
    24/12
    .00003 and 52%
  • whiteHackwhiteHack Member Posts: 46
    Hi, may I please get the MF,RV, and incentives on the 2024 jeep grand Cherokee 4xe base, overland, TRAILHAWK in 27562. Thank you!
    24/12
    24/12
    Base - .00003 and 52%
    OVR - .00015 and 54%
    TH - .00001 and 52%
    Hi there! Are new numbers available for June yet?
    24/12, 33437
    GC 4xe Base
    4xe Trail Hawk
    24/12, 33437
    GC 4xe Base
    4xe Trail Hawk
    .00003 and 52%
    .00001 and 52%
    $8100 2024 National Lease Cash exp. 06/30/2025
    .00003 and 52%
    .00001 and 52%
    Thank you! Do you know if the $2000 aged inventory incentive has expired or gone away?
