They work great in the right conditions just as canc says. Also remember, however, that as they "fill up" they become less effective, so they do have a "life".
I wax my new cars about a week after being delivered. It's not about the paint curing but I want to play around with the car rather than cleaning it. However, by one week, you've ran out of excuses to randomly go to the car, than washing/waxing is a great excuse.
I am sick of struggling to get them streak free! I should sue Windex for their false claims (kidding)! Seriously, is there a procedure, a method, a product....ANYTHING to make this simple.
I guess I am talking about 2 things:
1)Cleaning the grime off the outside (includes dirt, wax overspray, oil overspray (the dealer lubes all weatherstripping to keep the rattles and pops down on my 02 Camry--I AM SERIOUS), sap, rain marks etc.
2) The inside. You would think this would be easier but I get a film on my wondows. The dealer said this is normal for a newer car.
So what product do I use or what concoction do I mix up? What kind of towell / cloth should I wipe with? Is it best to wipe in circles, vertically, horizontally etc. Whats the secret! Thanks again!
If your windows seem gritty, try steel wool, 00 very fine, on front and then sides. I use an SOS pad myself. I do it when it's raining since that's easier than wetting the windows myself. Some people use barkeeper's friend (oxalic acid) to remove the road grit that adhere especially to the front window.
2 great products - Eagle1 20/20 or Stoners Invisible Glass. Both work well with paper towels or newspaper. After you clean the outsides use either Rain X or whatever wax you are currently using to keep them nice and clear in the rain. Side mirrors done this way also helps on those cruddy days. You can also use Bartender's Friend abrasive cleaner for a deep window cleaning on the outside, but spot check it first - I've never had trouble, but a friend with a factory Subaru windshield said it scratched.
I also really like the Eagle One 20/20....great product and value. I usually use a damp MF towel on the first pass and then follow up with a clean MF towel and the EO 20/20. All cars, especially new ones, emit some sort of gas from the vinyl that forms on the interior windshield. It is not as bad as the car ages. I would never use any steel wool or similar abrasive product on my glass for fear of scratching the glass.
All cars have windows that fog up. The vinyl/plastic trim in cars give off some sort of gas that causes the thin whittish fog on windows. Typically the fogging gets progressively less as the car ages. Also, if you have leather trim, you will get even more of that foggy whitish film on the windows.
For the inside of my windows, I have tried a variety of liquids in spray bottles, including stuff especially for cars, like Eagle and Turtlewax. Newspaper definitely works best for spreading it around and wiping it off, but every single pump bottle liquid, from several varieties of Windex to car specialty stuff to Wal-Mart's housebrands, left some streaks.
I then tried Stoner's Invisible Glass in an aerosol can and it worked much better.
Finally I purchase some cheap Gunk window cleaner in an aerosol can, clearly a rip-off in terms of packaging of the Stoner product which has been around longer, and it worked best of all!
I have seen both the Stoners and the Gunk at Wal-Mart's, it is a lot cheaper there than Kragen's etc.
Both aerosol products are "nasty" if you don't keep the car well ventilated. Both really require using newspaper for the best job. Anything else streaks or leaves behind lint.
I use Stoner's Invisible Glass with a paper shop towel, not a paper towel. Wholesale club's have them, large box lasts years. If your windows haven't been cleaned in a while you will have to clean them twice. I use a Clay Bar for the outside of my windows, leaves the glass smooth then apply Invisible Glass.
I also discovered Stoner's Speed Bead Wax a few years back and won't use anything else. Great stuff!
Inside: Stoners Invisible glass with this http://www.properautocare.com/vipglasclean.html microfiber cloth. I will NEVER go back to paper towels. I used the newspaper a couple times but the ink left streaks as well as my hands black.
Outside: Depends how dirty. A couple times a year, one or combo of the following Glass Scrub http://www.properautocare.com/glassscrub.html (also available at some auto stores), Clay, Stoners with 0000 steel wool (do NOT use anything more abrasive or the "synthetic" type substitutes). Normal cleaning just wash when I wash the car possibly followed by Stoners using the MF towel.
Aquapel on front window, Rain Clear or Rain-X on sides, back and mirrors.
How often do you wash a microfiber towel after quick detailing (Sonus Spritz)? Do you have to do it every time? It seems like a lot to machine wash and dry one towel every couple of days?! (since you're supposed to wash it separately from "linty" things?) Or, do I just need to rinse the towel after use?
I wash mine after each use....I don't want to risk dragging around any debris on the paint the next time I use it. Of course, I have over 20 MF towels so I end up washing mine every other week.
Try Bon-Ami cleanser (next to Ajax and Comet at your grocer's) for the outside of your windows. It is designed for plastic and fiberglass tubs and sinks, so it won't scratch glass. It's a little messy, and I wouldn't want to get it on my paint, but it gets your glass about as clean as it's going to get, including those pesky hard-water spots!
I've noticed over and over the recommendation to use dish washing soap to wash cars and to avoid car washes like the plague - even if they're the touchless type. What is a person suppose to do to wash the undercarriage during harsh Midwestern winters? I've been told by Ziebart that one should not use any dish soap on a car but only special car-wash solutions. They said that the dish soap can damage the clear finish of today's cars. Any thoughts on this?
Dishwashing soap REMOVES waxes. Some are milder than others. I don't know that they will damage clearcoats.
I accidentally used Dawn that I had in a bucket for wheels and added some car soap to it. I had little yellow flakes of carnauba wax that I had labored to paste on a couple of weeks earlier floating in the water. Then I realized what I'd done. Dawn is a terrific grease cutter. They used it when a truck overturned on an interstate ramp in Cincinnati a few years back. The truck was carrying rendered fat meant for a hand cream/lotion type plant in the area. They used Dawn to emulsify that lard. So it's potent stuff.
I would avoid dishwashing detergent on windows because if a drop dribbles down onto the paint, your wax is gone in that path the dribble takes. If you only use a dampened cloth with dishwashing detergent, you might do okay.
When wife's away... Wash only car cloths wash with a little Dawn in first wash along with powdered soap. Rinse. Wash with powdered soap through entire cycle. Dry.
The Dawn wash is not for routine washing, it is for washing prior to waxing because it takes the remnants of the old wax off. This in turn saves efforts with cleaners and surface preps before waxing.
I have no use for it on my car....anywhere. It not only ruins a wax job but it can dry out rubber seals. When I prep my car for waxing or any other last step protectant I will usually clay the vehicle (at least once and maybe twice a year), polish the paint if it needs a deeper shine and/or chemically clean my paint with Klasse All-In-One before I wax or apply a sealant. Whether I polish or just clean the paint with Klasse AIO I don't have to worry about any previous wax or sealant because either process removes any old products and properly preps the paint without using dishwashing soap. I am not certain that dishwashing soap will remove sealants or even some waxes although I am sure it would greatly diminish any shine or protective qualities.
Here's something I ran across when looking for car washing techniques. The University of Texas did a study that says that hand-washing a car left far more scratches on a cars surface than did automatic touch-less car washes. Has anyone heard of such a study? It sounds fishy to me as it was posted at a Texas car wash's web-site. But... if true ...
A follow-up to the study: it was indeed done by the University of Texas and is a publication TR-3-81 ($15) and is called Handwashing of Auto Paint Surfaces by John H. Matthys, Ph.D., P.E.
it makes sense that there would be less scratching. I think the problem with touchless car washes is that in order to clean the car without brushes, they need to use harsh chemicals that somehow hurt the finish.
The link didn't work for me, but was able to find the site using the URL. The site appears to be in California, NOT Texas. Even if it were though, why would it sound fishy being on a Texas site?? We wash cars in Texas too. Actually the report, to me, makes some valid points, but just my 2 cents worth.
Not to mention it was sponsored by the commerical car wash industry who is pressuring cities and municipalities to ban driveway car washing (among other things).
I supposed someone washing at home could scratch their paint worse than a commercial car wash can, but it would take some effort to do so. Like using sandpaper instead of wash mitt, or using real dirty water in the wash bucket. I'd love to hear some real world examples where someone did more damage by hand washing than using a commerical car wash.
Here's an anecdote: At work I oversee the maintenance of our service trucks and vans. This past Monday I had one of our trucks in for repairs (3/4 ton Ford with a service body). I always get the trucks washed prior to putting them back into service. So I took the truck to the local car wash/oil change place, got the oil changed and ran it thru their full service car wash. The truck had a bunch of concrete mix and dirt in the back that I forgot to sweep out before washing. The spinning brushes and water made a mess of the concrete stuff in the back when it ran thru the tunnel. I'll tell ya this, I'd have HATED to own the car behind my truck after it went thru the car wash. Those brushes were coated in dirt and concrete mix! Quikrete + dirt + water + car wash equipt = swirls and scratches.
That's the risk of using commercial car washes - you don't know the condition of the washing equipt before your car runs thru the tunnel. At home you can use a clean wash mitt, a clean wash bucket, and wash the car gently. You control the quality of the tools you're using. At the local automatic car wash, you're at the mercy of the equipt. If their stuff is poorly maintained or the brushes are coated in Quikrete, you're screwed!
bret - I'm shocked. I figured you of all people would figure out a way to justify spending the work day in the parking lot doing a proper wash and detail job of the company truck!!
Ever detail an F350 chassis with a dump body? Don't ever offer to do it for you boss - even for a few extra bucks.
hahaha, yeah, that's not far from the truth. I have taken home service trucks to clean them up if they get left at the office over the weekend. I detailed this particular truck a couple months ago. Nice thing about vinyl seats and rubber flooring is being able to literally hose out the interior.
We have an F350 welding truck that gets washed 2-3 times a year. Part of me wants to detail this truck but the other part is saying it'll take me 3 days to do a good job. So far I haven't touched it but it's slowly reeling me in, like its got a tractor beam or something.
Back in my young and foolish days, I offered to wash and wax the 2 company F350's noted above at a summer job I had with a landscaper. I used Armour All on the vinyl seats and steering wheels - let's just say I didn't make any friends on the crews until the stuff wore off!!
"Not to mention it was sponsored by the commercial car wash industry who is pressuring cities and municipalities to ban driveway car washing (among other things)."
A few years ago I toured the printing plant where the BMW Car Club's magazine Roundel is published. While browsing through some of the other magazines published at that facility I found a magazine aimed at commercial car wash operators. It contained a story which explained how to quietly utilize local and national environmental regs to shut down CHARITABLE car washes. Unbelievable.
I don't know that there's anything really despicable (to borrow from Daffy Duck) about that. After all, these car washes are trying to make a living and probably have a lot of regulations to deal with that drive up costs (such as minimum wage). In some areas you can get a charity every week offering to wash a car for pennies.
I'm not saying they should be banned or anything, but it's not so clean and dry (pun intended)
Folks, I need help. I've got a dark green car with some mild swirling, and after reading some posts here and in the Zaino forum, I've decided to step up and do my car right. I'm happy with my regular car wash, but understand that I'll need...
- Dawn dishwashing liquid to remove the current coat of wax - a clay bar to really get the car decontaminated - some sort of a polish for swirl marks (not a compound - the swirls aren't that bad) - a regular polish to use after the 1st polish dries - something to "cure" the polishes
I was gonna go with Zaino (the stuff does sound really great), but am just turned off at having to buy it via mail order. What products/brands would you recommend that are sold in regular stores (like Pep Boys or Discount Autoparts)? Also, I've heard that synthetic clay is better than natural - does the brand really matter for this? Lastly, is there a polish out there that doesn't need to be cured? :confuse:
Every time I wash my black car, I seem to get some white residue (presumably soap suds) left over after I dry it off. It's only noticeable from certain angles but annoying none the less. I rinse thoroughly so it must be coming from my synthetic chamois. Any suggestions?
"What products/brands would you recommend that are sold in regular stores (like Pep Boys or Discount Autoparts)? Also, I've heard that synthetic clay is better than natural - does the brand really matter for this?"
If you don't want to use Zaino, I would shoot for either Meguiar's or Mother's brand waxes/polishes. Both also sell claybar kits. I don't know if these 2 brand's clay bars are synthetic or natural, but I've used both brands and they both work great! I believe both Mother's and Meguiar's sell polish specifically for swirl marks. Read the label thouroughly. I stopped using Carnuba wax a while ago because it is a pain in the a** to remove when it dries and the protection doesn't last too long. I've tried Meguiar's NXT wax recently, and personally I'm happier with this. It goes on easier, comes off easier, and seems to last longer than Carnuba wax.
"Lastly, is there a polish out there that doesn't need to be cured? "
You might want to try a product from Stoner's called Speed Bead. If you go to www.moreshine.com you can click and find out what retailers sell Speed Bead and where. Stoner's claims that Speed Bead will remove minor scratches and water spots. I have been using Speed Bead for 3 years on both of my vehicles and the paint job is still like new on both cars.
My son used Speed Bead on his 1989 Toyota with black paint and the car really did shine, almost like new. I can't say if the Toyota had any swirl marks to begin with, but I didn't notice any after he waxed the car.
You said that you don't want to order over the phone or online and I don't like to do that myself, but, I ordered a case of Speed Bead (some for family and friends) and it was at my door the next day. Depending on where you live you might be able to buy Speed Bead locally, that's what I did when I went to visit relatives out of state and found a store that sold Speed Bead.
I paid about $6.00 a can for Speed Bead froms Frank's Autosuper Store in PA when I first wanted to try it. I will never use anything else. Speed Bead is fast to put on, very easy to remove and it leaves no powdery residue. Great Stuff!
Just used it on my van on Saturday and the van shines like it's wet.
Thanks to all who replied. I really appreciate it!!!
When I asked about a polish that didn't need "curing," here's an example of what I meant:
according to Zaino's, before using their polishes, you either need to coat your car with a product they call "polish lock" or add a few drops of a product called ZFX to the polish before using. I believe the site says this is necessary to "cure" the polish and make it bond to the car.
Since you didn't know the term, I guess that's am unusual requirement :confuse: Maybe it's something used by higher-end products that last longer? :confuse:
I don't mean to push my luck here, but I'm getting such great feedback that I can't help myself!!!
It is a Zaino thing. If you really want to properly detail your car go to autopia.org and prepare to read a lot of information. Most products from regular stores can hide the swirls with fillers but they will come back. Meguiars and 3M make swirl removers that you can buy locally but there are others that are easier to use that would have to be bought online.
I don't know if the "high" end products last longer or not. Read some of the Zaino posts and you will see that some/most of these people talk about the long lasting shine, but they seem to wax or apply something every month.
I believe that most people don't want to spend all day waxing a vechicle and will shy away from doing it again if the product is difficult or if it takes too long.
As you can tell, everybody has their favorite brand of wax. I use Speed Bead, they don't call it Speed Bead for nothing. I would rather be out driving my convertible than spending all day waxing my two vehicles.
Have this wax and it's pretty awesome...quick and easy! Though not as good as the P22 wax I got at the Harley Store, which is incredible, I do like the Speed Bead. And since I got hurt, I've not been able to do almost anything. We just got a Mazda3 S this weekend and can't wait to wax that baby. We got the Sunlight Silver due to a shortage of the Titanium color and then it took 4 days to get the car, as it's in much demand down here in South Florida. Luckily the ship came in last thursday and my dealership was allocated 1 Silver car with just what we wanted in it. They held it since we signed the deal already and now were "zoom zooming" and it's outstanding! Plan to use the Speed Bead on it when I feel better.
On the contrary, Zaino goes on/off easier than anything I've used, and lasts longer than anything I've ever used. And I only apply twice per year, once in early Spring, then again in early fall. There are alot of anti-Zaino folks out there who will have you believe this product is very time-consuming and requires frequent applications. It's just not true.
I am not "anti" anything. Read post # 5934 in the Zaino threats, this is what I was talking about. Multiple steps of whatever to be applied whenever, not something that most people will want to do.
Like I said in my post, everybody has their favorite wax, enjoy your Zaino. Just read what some people go through using Zaino and it does seem to be very time-comsuming.
I've gone 6 months between waxing with Speed Bead also, easy on, easy off and less than $6.00 a can delivered to my door.
That particular post does list many steps. But the prep ones are just like the prep ones for any good detailing job. Plus, the prep steps are used only with the first application - just like for any other product.
As for the rest, you can take any product or process to the nth degree. I remember using a Meguir's three step process to polish, glaze, and wax.
You are correct, you can take anything too far. Most people just want to wash and wax their vehicle, not detail it. I believe the reason that this board says "no Z" posts is that most people here won't do what those people are doing to their vehicles.
If you want to spend all day waxing your vehicle don't use Speed Bead. Speed Bead is for those of us that want a "great" long-lasting shine in about 1/2 hour.
No matter what product line you use, proper paint prep is the key to a great looking, long lasting shine. If you want your car to look as good as it can, you've got to do the prep (claying, polishing, paint defect removal, waxing, sealing, etc). There are no shortcuts or magical products.
If you don't demand the best possible shine and you want to spend as little time as possible cleaning your car, there are lots of quick and easy products out there - just wipe or spray on, wipe off, and go. It's all a matter of expectation meeting results.
1. wash it with Dawn detergent to strip the old wax off.
2. Using a *Clay Bar* kit, clean the paint job with the clay bar.
3. Wash the car again.
4. Polish your Camry with a polish such as Meguiar's Deep Gloss Polish or something similar.
5. Then wax your Camry using a good wax. I just recently tried Meguiar's NXT wax and am quite happy with the results.
Simple Dawn dishwashing soap and hot water. Cuts grease and leaves no steaks.
When wife's away...
Rinse.
Dry.
car wash study
Can you recall some of the details about how to do away with the competition car washes?
Thanks for your input.
It could also be acid rain damage that you are seeing on your paint job.
I don't know what you mean by this. Anyone?
Good Luck.
Good Luck!
The Sandman :sick:
If it works for you, great.
