2025 Nissan Rogue Lease Deals, Incentives, Rebates, and Prices
124
  • Geo_RibGeo_Rib Member Posts: 6
    edited June 18
    Hi. Please provide RV, MF, and Incentives for 2025 Nissan Rogue SL and Platinum for 36 months. 10k and 12k miles. Zip code 10701. Thank you.
  • kyfdxkyfdx Moderator Posts: 269,197
    FWD or AWD?
    AWD
  • MichaellMichaell Moderator Posts: 266,233
    Geo_Rib said:
    AWD
    .00210 MF
    $2300 incentive
    63% Plat
    62% SL
    Thanks for the quick responds.
    How about RV, MF, and incentive for 2025 Nissan Rogue SV AWD for 36 months 10k and 12k miles. Zip code 10701. Thank you.
    .00210 MF
    63%/62% residual for 36/39 mo, 12K/yr
    +2% for 10K/yr
    $1300 incentive
  • JMontyJMonty Member Posts: 29
    Hi looking for residual, MF, and incentives for 2025 Nissan Rogue SV AW:
    36 months / 12K miles
    Zip code: 01089
    Thanks!!
    Zip code: 01089
    Thanks!!
    .00210 MF
    $975 incentive
    63%/62% residual for 36/39 months
  • samwelltarlysamwelltarly Member Posts: 1
    Hi - may I please have the MF, RV, and any incentives for a 2025 Nissan Rogue SV AWD (SV Premium Package) 39/10? Zip 01760. I appreciate everything you do. Thanks!
    .00210 MF and 64% residual
    $975 incentive
  • gdama001gdama001 Member Posts: 2
    Hi - may I please have the MF, RV, and any incentives for a:
    1) 2025 Nissan Rogue Rock Creek AWD 36/10? Zip 20171.
    2) 2025 Nissan Rogue SV AWD 36/10? Zip 20171
    .00152 MF and 62% RV
    Either trim
  • RockyRhodeRockyRhode Member Posts: 3
    Good Evening- Is it possible to get the MF and Res% for a 2025 Rogue w/Platinum Trim, AWD, and 3yr/10K in zip 02458?
    Thank you very much.
    .00152 MF and 62% residual
    $1000 incentive
    $1000 incentive
    Are these figures the same for 3yr/15K?
    Thanks much for the assist.
    $1000 incentive
    Of course not.. 59% residual for 15K/yr
  • mjb327mjb327 Member Posts: 9
    Can I get the MF and RV on a Nissan Rogue SV and S for 60014 and also 60173. Looking for a 36/10 lease. Thank you.
    FWD or AWD?
    FWD or AWD?
    both please.
    mjb327 said:
    FWD or AWD?
    both please.
    SV
    .00152 MF
    $675 incentive
    62%/61% residual for AWD/FWD
    Not seeing a lease program for the S trim
    mjb327 said:
    FWD or AWD?
    both please.
    SV
    .00152 MF
    $675 incentive
    thank you!
  • VitorLaraVitorLara Member Posts: 15
    Looking for MF/Incentive/Residual info for:
    SV, FWD
    -36/12k
    -36/15k
    Zip: 33141
    SV, FWD
    -36/12k
    -36/15k
    Zip: 33141
    .00152 MF
    59%
    58% residual
    $1325 incentive
  • jetfanjetfan Member Posts: 68
    Looking for MF/Incentive/Residual for a 2025 Nissan Rogue.
    Not sure which one.
    SV AWD?
    zip code 07738.
    Not sure which one.
    SV AWD?
    zip code 07738.
    .00152 MF and 59% residual
    $1325 incentive
    thanks.
    I should have been more specific.
    36 months 10K a year.
    assuming 62% RV instead of 59%
    jetfan said:
    thanks.
    Correct
  • OzertimeOzertime Member Posts: 49
    Hello. Can you please provide RV, MF, and Incentives for 2025 Nissan Rogue SL AWD for 39 months and 36 months. 10k miles/yr. Zip code 92865. Thank you.
    .00152 MF
    61% and 58% for 36/39 months
    $1325 incentive
    Thank you. Do the numbers change if the zip code is 07462?
    Nope
  • Yaakov24Yaakov24 Member Posts: 39
    Hi - can I please have the MF, RV, and any incentives for a 2025 Nissan Rogue SV with Premium Package 36/10k? Zip code is 11598.
    FWD or AWD?
    AWD
    Yaakov24 said:
    AWD
    $1325 incentive
  • ebdebdebdebd Member Posts: 39
    Hello
    My I have the MF, RV, and incentives for the 2025 Nissan Rouge SV and SL AWD 24/10 and 36/10? My zip code is 19805. Thanks!
    edited July 28
    Does the 2025 Nissan Rogue SV qualify for conquest and/or loyalty in 11598?
    $1000 conquest
    ebdebd said:
    Hello
    SL - .00152 MF and 64%/61% RV
    SV - .00152 MF and 64%/62% RV
    $1000 incentive
  • PAKYPAKY Member Posts: 7
    Can I please get the MF and RV for a 2025 Rogue platinum for a 10/36 lease in area code 08005.
    FWD or AWD?
    AWD
    PAKY said:
    AWD
    $1000 lease cash
  • jmd0423jmd0423 Member Posts: 7
    Please provide incentives, MF, residual for 2025 Rogue SL FWD 36 month 12k lease for zip 92220
    .00152 MF and 58% residual
    $2650 incentives
    Can you give a breakdown of the $2650 in incentives? Dealer is stating there is only $1325. Are the above figures valid for Rogue SL AWD as well?
