Visitor Agreement.
I’ve been pretty critical of the newer car air conditioners (my Volvos just ok as were the Enclaves) but both my Rams remind me of the freezer my 79 Continental was. I’d wager vent temps were 30 degrees or so with 100 degree ambient.
I just ran out in my wife’s Mercedes and it was not nearly as cold but did the job - 99 out currently
You could hang meat in my 2006 BMW..
I did wipe off the sensors and checked to see that they were lined up.
Once in a while they get jostled, ao maybe that's what fixed it.
Thanks for the tip.
I usually back in to the driveway, which leaves me pointing west. Going to have to start pulling in. Windows have fairly heavy tint (legal)
https://maritime-executive.com/article/burned-out-car-carrier-sinks-in-pacific-three-weeks-after-fire-began
Oh, I misunderstood. I thought you had said they were only a year and a half old. My mistake!
that's a heck of a thing.... electric battery fires on a ship! Seems like they need to devise some sort of vacuum suppression system to keep such fires in check, as normal methods of control just don't have enough oomph to deal with the intensity of lithium battery fires.
I put in a new condenser fan motor and contactor today. Really a struggle to get the old fan blade off the old motor. Down to 73 degrees this am
I’m not sure there is any liquid wrench trick - it was a desperation move to try to get it going again. The super lube worked better.
One system is a year and a half old and working well. The other three (ouch - it seemed like a good idea at the time) are 23 yrs old. One new system is going in tomorrow.
Or, do like some of the car YouTubers do, and mount them on a wall a couple inches apart, facing each other, not that I would condone such a thing.
I never knew babies planned on moving.
————————————————-I’m sure you saved yourself at least a couple hundred bucks by doing the work yourself. Too bad that savings is going to be plowed into new units. :'(
Where did you see that? Last retirement buyout I saw was back in March.
It was some random YT video.
I saw that too. maybe the same one!
Had my appointment for the A/C annual checkup.
Guy said everything was ok.
He recommnded some upsells. An ionizer and a soft start device.
I had him install the soft start kit.
Hopefully it gets me a little more time because the startup was pretty abrupt and loud. Seems quieter now.
He showed me screen shots of the startup voltage. 85 volts before and 46 after.
A vacuum removes the oxygen, probably not entirely in practical applications, but enough that you could, theoretically, suppress the intensity/rate of the fire, thereby reducing the heat and the likelihood of a chain reaction. That said, these ships are vast, and they fill the hulls with these cars. I imagine it would take a heck of a modified ship to be able to accommodate that sort of suppression system successfully.
"Regarding the need for oxygen, lithium-ion batteries can generate oxygen during thermal runaway. When the metal oxides in the battery's cathode are heated, they decompose and release oxygen gas. This oxygen can sustain a fire, making it more challenging to extinguish.
However, it is important to note that the initial fire is not dependent on atmospheric oxygen, as the reaction is self-sustaining once thermal runaway begins.
"In summary, lithium-ion batteries can catch fire due to thermal runaway caused by factors such as overcharging, physical damage, or manufacturing defects. While they can generate oxygen during thermal runaway, the initial fire does not require atmospheric oxygen."
All that can be done is to cool the reaction.
https://search.brave.com/search?q=what+causes+lithium+auto+batteries+to+catch+on+fire%3F+Do+they+need+oxygen%3F&summary=1&conversation=234b8a7542b129022c7034
How is my work? I even zip tied the wires. I turned the system to off inside the house and pulled the disconnect. The fan was really a hassle to get off the motor but there were no new 2 blade ones available except a 4 blade with a higher pitch but I was worried it would cause too much drag on the 1/8 hp motor.
I did get the yellow wire off of the top of the capacitor.
I knew that.
If you leqve> @ab348 said:
If you leave the 240 attached it could go south. Not turning the system off inside would just be a little zap. It was shockingly easy to replace the compressor fan motor since I bought the OEM. It had the correct snap in thermal and then only attach the ground wire to the chassis. The contactor was plug and play.
The fan required PB blaster and then a puller using an impact wrench and then tap the motor shaft out.
Nice job.
Consider yourself a #1 hacker. HVAC guys really dislike folks like you.
FWIW, my compressors cooling fan motor shaft is 3/8 of an inch in diameter and it spins a 3 blade fan. The whole assembly is mounted to the underside of the top grill (it’s a 3 ton Lennox unit).
I’ve changed out one like that on a pool heat pump a couple of yrs ago. It was more of a pain
This guy as 5 cars you should not buy....short and sweet and kind of amusing:
https://www.youtube.com/shorts/hmE-l7xKd9g?feature=share
🔥HOT, Felt like 109. Thunder storm currently. Ahh, summer storms.
"Hello, I have been driving my new 2025 4xe Summit Reserve Grand Cherokee for 1500 miles. This car makes me want to drive it into a wall. This is my 3rd jeep but the worst car I have ever owned!!!! From the sound of the electric motor to the lack of comfort or layout of the controls and shifter... It is horrible. I about soiled myself today because I accidently spung the drive mode from drive to reverse while on the high way and thought I was about to drop my transition but lucky if just went into a no power neutral and kept rolling with no gas but still, just another horrible feature with no comfort for hand placement and I JUST HATE THIS CAR!!!!!!!! This will be my last jeep!!!"
Which reminded me of a quote from Douglas Adams:
“A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.”
There is so much wrong with that post that it is impossible to know where to start
Usually starting at the beginning is the best way. But, jumping to the end of that story is the best way since you won’t have to read anymore of that sad story.
apparently they would have finished earlier but when they got the unit on, the valve that it fills refrigerant through (king valve?) was stuck shut and they could not get it open. so they had to take that one off while someone went back to the shop to get a new one, bring it back, and install again. Hopefully after all this it is at least reliable!
Some folks thrive on negativity and complaining.
Went to a popular one in Sharonville, OH where they do the whole shebang...inside, outside, windows, vacuum, tire shine, etc.
Mostly, it's staffed by young people for a summer job and what I'll kindly surmise are people with questionable legal status. No matter, they did a great job.
Was talking to the kind (maybe 17-19 years old) that dried my car. He said he had lost 18 pounds in the last 3 days working. I tipped him well.
Oh year, good to have a clean car again, too.
Thanks for the warning. We now know to be on the lookout for an old geezer with a shiny car trying to learn how to drive again.
Anyway, good to hear you’re almost your old self again.
He mentioned he knows nothing about cars, but he likes a Nissan Rogue mainly because they have .99% financing these days, he is a retired bank exec.
I read that the Rogue offers a 3 cylinder engine that has 201 H.P. with it's turbo engine. The article I read said that gave it power, but it was rough when idling.
I told him, the Rogue is probably fine, but make sure it isn't the 3 cylinder model. He asked, "What is a cylinder", and said he knows nothing about cars. I explained a car should have 4 cylinders minimum and some reasons why.
He was going to look at the Rogue Friday afternoon. I was curious and I checked this review of the Rogue, at the 2 minute mark he explains why the 3 cylinder engine could lead to big problems and a very low value for a used Rogue.
He may have bought the car so I decided not to send him the review. If he hasn't bought it when I see him I'll send him the review;
https://www.google.com/search?q=is+a+2025+nissan+rogue+3+cylinder+a+good+car+to+buy&oq=is+a+2025+nissan+rogue+3+cylinder+a+good+car+to+buy&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIHCAEQIRigAdIBCjIwNjcwajBqMTWoAgiwAgHxBVxnkk7JqKAz&sourceid=chrome&ie=UTF-8#fpstate=ive&vld=cid:5b466cbb,vid:L6G9B2LRmi4,st:0
I had a Rogue as a rental for about 10 days last year, and honestly couldn't tell you the difference between the 3-cyl engine it had and 4-cylinders from other makes. Quiet, decent power. Pretty comfortable inside.
The low financing is attracting a lot of attention.
We've been using Comcast for 25+ years for our home phone, internet and cable TV. Price creep has made our monthly bill pretty expensive, and we're looking at options to replace it.
We've decided we don't use or need a home phone any further, so that's going away. There are some senior deals (55+) out there that look appealing, but I'm curious how everyone else consumes their viewing content.
Our daughter pays for AppleTV, Netflix, Prime, and one or two other streaming services, so I doubt we'd want to lose those.
until last year we just had cable and paid the ever increasing cost. included a home phone in the triple play deal. We actually got some calls at the NJ place. When we moved, we didn't even remember the new phone number, and it only rang for spam. so did not need that.
the new house we intended to get cable, but due to some miscommunication in the box behind the TV mount they put in an ethernet jack instead of coax. so we instead went with Verizon Fios. Since they didn't offer the TV part of that here (no idea why) we just got it for internet. Then we added Hulu live TV+ because we wanted the local stations (and are probably not in good antennae range, plus I did not want to deal with that) plus they include the Mets games.
A small learning curve on using Hulu, but if you have streaming services already on the smart TV it will feel natural. My yardstick is that my wife can handle it, so it has to be simple. I honestly didn't miss cable after the first few days, and we get every station they offered that I ever want to watch.
Some People prefer YouTube TV plus. about the same price.
I think we pay about $165/month all in. Cable was up to about $235. Verizon high speed is about $80 and Hulu $83. If you are fine with the streaming stuff only (so giving up the cable stuff like HGTV) and can run an antennae for local, you can cut that way down. Plenty of stuff to watch for free also, and if you don't mind some research, can find a lot of stuff (maybe not new episodes) on places like the HGTV website. Or youtube. everything seems to end up there.
I would never go back to cable at this point.
I get the usual ESPN, ESPN2, Fox Sports, etc... but I also get MLB Network, NFL Network, NHL Network, Big 10, SEC, ACC Networks, Cleveland baseball and Columbis hockey.
Edit: We don't have a landline anymore.
