1133134136138139201
  • tjc78tjc78 Member Posts: 17,501
    93+ here today, with heat index well above 100. The house A/C is fine, but the GTI is struggling to keep me cool. It's parked outside, which doesn't help.
    I’ve been pretty critical of the newer car air conditioners (my Volvos just ok as were the Enclaves) but both my Rams remind me of the freezer my 79 Continental was. I’d wager vent temps were 30 degrees or so with 100 degree ambient.
    I just ran out in my wife’s Mercedes and it was not nearly as cold but did the job - 99 out currently
    Leaving from my garage would make a big difference.
    You could hang meat in my 2006 BMW..
  • explorerx4explorerx4 Member Posts: 21,117
    @stickguy,
    I did wipe off the sensors and checked to see that they were lined up.
    Once in a while they get jostled, ao maybe that's what fixed it.
    Thanks for the tip.
  • ab348ab348 Member Posts: 20,713
    Remind me of the paint color again?
    Dark Iron Blue.. Basically, the same as charcoal gray. Cloth interior, which helps.
    I usually back in to the driveway, which leaves me pointing west. Going to have to start pulling in. Windows have fairly heavy tint (legal)
    The car carrier Morning Midas, which caught fire on its EV deck about 300 miles off the coast of Alaska three weeks ago finally sunk today. Apparently it was no longer on fire but had been weakened to the extent that a storm was too much for it.
    https://maritime-executive.com/article/burned-out-car-carrier-sinks-in-pacific-three-weeks-after-fire-began
  • xwesxxwesx Member Posts: 18,015
    edited June 2025
    mjfloyd1 said:
    They are almost 23 yrs old
    Oh, I misunderstood. I thought you had said they were only a year and a half old. My mistake!
    that's a heck of a thing.... electric battery fires on a ship! Seems like they need to devise some sort of vacuum suppression system to keep such fires in check, as normal methods of control just don't have enough oomph to deal with the intensity of lithium battery fires.
    @corvette said:
    When I bought this house in 2015, the A/C unit looked really terrible--rusted and barely any paint left on it, but it ran fine. It was so old that the home inspector's database didn't go back that far. Same failure, on that one--the fan motor locked up. I didn't know about the Liquid Wrench trick, but I had a spare window unit and was able to stay comfortable for the couple of days until I got the entire unit replaced. They offered to order the fan motor and just replace that for around $1k, but then I'd still have a 30+ year old unit that was cosmetically awful. No issues with the new Trane! It's definitely gotten a workout the past few days.
    I put in a new condenser fan motor and contactor today. Really a struggle to get the old fan blade off the old motor. Down to 73 degrees this am
    I’m not sure there is any liquid wrench trick - it was a desperation move to try to get it going again. The super lube worked better.
    edited June 2025
    One system is a year and a half old and working well. The other three (ouch - it seemed like a good idea at the time) are 23 yrs old. One new system is going in tomorrow.
  • corvettecorvette Member Posts: 11,731
    @stickguy said:
    On the door opener clean off the photo eyes and make sure lined up.
    Or, do like some of the car YouTubers do, and mount them on a wall a couple inches apart, facing each other, not that I would condone such a thing.
    That would be really messy though…😎😎
    I find it interesting that there are always worried about sea levels rising, but no one ever says “yep, but a lot of crap has sunk in the ocean”
  • jmonroe1jmonroe1 Member Posts: 9,820
    You people jinxed my son’s AC with all this talk. We were there a week back and they put it on (first time this year I think) and it didn’t generate much in the way of even cool air. They had someone out today to check it. New system going in tomorrow. Not sure of exact diagnosis but it’s from 1999 and still on Freon. Surprised it lasted this long and not going to be fixable. Not what they needed with all the new baby expenses.
    I told them to move before the baby but didn’t listen!
    I never knew babies planned on moving. B)
  • stickguystickguy Member Posts: 54,318
    baby will just go along for the ride.
    the AC in our Acura is OK, nothing special, but the Ford really gets cold quick. Can freeze in that thing. actually probably helps not having to cool the cargo area!
    I’m sure you saved yourself at least a couple hundred bucks by doing the work yourself. Too bad that savings is going to be plowed into new units. :'(
  • oldfarmer50oldfarmer50 Member Posts: 24,628
    @oldfarmer50 said:
    Have any of you heard the story about Stellantis offering retirement buyouts to 60% of its US workers force? That sounds ominous.
    Where did you see that? Last retirement buyout I saw was back in March.
    It was some random YT video.
    edited June 2025
    mjfloyd1 said:
    Well craptastic, main floor ac crapped out. I changed the capacitor but the contactor was stuck (thankfully on) and fan motor seized. A little Liquid wrench and we are back in business until it can be repaired.
    Must be the season for that. Last night my son’s window unit crapped out on the cusp of a string of near 100 degree days. Luckily, I had an extra unit since I replaced the downstairs AC a few weeks ago.
    The infuriating thing is that his unit was only going into its second season. Well past the 90 day cheapo warranty.
    Did it just stop turning on at all? If so ... the new units use ultra cheap GFCI plugs and they often fail. Solution is to install a new plug. $4 at Lowe's / HD.... won't be GFCI but we survived for many years without GFCI on window ACs.
    Fan worked but the compressor doesn’t come on. These things are so cheap that they are not worth fixing but I bet it’s a bad switch or loose connection. Not something I want to fuss with at 100 degrees after a 12 hour shift.
    I saw that too. maybe the same one!
    I don’t know if even that would work as I’ve seen videos of EVs burning under water. What’s the current protocol for battling battery fires? Blankets, foam, 50,000 gallons of water?
    The car carrier ships have some sort of CO2 system under pressure that they use to somehow displace the regular atmosphere on the decks below. But apparently it needs a rethink to be more effective against lithium battery fires.
    90+ degrees today.
    Had my appointment for the A/C annual checkup.
    Guy said everything was ok.
    He recommnded some upsells. An ionizer and a soft start device.
    I had him install the soft start kit.
    Hopefully it gets me a little more time because the startup was pretty abrupt and loud. Seems quieter now.
    He showed me screen shots of the startup voltage. 85 volts before and 46 after.
  • roadburnerroadburner Member Posts: 18,613
    I was going to cut the grass close to sunset last night but it started to rain. This afternoon I said screw it and stared mowing at 1:00 pm at 95F. The mower had been down while I replaced a couple of belts so it had been about two weeks since the last cut. It took a bit under two hours but at least I had my earbuds and was able to listen to the Missed Apex F1 podcast.
    Makes sense. I think the issue with the battery fires are that they are so, so hot, yet they still need oxygen to combust. Just theorizing here, but carbon dioxide and water both have it... a lot of it... so if you can get it hot enough to break that bond, then something that normally suppresses now becomes something that feeds. And, even if these do suppress, the reaction, once started, is spontaneous.... as soon as oxygen is more readily available, the reaction will resume as before.
    A vacuum removes the oxygen, probably not entirely in practical applications, but enough that you could, theoretically, suppress the intensity/rate of the fire, thereby reducing the heat and the likelihood of a chain reaction. That said, these ships are vast, and they fill the hulls with these cars. I imagine it would take a heck of a modified ship to be able to accommodate that sort of suppression system successfully.
    edited June 2025
    The lithium battery fires are actually runaway events. They don't need oxygen from other sources.
    "Regarding the need for oxygen, lithium-ion batteries can generate oxygen during thermal runaway. When the metal oxides in the battery's cathode are heated, they decompose and release oxygen gas. This oxygen can sustain a fire, making it more challenging to extinguish.
    However, it is important to note that the initial fire is not dependent on atmospheric oxygen, as the reaction is self-sustaining once thermal runaway begins.
    "In summary, lithium-ion batteries can catch fire due to thermal runaway caused by factors such as overcharging, physical damage, or manufacturing defects. While they can generate oxygen during thermal runaway, the initial fire does not require atmospheric oxygen."
    All that can be done is to cool the reaction.
    https://search.brave.com/search?q=what+causes+lithium+auto+batteries+to+catch+on+fire%3F+Do+they+need+oxygen%3F&summary=1&conversation=234b8a7542b129022c7034
    What could possibly go wrong? :D
    I knew that. o:)
    edited June 2025
    If you leave the 240 attached it could go south. Not turning the system off inside would just be a little zap. It was shockingly easy to replace the compressor fan motor since I bought the OEM. It had the correct snap in thermal and then only attach the ground wire to the chassis. The contactor was plug and play.
    The fan required PB blaster and then a puller using an impact wrench and then tap the motor shaft out.
    mjfloyd1 said:
    How is my work? I even zip tied the wires. I turned the system to off inside the house and pulled the disconnect. The fan was really a hassle to get off the motor but there were no new 2 blade ones available except a 4 blade with a higher pitch but I was worried it would cause too much drag on the 1/8 hp motor.
    I did get the yellow wire off of the top of the capacitor.
    Nice job.
    Consider yourself a #1 hacker. HVAC guys really dislike folks like you.
    FWIW, my compressors cooling fan motor shaft is 3/8 of an inch in diameter and it spins a 3 blade fan. The whole assembly is mounted to the underside of the top grill (it’s a 3 ton Lennox unit).
    edited June 2025
    @jmonroe1 said:
    Nice job.
    I’ve changed out one like that on a pool heat pump a couple of yrs ago. It was more of a pain
  • driver100driver100 Member Posts: 32,720
    edited June 2025
    I missed about 4 pages, I have been ultra busy but I am putting in an appearance just for the fans.
    This guy as 5 cars you should not buy....short and sweet and kind of amusing:
    https://www.youtube.com/shorts/hmE-l7xKd9g?feature=share
  • sdasda Member Posts: 7,737
    🔥HOT, Felt like 109. Thunder storm currently. Ahh, summer storms.
  • qbrozenqbrozen Member Posts: 33,846
    There is so much wrong with that post that it is impossible to know where to start
    Usually starting at the beginning is the best way. But, jumping to the end of that story is the best way since you won’t have to read anymore of that sad story.
    my son just texted that they now have AC again. Crew finished after 10. He said the guy told him that they have worked that late every day this week.
    apparently they would have finished earlier but when they got the unit on, the valve that it fills refrigerant through (king valve?) was stuck shut and they could not get it open. so they had to take that one off while someone went back to the shop to get a new one, bring it back, and install again. Hopefully after all this it is at least reliable!
    He has a number of videos like that criticizing the engine or transmission of usually low end cars although he trashes Range Rovers all the time. No details so I find him frustrating.
    Some folks thrive on negativity and complaining.
    edited June 2025
    Just received permission from Docs I can drive again. Been a month and a half since I got behind the wheel. Just wanted to drive around a bit just to see how it felt (fine, but right leg still hurts). So, the horrors, went to a car wash because I'm not going to hand wash my car any time soon.
    Went to a popular one in Sharonville, OH where they do the whole shebang...inside, outside, windows, vacuum, tire shine, etc.
    Mostly, it's staffed by young people for a summer job and what I'll kindly surmise are people with questionable legal status. No matter, they did a great job.
    Was talking to the kind (maybe 17-19 years old) that dried my car. He said he had lost 18 pounds in the last 3 days working. I tipped him well.
    Oh year, good to have a clean car again, too.
    Thanks for the warning. We now know to be on the lookout for an old geezer with a shiny car trying to learn how to drive again. B)
    Anyway, good to hear you’re almost your old self again.
    A tennis friend is a great guy, and he is looking for a new car to replace his 2017 Hyundai SUV which has been acting up, it stalls out and hesitates a lot.
    He mentioned he knows nothing about cars, but he likes a Nissan Rogue mainly because they have .99% financing these days, he is a retired bank exec.
    I read that the Rogue offers a 3 cylinder engine that has 201 H.P. with it's turbo engine. The article I read said that gave it power, but it was rough when idling.
    I told him, the Rogue is probably fine, but make sure it isn't the 3 cylinder model. He asked, "What is a cylinder", and said he knows nothing about cars. I explained a car should have 4 cylinders minimum and some reasons why.
    He was going to look at the Rogue Friday afternoon. I was curious and I checked this review of the Rogue, at the 2 minute mark he explains why the 3 cylinder engine could lead to big problems and a very low value for a used Rogue.
    He may have bought the car so I decided not to send him the review. If he hasn't bought it when I see him I'll send him the review;
    https://www.google.com/search?q=is+a+2025+nissan+rogue+3+cylinder+a+good+car+to+buy&oq=is+a+2025+nissan+rogue+3+cylinder+a+good+car+to+buy&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIHCAEQIRigAdIBCjIwNjcwajBqMTWoAgiwAgHxBVxnkk7JqKAz&sourceid=chrome&ie=UTF-8#fpstate=ive&vld=cid:5b466cbb,vid:L6G9B2LRmi4,st:0
    The Rogue is a decent CUV. The 3-cyl engine is not really much of an issue, any more than the problematic 4-cyl engines from other automakers have been. It still has a CVT which some reviewers do not like, and it is a bit wallowy in corners apparently. But it is reportedly comfortable and quiet, so sort of mid-pack. I think the biggest concern might be whether Nissan survives its financial crunch. You probably can get good deals because of that.
  • MichaellMichaell Moderator Posts: 268,649
    I would second that.
    I had a Rogue as a rental for about 10 days last year, and honestly couldn't tell you the difference between the 3-cyl engine it had and 4-cylinders from other makes. Quiet, decent power. Pretty comfortable inside.
    The low financing is attracting a lot of attention.
    Question for our, um, "retired" folks here. What are you all using for TV/Internet service?
    We've been using Comcast for 25+ years for our home phone, internet and cable TV. Price creep has made our monthly bill pretty expensive, and we're looking at options to replace it.
    We've decided we don't use or need a home phone any further, so that's going away. There are some senior deals (55+) out there that look appealing, but I'm curious how everyone else consumes their viewing content.
    Our daughter pays for AppleTV, Netflix, Prime, and one or two other streaming services, so I doubt we'd want to lose those.
    not retired yet. but old enough and hopefully soon! but having recently moved and made a change, I feel qualified.
    until last year we just had cable and paid the ever increasing cost. included a home phone in the triple play deal. We actually got some calls at the NJ place. When we moved, we didn't even remember the new phone number, and it only rang for spam. so did not need that.
    the new house we intended to get cable, but due to some miscommunication in the box behind the TV mount they put in an ethernet jack instead of coax. so we instead went with Verizon Fios. Since they didn't offer the TV part of that here (no idea why) we just got it for internet. Then we added Hulu live TV+ because we wanted the local stations (and are probably not in good antennae range, plus I did not want to deal with that) plus they include the Mets games.
    A small learning curve on using Hulu, but if you have streaming services already on the smart TV it will feel natural. My yardstick is that my wife can handle it, so it has to be simple. I honestly didn't miss cable after the first few days, and we get every station they offered that I ever want to watch.
    Some People prefer YouTube TV plus. about the same price.
    I think we pay about $165/month all in. Cable was up to about $235. Verizon high speed is about $80 and Hulu $83. If you are fine with the streaming stuff only (so giving up the cable stuff like HGTV) and can run an antennae for local, you can cut that way down. Plenty of stuff to watch for free also, and if you don't mind some research, can find a lot of stuff (maybe not new episodes) on places like the HGTV website. Or youtube. everything seems to end up there.
    I would never go back to cable at this point.
    edited June 2025
    I still have cable(Spectrum) but I pretty much watch sports exclusively. Unless the grandkids are over. :)
    I get the usual ESPN, ESPN2, Fox Sports, etc... but I also get MLB Network, NFL Network, NHL Network, Big 10, SEC, ACC Networks, Cleveland baseball and Columbis hockey.
    Edit: We don't have a landline anymore.
