2025 Ford Expedition Lease Deals, Incentives, Rebates, and Prices
2»
  • kyfdxkyfdx Moderator Posts: 273,555
    terranea said:
    Hello - can I get please get MF, RV & any incentives for 2025 expedition tremor off road package
    36/10k miles, zip is 32164
    Standard APR
    58% residual
  • terraneaterranea Member Posts: 22
    Standard APR
    58% residual
    sorry - what is standard APR?
    Standard APR
    58% residual
    We don't know exactly. Somewhere in the 8%-9% range
    Standard APR
    58% residual
    Standard APR
    58% residual
    gotcha, thanks for the clarification
  • JBenGuinnJBenGuinn Member Posts: 102
    Hi, can I please get MF, RV, and lease incentives for a 2025 Expedition MAX Limited 4WD, 36/12, zip 37209? Thanks!
    I don't see a Limited trim for the 2025 model
  • ctelisctelis Member Posts: 63
    Could you please provide the residual and rate for the following:
    2025
    Tremor 4x4
    Zip: 33967
  • MichaellMichaell Moderator Posts: 269,587
    2025
    Tremor 4x4
    Zip: 33967
    Standard APR
    57% residual
  • NytoscNytosc Member Posts: 9
    Could anyone share MF and Residual on a 2025 expedition platinum 4x4 at 24 and 36 months and 7500 miles in 57101
    6.50% APR and 69% residual
    6.42% APR and 60% residual
    $150 dealer cash
  • CJ05CJ05 Member Posts: 39
    edited September 2025
    Hi, could you please share MF and residual for a 2025 Expedition Max Platinum 4x4. 12K/36 or 39 months. 06840.
    Any incentives for the above?
    Thank you very much.
    6.42% APR and 57% residual
    6.67% APR and 54% residual
  • itamarbhitamarbh Member Posts: 1
    Could you please share Money Factor and Residual for 2025 Expedition Max Platinum (driver package)?
    12K / 36Mo, Zip 33957
    Thank you!!
    Thank you!!
  • Dlcorbett10Dlcorbett10 Member Posts: 6
    Looking for lease incentive info for expedition platinum. Im assuming the rates will be the same regardless of trim:
    3 yr/15k annual
    3 yr/12k annual
    3 yr/15k annual
    3 yr/12k annual
    What is your location?
    Zip code: 29486 - charleston sc
    3 yr/15k annual
    3 yr/12k annual
    6.42% APR
    56% residual
    edited November 2025
    Good evening, could you please provide the mf and residual for the following!2025's:
    Platinum
    4x4
    Platinum MAX
    4x4
    Tremor
    Any lease cash?
    Zip: 33967
    Platinum
    4x4
    Platinum MAX
    4x4
    Tremor
    Any lease cash?
    Zip: 33967
    6.42% APR
    58% Plat
    57% Trem
    57% Plat Max
    Wondering if anything has changed this month
    Platinum
    4x4
    Platinum MAX
    4x4
    Tremor
    Any lease cash?
    Zip: 33967
    Platinum
    4x4
    Platinum MAX
    4x4
    Tremor
    Any lease cash?
    Zip: 33967
    No changes
  • Titan0118Titan0118 Member Posts: 36
    edited December 2025
    Hello, may I please have residual and money factor and any incentives for an Expedition Active, 3/36 and 42/42 in zip 15642? Thank you!!
    2WD or 4WD?
    2WD or 4WD?
    Sorry! Didn’t realize 2WD was an option. This one is 4WD.
    Titan0118 said:
    2WD or 4WD?
    36/12: 6.42% APR and 59% residual
    39/12: 6.67% APR and 57% residual
    We don't have 42 month terms
  • OzertimeOzertime Member Posts: 54
    Hello, can I please get the MF and RV for a 2025 Ford Expedition Platinum 4x4 in zip 92867? 36 months, 10k miles per year. Also any incentives? Thanks in advance.
    6.42% APR and 59% RV
    $1000 incentive
    Thank you. Are the numbers the same if it is a MAX Platinum (i.e., extended wheelbase)?
    58% residual is the only difference
  • Sixers21Sixers21 Member Posts: 21
    Hi, are you able to provide the MF, RV & any incentives for 2025 Expedition Max Active 4x4 in zip 20879 for both a 36/10 and 39/10 lease?
    36 month term is not supported by Ford, this month
    39/10
    5.22% APR and 56% RV
  • hagan16hagan16 Member Posts: 56
    Hi, could you provide the MF, RV & any incentives for 2025 Expedition Active 4x4 in zip 17584? Interested in 36/10 and 39/10. Thanks
    5.22% APR and 57% RV
    5.47% APR and 56% RV
  • Josh123467900Josh123467900 Member Posts: 22
    Hi, could you provide the MF, RV & any incentives for 2025 Expedition Active & Platinum 4WD in zip 92111? Interested in 36/10 and 39/10. Thanks
    Standard APR
    61%/60% RV for Active
    58%/57% RV for Plat
    Good evening, could you please provide the mf and residual for the following 2025's:
    Active Max
    4x4
    Platinum Reg & MAX
    4x4
    Tremor
    Any lease cash?
    Zip: 33967
    Active Max
    4x4
    Platinum Reg & MAX
    4x4
    Tremor
    Any lease cash?
    Zip: 33967
    5.22% APR
    55% residual
    55% and 54% residual
    54% residual
    39/10
    Thank you. Could you also provide the 39 month term numbers for zip 22150 for both the 2025 Expedition Max Active 4x4 and 2025 Expedition Active 4x4?
    39/10
    Numbers won't change for the other ZIP
    Hi, could you provide the MF/RV and any incentives for the 2026 Expedition Active 4x2, Active MAX 4x2, Platinum, and Platinum MAX for 92111 please? Interested in a 36/10, 39/10, and 42/10 (if applicable). Thanks!
    I couldn't find the 2026 forum
    2026 model discussion
    Hi could you provide the MF/RV and incentives for a 2025 Expedition Max Active 4x4 in zip 18235. Interested in a 36/10 and 39/10. Thanks
    5.22% APR and 56% residual
    5.47% APR and 55% residual
    $500 lease cash
