2024 Chevrolet Silverado EV Lease Deals, Incentives, Rebates, and Prices
2»
  • whataday2whataday2 Member Posts: 18
    edited June 29
    Hi, can I please get June lease numbers for 2024 SIlverado EV Crewcab Shortbox Work Truck 4WD & EV RST e4WD?
    24/10k, 27/10k, 36/10k
    85004
    Rebates/incentives?
  • MichaellMichaell Moderator Posts: 262,672
    85004
    Rebates/incentives?
    3WT or 4WT?
    (pick only one)
    85004
    Rebates/incentives?
    3WT or 4WT?
    (pick only one)
    3WT please. Thank you so much!
    85004
    Rebates/incentives?
    3WT or 4WT?
    (pick only one)
    RST
    .00096 and 70%
    .00096 and 69%
    .00091 and 68%
    3WT
    .00143 and 71%
    .00143 and 70%
    .00160 and 66%
  • SimanderSimander Member Posts: 29
    3WT: .00143 MF and 71% residual
    4WD: .00096 MF and 69% residual
    Sorry can you also provide for 24/12 for 14221 2024 3WT?
    .00143 and 70%
    edited June 30
    85004
    Rebates/incentives?
    3WT or 4WT?
    (pick only one)
    Hi, I'm so sorry. Can I please also get Crewcab Shortbox Work Truck 4WD 4WT for just 24/10? The 3WT loaner I was eyeing sold overnight and only 4WT loaner remains :(
    Thank you so much
  • kyfdxkyfdx Moderator Posts: 266,190
    85004
    Rebates/incentives?
    3WT or 4WT?
    (pick only one)
    Thank you so much
    Hi, can I please get July lease numbers for 2024 Silverado EV Crewcab Shortbox Work Truck 4WD 3WT?
    24/10k
    85004
    Rebates/incentives?
    24/10k
    85004
    Rebates/incentives?
    .00170 MF and 71% residual
  • BigemoneyBigemoney Member Posts: 16
    Could you give me the mf and residual for an RST for 24/15k and 36/15k for 84790?
    .00117 MF and 68% residual
    .00112 MF and 65% residual
  • Cedric0045Cedric0045 Member Posts: 10
    Could you give me the mf and residual for an 3WT for 24/15k and 36/15k 75227?
    .00170 MF and 69% residual
    .00188 MF and 63% residual
  • bavarian3bavarian3 Member Posts: 38
    Hi there, may I have MF/residual/incentives for Silverado EV RST 24/10k 33647 zip?
    .00117 MF and 70% residual
  • khoward2001khoward2001 Member Posts: 48
    Hi there, may I have MF/residual/incentives for Silverado EV RST 24/10k 36/10k zip 28546
    .00112 MF and 68% residual
  • Dealdeal101Dealdeal101 Member Posts: 11
    Hey guys, hope you are all doing well. Could I grab the MF/Res for a 2024 Chevrolet Silverado EV 4W/T?
    Zip-29715
    Zip-29715
    Lease term and mileage?
    sorry, 24/10000
    Zip-29715
    sorry, 24/10000
    .00122 MF and 69% RV
  • JessterSBJessterSB Member Posts: 3
    Hi, can I please get the MF and Residuals in 93117 for the:
    - 2024 Silverado EV LT Extended Range
    - 2024 Silverado EV RST Extended Range
    We don't see an LT trim
  • larryzzzlarryzzz Member Posts: 8
    edited July 25
    Hi, could you please provide the MF and RV for the 2024 Silverado EV RST with 36/10 and 39/10? Zip code is 79382. Also, is it true that Chevy does not do leases below 10k miles per year?
    Thank you so much!
    Thank you so much!
    .00112 MF
    68%/66% residual
    10K/yr is the lowest
  • kidwhykidwhy Member Posts: 10
    Can you please give me MF and RV for Silverado RST
    Zip code 48188
    24/12k
    and
    24/15k
    Zip code 48188
    24/12k
    and
    24/15k
    .00117 MF and 68% RV
  • SmaculaSmacula Member Posts: 18
    edited July 28
    Hi, can I please get MF and Residuals in zip 30519 and any available incentives for the:
    2024 Silverado EV RST courtesy vehicle
    24/12
    24/15
    24/12
    24/15
    24/12: .00117 MF and 69% residual
    36/12: .00112 MF and 67% residual
    24/12
    24/15
    Don't know if, or how, courtesy vehicle status changes those numbers.
    Hi, could you please provide the MF and RV for the 2024 Silverado EV RST with 36/10 and 39/10 in August? Zip code is 79382. Not sure if the numbers change in August and want to double check before talking with dealers. Thank you very much!
    July programs run through Monday
    August programs start on Tuesday, the 5th
